Question about Luxor 27 Inch 2 Shelf Mobile TV Cart - Flat Panel / LCD Mount - LE27WTUD
How do i remove the thick black line at the bottom of my tv screen
Thick black line ascending from bottom of screen reducing the bottom part of veiwable screen
    Top Expert:
  • Luxor Master
  • 75,311 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Nov 19, 2014
Samsung TV thick black line running across the bottom.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 08, 2016 | Samsung PN51E450 - 51" Class 50.73...
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
VIZIO 42" tv has thick black vertical line on left side of screen
The oven paper (referred as ovenable paper some time), is made of wood pulp, coated with food grade silicone oil. It features in smoothness, high-heat resistance and non- stick, etc. The brightness of baking paper is over 88. The sizing value of baking paper is above 0.8.Its strength is more than 3000.
Feb 23, 2013 | Vizio 42 in. LCD TV
I have a inch thick black line down the center of my screen
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Aug 13, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Thick black line running down the middle of my screen
May 13, 2010 | Soyo SYTPT3227AB 32 in. LCD TV
Thick black line rolling up the recorded video of the TV
That is the camera not being in sync with the refresh rate of the TV. With consumer gear, there is really not much you can do about it.
Sep 08, 2009 | Mitsubishi WS-65809 65" Rear Projection...
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Aug 19, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
There is a thick black line down the middle of the screen
Aug 11, 2009 | Hyundai HPT-4250 Television
Hyundai 42inch plasma tv
If these are thick black lines, this is most likely line frequency noise entering the set. you may have a leakage from the DC ground on the secondary side of the powersupply to the AC side, or a bad filter capacitor(s). Most of the time it is the filter caps that give these types of problems. If you are connected to cable TV service, or an outside antenna you can also have this problem from an AC ground loop return. Also if there is a device such as a VCR connected to the TV and it has problems, it can cause this as well...
Mar 20, 2006 | Hyundai ImageQuest DPD4210 42 in. HD-Ready...
Luxor 27 Inch 2 Shelf Mobile TV Cart - Flat Panel / LCD Mount - LE27WTUD Logo
61 people viewed this question
Top Luxor Televison & Video Experts
sureshd2008
gbob59
rugby prop
Are you a Luxor Televison and Video Expert? Answer questions, earn points and help others
