Question about MAGNASONIC MAG-MM176K Projection Clock Radio
How do I make the backlight of the Magnasonic projection clock disappear ?
I have an EnVivo projection alarm clock model P1223. I can't find the instructions & cannot turn the alarm off. Help?!
Use Mode button until on the Alarm setting with current time set (for Alarm) flashes. Adjust until the display shows - - : - - (not 00 : 00 as this is Midnight!) the dashes represent No Time Set. The Alarm will disappear from the display denoting Alarm Off. Took a while and many alarm events to find, but it works. This is specifically for the Envivo Alarm Projection Clock 1223.
Jul 28, 2013 | Audio Players & Recorders
How to unlock magnasonic vcr/dvd 833-2 combo
If the shipping lock is on, on your Magnasonic DVD833-2, hold the POWER button for 8 seconds. The factory password for parental control is 3308. For the factory manual here is the link http://magnasonic.com/discontinued/manual/DVD833-2_Eng.pdf
Oct 22, 2011 | Televison & Video
How do you increase the volume of the backlit light?
Hello
The backlight can be adjusted as follows:
This alarm clock radio features an adjustable display backlight, with dim, medium, and bright settings. To
select a backlight setting, press the 3 Snooze/Dimmer Bar until the desired brightness is reached.
Please note that the backlight will not work while the clock is operating on battery power.
OK
Apr 07, 2011 | Timex T311T Clock Radio
The instrument cluster & clock won't light up
I would check the fuse first,the fuse, should be a 5 amp.The fuse box cover should tell you what fuse it is.It might say INT short for instrument,If that don't work you might have a bad dimmer instrument panel swicth.
Mar 16, 2010 | 2005 Pontiac Sunfire
Oregon Scientific RRM326P Snooze button won't work with radio
this is internal speaker control volume defect, please send to repair shop for repair.
Nov 29, 2009 | Audio Players & Recorders
Have all for one 4110 - need code for magnasonic
http://www.hifi-remote.com/ofaold/tvcode.html
MAGNASONIC 017,019,030,153,154,156,193,093,179
Should be one of these. If not try the website.
Oct 25, 2009 | Televison & Video
I can`t seem to get rid of the clock or channel on my screen HELP
Press Display or "info" button on Sony TV Remote, on-screen display will disappear. Please use TV Remote, no other remote will work for that.
Jul 15, 2009 | Sony KP-57WS520 57" Rear Projection...
MAGNASONIC MAG-MM176K Projection Clock Radio Logo
32 people viewed this question
Top MAGNASONIC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MAGNASONIC Audio Player and Recorder Expert? Answer questions, earn points and help others
