Question about Yamaha Music
How do I get a Yamaha DD-50 4 pad Electronic drum machine manual. Downloaded manual from yamaha site and comes up as 5 pad. Can you help.
When I look on yamaha site the downloads are for a 7 pad machine
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • Yamaha Expert
  • 128 Answers
The DD50 as far as i am aware was only a 7 pad machine.
The DD35 was a 4 pad instrument.
How do I get a Yamaha DD-50 4 pad Electronic drum  - 25289937-25qnjy3ifepwofogsdsgnkd0-3-0.jpg
Posted on Jun 08, 2016
robotek
  • 1512 Answers
SOURCE: yamaha dd55 electronic drumkit
Hi sunshine
You can download the manual from here. Thanks for using FixYa.
regards robotek
Posted on Dec 19, 2008
  • 17 Answers
SOURCE: i want to connect my YAMAHA DTXPRESS IV SPECIAL to my PC
Any pro-audio interface with a midi input would do the trick. There are numerous products out there that offer this. You can get a simple usb midi interface, and connect the Yamaha up with a midi cable running from the midi out of the drum module to the nidi in of the interface.
one of the simpler ones:...
http://www.amazon.com/M-Audio-Midisport-Uno-MIDI-Interface/dp/B00007JRBM
Posted on Mar 04, 2009
  • 1126 Answers
SOURCE: CHANGE THE SENSITIVITY OF DRUM PADS ON (YAMAHA DTXPRESS IV SPECI)
http://www.yamaha.co.jp/manual/english/result.php?div_code=emi
This should link to owners manual..Hope this helps.
Posted on Aug 25, 2009
SOURCE: Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Posted on Feb 14, 2010
communicate
SOURCE: Alesis SR-16 distorted sounds
The distorted and low volume output plus noise is usually caused by using the wrong power supply adapter. The Alesis SR-16 takes a 9V "A/C" supply not "DC". The A/C supply provides a negative voltage swing which wouldn't exist with a DC supply. So check and make sure you have 9V A/C output supply not DC.
Posted on Apr 04, 2012
Electronic drum
That might be Yamaha DD-50 electronic drum. You will get the manual from Yamaha musical instrument website. https://usa.yamaha.com/files/download/other_assets/6/333636/DD50E.pdf
Dec 18, 2017 | Music
Yamaha DD-65 pad 2 has lost its sensetivety, if i hit it really hard it works, but when tapping it lightly like i can with the other pads, it does not sound. I have only just bought it second hand so...
There is a setting to use that sets for using either sticks or by hands. If a single pad is thee problem, likely the sensor has come loose. Most of these use a piezo disc pickup and this may have separated from the pad. Open unit carefully and check for this visually. If separated, try to analyze what type adhesive was used. It is likely a contact cement. If so, clean surfaces of residue and use contact cement following the direction. Let dry overnight per the label on the cement. Be careful of the cables in the unit when opening. Keep track of which screws go where. They sometimes have different lengths and threads.
May 23, 2011 | Yamaha DD65 PAK Electronic Drum Pad
I have the yamaha dd65 digital drum machine , they don't work at all , once I have turned the power on and I'm ready to play when I hit the pads it cycles through the voices then it stops the...
Make sure you have the ORIGINAL power adapter for this unit. It should say PA150 on it and provide 12 volts at 1.5 amps (1500ma). I am not sure of the polarity, but if the part number matches, you have the right one.
May 09, 2011 | Yamaha DD 65 Seven pad Digital Drum Module...
I Have a Yamaha dd55c electronic drum machine without the bass and Hi-Hat pedals. I am good with electronics and wondered how they are wired, or alternatively if they are available to buy from anywhere.
The pedals are domes with Piezo disc sensors. SImple two wire connection... the original pedals are really NOT very good... You might try to find regular pedals used for drum sets... they have a beater and sensor. They do cost a bunch.
May 07, 2011 | Yamaha DD55C 7-Pad General MIDI Digital...
Weak LCD Display on a Yamaha DTX Electronic Drum Kit
NOT a battery issue.
Note that many of these devices have a parameter one can set for "contrast" or "viewing angle". You might want to check your owners manual for this possibility.
I downloaded the DTX manual and there IS a contrast control on the back of the unit near the top left facing the back...
IT MAY require a screwdriver to adjust it.
Apr 03, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Not sure how to reset the pad for Highhat to read RRH
go to the Yamaha.com website and download the manual probably in PDF format. The old saying "for the last result read the instructions"
Good Luck and bang on you hihats.
Sep 04, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Problems with DTXpress III special bass drum pad
If you are comfortable with working on it and the warrantee is up try taking the pad apart to see if the piezo element has come loose from its mounting or if the solder joint is loose. If that isn't the problem save your settings and initialize the set according to the instructions in your manual.
Aug 09, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Music Logo
35 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
