Question about Procom Heating & Cooling
The fan doesn't run on my procom md200tbe natural gas heater. I'm sure power source it good, etc. Is it thermostat controlled? Wondering if it's possible the temp never gets high enough for it to kick
The fan doesn't run on my procom md200tbe natural gas heater. I'm sure power source it good, etc. Is it thermostat controlled? Wondering if it's possible the temp never gets high enough for it to kick on.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
There should be a 'snap disc' heat activated switch that is responsible for starting the fan on rise in temperature. This should occur around 140 degrees. If the fan does NOT start, it will cycle on the high limit safety, usually at 200 degrees. Some hi limits are manual reset. The flames should be two shades of blue, an inner cone of a shade darker than the larger, taller outer cone of light blue. An occasional flicker of BRIGHT orange may dance across the top of the flame, but never a YELLOW tip.
It would be hard for it to burn reasonably normally with gas pressure so low that it wouldn't produce enough heat to get to the 'fan on' temperature. There would be other issues too.
I'm just guessing the 'fan on' switch is defective or a wire is burnt off somewhere in the fan circuit. Of course, the motor could also be bad.
Posted on Nov 23, 2014
SOURCE: Natural Gas wall heater
It could be either the thermostat or thermocouple is not getting correct voltage so will intermittent turn on and off.
Posted on Jan 21, 2008
SOURCE: Procom Model SN400TYLA Thermocoupler bad, can't find part
try 18778865989
Posted on Oct 28, 2008
  • 108 Answers
SOURCE: procom MN300HPA ventless heater conversion
You need to first get a regulator which will go between the propane tank and the burner. You will need to know the burner capacity in BTU/HR and the pressure required. All of this can be found on the furnace specification plate or on the gas valve. It is a no brainer Circut!
Ray
Posted on Nov 07, 2008
  • 22 Answers
SOURCE: convert a procom heater from propane to natural
you need to find a place that makes your type of heater and they will have a change over kit all it is different orfices and jetcovers for each gas jet from your heater its self explanitory once you see the parts,sometimes there are different gas comp. that if you use there service they will change you over at no or little cost. hope this helps
Posted on Sep 15, 2009
SOURCE: I want to convert a QN300TYLA natural gas unit to
HI , I HAVE A PROPANE MODLE QL300TYLA I WOULD LIKE TO CONVERT TO NATURAL GAS , MAYBE WE CAN SWITCH PARTS.
Posted on Oct 14, 2009
Why does the heater turn off?
If it's thermostatically controlled, if shuts off the burner when it reaches the set temperature. Is the pilot flame going out too? These heaters require a certain amount of fresh air to operate properly. If the oxygen level gets too low, it is designed to shut off completely for your safety.
Mar 15, 2015 | Procom 10K BTU, Vent Free, 2 Plaque...
I have a Pro-Com duel fuel ( NG/LP ) mdl # MD200TBE. Using natural gas and correctly set, any setting above 2 the pilot light flame increases dramaticly and will eventually go out causing the stove to go...
Frankly, Jerry from what you described, it doesn't sound like it's correctly set. The pilot light flame shouldn't increase at all when you turn the heater up. If it's properly set on Natural Gas the pilot flame should remain about 2 1/2" to 3" long. It sounds as if there is a problem with the gas control valve. In which case, I would strongly recommend that you stop using ,until you can have the unit professional checked and/or repaired. If the unit is under a year old, it's still under warranty. Contact the manufacturer directly.
Jan 17, 2011 | Heating & Cooling
Hello, How to convert a ProCom VentFree Stove QL300TYLA from Propane to natural gas..
yo have to get a kit the orifices are way different because nat gas runs at one half a pound and propane runa at 10 pounds
Feb 20, 2010 | Procom QL300TYLA Heater
Kerosene odor from natural gas heater. gas co thinks grates break
The odor your referring to usually comes from you recently using an oil based product like paint or wood oil. Until the petroleum based product has fully dried, the open flame will seem to be the source of the odor but are really just intensifying it. If you have a gas range, see if those burners smell similar. Rags in a gas dryer also cause the odor. The gas co. will check for gas or carbon monoxide  only but this odor is neither. Good Luck and please rate my answer if it was helpful.
Dec 30, 2009 | Procom 10K BTU, Vent Free, 2 Plaque...
I have a ProCom FBN400TYLA vent free natural gas fireplace and want to convert to propane because the gas company wants too much money to hook up a line. Is this even possible?
Found the manual on line and copied directly from it:
WARNING
Models FBN400 are equipped for Natural
gas. Field conversion is not
permitted.
Models FBL400 are equipped for Propane
gas. Field conversion is not permitted
This should answer your question.
See if you can run the gas line or find someone to do it cheaper for you.
Nov 15, 2009 | Procom QL300TYLA Heater
I'm trying to get my heater going this season. The pilot lights fine and heater will kick in but will only run 30 seconds max before it quits and I have to restart it. I've done this at least 20 times in a...
Does this have a fan attached to it or does the heat just stay around the unit. Does this have a thermostat or is it manually turn it on and off?
Is this in the garage or house?
1) Make sure no fans are operating when you do this.
An external fan can either **** the pilot off or blow it out.
2) Make sure if it has a thermostat that the sensing bulb located on the back is not picking up external
heat source.
3) If it has an external sensing bulb, put it in a bucket
of cold wtaer. Then try to light the pilot
Sep 30, 2009 | Procom (177653) Utility Heater
Convert a procom heater from propane to natural
Sep 14, 2009 | Procom ML300TBA Heater
Looking for: ProCom Model MNO60HBA (about 3 years old) 6000BTU-Natural Gas-Serial#3620775. I want 3 of the plastic like adjuster knobs on top of the heater. Not the igniter button but the one to allow gas...
Control knobs can be purchased from Procom customer service at 877-886-5989. If you can't find them there, call Kozy World's customer service department at 800-776-9425 and tell them you need a control knob for a KWN109 (same size heater, manufactured by Procom, so same control knob).
Mar 07, 2009 | Procom ML060HPA Heater
Heating & Cooling Logo
96 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
