Question about Beko Washing Machines
Water is getting to the machine but not into machine
Brand new...hums but wont work on ANY programme
  • Beko Master
  • 9,587 Answers
Look at the fill connection to see if there are any shipping plugs blocking the water flow. If not then the solenoid that opens the water inlet to fill the machine is not working.
Posted on Nov 19, 2014
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: washing machine goes through the programme untill
Check to see if there is a pump filter, if not, then there is probably something stuck in the pump, you will probably have to remove pump to clear it.
Please rate my solution.
Thanks.
Posted on Sep 22, 2009
willnjess
SOURCE: Washing machine wont fill with
Yesterday, my Whirlpool washer just agitated only, no matter what cycle it was turned onto. My husband shook the washer,and gently dropped it up and down on the floor. He also unplugged it for a few minutes. I turned it on, and like magic it worked correctly! I have done 4 loads of wash since we got it going this am. I am happy. The washer is only 2 years old, and repairs are more then the appliance cost!!
Posted on Oct 09, 2014
After filling water it wont start the cycle?
Not an expert on washing machines Steve but I am mechanical. If the machine fills with water then the programmer must be working to an extent. It may be partially functional. It may possibly be entirely functional but the motor might have given up the ghost. I have had a few machines over my long life and when they have broken it has always been the programmer that broke. Anecdotal, but that would be my guess.
As washing machines are so cheap nowadays
I would get a new one rather than have a repair carried out that can cost nearly as much as a new machine.Good Luck
Jun 04, 2015 | Washing Machines
My new Miele Washing Machine (Model no WDA 110) is not taking in water. The programme timer counts down but no water comes in thru powder/conditioner. We have checked the installation carefully and
Hi, Jane.
Is the tap on? (Sorry, I had to ask)
Make sure the filters on the inlet valve(s) aren't blocked.
If all is well with the inlet valves you should hear a faint humming. This is normal.
If it's a new machine it would still be under warranty, so you should get a Miele serviceman to check out the problem.
Good Luck
Cheers
Nomess
Jan 05, 2015 | Miele Washing Machines
Brand new washing machine .. just humms will not fill water ???
selenoid valve is stock. after making sure water is turned on gently tap on the washer water connection with a hard object. if you are lucky the valve will get freed.
Dec 18, 2014 | Whirlpool Washing Machines
Front Loader Humming
Thats normal just the water valve
Dec 15, 2009 | Samsung WF328AA Front Load Washer
Washing machine goes through the programme untill it needs to drain. It makes humming noise but does not drain water out so then it wont spin
Thanks.
Sep 22, 2009 | Tricity Bendix AW1000W Front Load Washer
Dishwasher wont go into cycle mode and hums
No model and brand name .
the way you mention look like the main motor jammed and making the humming noise click out on overload then the humming noise stop and after a while it will humming again and continue like that until you switch off the machine. If the dishwasher is old I would recommand you buy a new one instead of changing the motor.
God Bless have a nice day Dickson
Jun 30, 2009 | Dishwashers
Fills up ok,but wont wash,,has a humming sound.
Yes, you need to fit new brushes, if motor still does not go, then it is probably faulty.
Please rate my fixya solution.
Thanks.
Feb 04, 2009 | GE Washing Machines
Not taking in water
go back to water vavle and start form there ,,is it humming..verifie water in fill hoses,,check and make sure you have hoses on dispencer correctly,,if removed,,,check and make sure you did not twist or kink hose entering tub...make sure connection are on the water valve..onthejob
Jan 24, 2009 | Hotpoint WMA66 Front Load Washer
My new Frigidair front loader
Wow it sure sounded like the water was turned off. There should be no problem getting a tech out soon to see whats going on why it wont bring the water in. It sounds like maybe the door lock isnt working?? Is the strike broken on the door?? I take it it wont spin on its spin only cycle??just return it to place of purchase. If you need any other assistance let me know, reply to your old posts so i can be notified you wouls like more assistance.
Jan 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Programme 1
make sure both solenoids have a working supply (if two fitted) at rear.
Nov 15, 2006 | Candy DQW150 Front Load Washer / Dryer
Washing Machines Logo
Top Beko Washing Machines Experts
Tom Chichester
J D Wright
 Russ Hill
Russ Hill
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
