Question about Remington Garden
How do i set the air intake on the back side of a Remington 170T?
Tried to adjust the air intake
  • 4 Answers
You don't set the air flow, you set the fuel rate. There is typically a plastic screw in the back that supplies air pressure to push the fuel in. Clockwise will increase fuel flow. You will need to adjust until you find the sweet spot of good heat with no black smoke.
Posted on Nov 29, 2014
First of I have 93 5.0 vert and the problem was when I let of gas I would hear popping sound then it got worse and sounded like I was throwing a rod then knocking stopped. Changed maf ,adjusted vavles...
you obviously know your vehicle, how about the crank sensor and VSS , when i've come across these type of symptoms before they are a nightmare to find sometimes , does it always die after starting now ? had a chrysler that had some foam sucked up into the air intake , that did what your's seems to be doing , have you tried starting with the air intake off ? might be worth a try , keep me posted if you wish
May 28, 2014 | Cars & Trucks
I have 1967 Gilera 106 Sears. Earlier I got it to run for about a minute then it would die. I tried adjusting the fuel and air intake but now I have this. Does anyone have advise on 60's Gilera's from
Check the fuel pipes make sure there is no blockages, take the carb off and clean with carb cleaner and put the mixture back to the original
Apr 20, 2013 | Motorcycles
I have a Remington Model HC-912A hair clippers and need to find a 1.8 inch attachment. Where do I find one?
The Remington Model HC-912A has adjustable blade with a lever on the side, you can use the Wahl attachment comb. You can this this at
Manny's Sharpening
Jun 11, 2012 | Remington Precision HC-8017 Hair Trimmer
My remington 870 is suddenly not loading shells from the tube. What could be the problem
It could be that the spring in the ammo tube is not strong enough to push them far enough back to clear the tube. Have you added any type of accessorys to the receiver like a side saddle, scope, etc? If you have changed the tightness of any of the screws or bolts (such as you would replace or adjust for a side saddle), it can bind up the action and prevent the free movement of the shells. Is it a new weapon? Is it propperly lubricated?
May 11, 2011 | Remington Sport & Outdoor - Others
Does a Remington 3.0 HP 300 with #114732-01s have a chain tension and screw. I do not have the manual and can not see where a chain tension screw would go.
The part number is Remington's and cannot be interpreted. What is the saw model number (reply below please)?
See the 2 holes near the heel of the bar (each side of the slot)? That is where the adjuster fits. I do not recall any Remington with an "Intenz" type bar (tensioner embedded in the bar).
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 06, 2010 | Remington Electric Chain Saw
The clipper blade adjustment on my Remington Hair Clipper, model HC-8017 (a black plastic adjustment arm) broke. Is it possible to get a replacement part?
The part that you require is not available for budget models like the HC-8017. You will need to purchase a new clipper or find an old one (ebay?) that you can buy cheaply for parts.
If you decide to replace your HC-8017 clipper, you will find them for sale at shaveroutlet.com
Jan 25, 2010 | Remington Precision HC-8017 Hair Trimmer
Chain fell off chain saw remington 10" pole saw, need directions to put back on.
Look from the side of the saw the motor/engine to left and the bar nose to the right. The thinnest part of the chain (sharpened edge) on the top of the bar is to the right.
Sep 26, 2009 | Remington Electric Pole Saw
Chain fell off my remington chainsaw, easiest way to put it back on?
Adjust the bar in until you can get the chain back on it and then adjust the bar out until the chain is snug but still can be turned by hand. hope this helps you...
Sep 17, 2009 | Remington Garden
Idle speed adjustment
While looking at the engine from in front of the car with the hood up..
Locate the TBI assembly ( follow the air intake tub from the cor support back. It leads directly to it ). Next look on the lower left side of the TBI just above the throttle linkage connection to the TBI.
you will see what looks like a little molded bullet sticking off the side with a screw sticking out of it making contact with the linkage assembly. On the back side of that little bullet you will see a torques head type screw head. adjust that forwards to increase idle speed or back it off to lower idle.
If you have a high idle condition the chances are it is not due to the idle set screw. Its more then likely either deteriorated vacum lines, deteriorated TBI gasket or a bad Air Idle Control Motor ( IAC ).
If you adjust the screw and nothing happens worth noting then check the vacum lines and replace. If nothing happens still then change the TBI gasket where it mounts to the intake.
If that doesnt do it then your left with the more costly option of changin out the IAC for a new one. They run from $75 - $125 depending on where you shop.
If after you change the IAC and it is still acting out then you may have an intak emanifold leak, or a head leak.
Oct 25, 2008 | 1986 Chevrolet Cavalier 2 Door
Garden Logo
66 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
