Question about Whirlpool Freezers
I have a whirlpool chest freezer and the warning light has come on it was stored in the garage but was working fine,then moved into the house.the compressor kicks in for about 10 seconds then cuts out
I have a whirlpool chest freezer and the warning light has come on it was stored in the garage but was working fine,then moved into the house.the compressor kicks in for about 10 seconds then cuts out.
    Problem Solver:
  • 10 Answers
A refrigerant line may have been damaged in the move, loss of refrigerant or a kinked line has stopped the compressor from working, need to attach refrigerant gages to find the problem and know the refrigerant level
Posted on Nov 19, 2014
watugot
  • 290 Answers
SOURCE: kenmore chest freezer not working
Remove the panel covering the compressor. Remove the relay plugged on the side of the compressor and shake it. If it rattles or has any burned spots it is shorted out. Try replacing it first. Make sure you replace it with the correct replacement, not a fit-all. If this is not the problem you will need to replace the compressor. If it is less than 5 yrs old the compressor should still be in warranty. If so call Sears, it will be repaired free of charge. If it is out of warranty buy a new freezer.
Posted on Sep 25, 2007
  • 61 Answers
SOURCE: can a chest freezer be put in an unheated garage?
yes you may encounter problems come sumer depending how hot it gets where you live but during the winter you should have no problems.
Posted on Jan 20, 2009
peyton32034
  • 410 Answers
SOURCE: GE chest freeze won't get cold
the noise your hearing indicates the possibility of a bad start relay on the comp or possibly it just came loose during the move. on the side of the compressor you will see 2-3 wires running into an electrical connection reseat this first. if still no operation replace teh relay. you can purchase thru any reputable appliance parts dealer. after replacing the relay if you have no operation then likely problem is seized comp.
domestic freezers do not have low pressure switches that indicate low freon charge.
Posted on Jan 28, 2009
dmftrucker
  • 1922 Answers
SOURCE: can a chest freezer be used in an unheated garage
why not then when its down to zero shut the unit off and open the lid and free freezing...no electricity required....remember pop machines sit out in all types of weather
Posted on Sep 16, 2009
  • 382 Answers
SOURCE: Black & Decker BF53 Chest Freezer wont freezer
dear sir,
i think after long trasporatation your freezer has been leek from any pipe so please contect to your service technician for find out that leek and refill the refrigrant gas .after that your freezer will be able to good cool.
hope the question,s answer
thank you .
Posted on Jul 12, 2010
The standby light is still on
Are you sure it is a standby light? Usually the orange light is showing you it is in fast freeze. Try switching the orange button off and monitor the temperature. The freezer should cycle on and off, not run continuously.
Apr 15, 2012 | Whirlpool 10 cu. ft. / 283 liter Chest...
Why can't a Haier chest freezer be put in garage?
The only problem that you might have is with the coils and the flux capacitor. If you clean the coils, it should be fine.
Dec 18, 2011 | Haier Freezers
Hi we have recently moved to a house an we have inherited a fairly new whirlpool chest freezer which works very well but there is a lot of condensation on the outside which results in small pools of water...
The insulation between the inside and the outside of the freezer haas become water logged, This can be twmporarilly remedied by switching off the freezer and letting the insulation dry out for a few weeks, less in hot dry climates, but the solution is temporary and the problem will reoccur. To have the foam replaced means a complete strip down of the freezer and is seldom worth the cost. I am sorry, but you will probably have to get used to living with the problem. Incidently, it does make inroads into your electricity bills.
Jan 16, 2011 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
Whirlpool Chest freezer problem, Wet all over on the outside, kept in a shed outside could this be the problem. The freezer works fine, but is constantly dripping, and there is still frost inside, where is...
Sorry to read about your problem, I hope this helps you out.
yes.. condensation issue
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
Water is dripping from bottom of chest freezer, also some condensation on side,
dear sir/madam
i think yor freezer.s inside insulation has been damage or warn out so please contcet to your freezer maintenance personnel for replace it .
hope answer the question
thank you
please vote!
Jul 12, 2010 | Whirlpool 10 cu. ft. / 283 liter Chest...
Frigidaire uprite freezer won't cool
it's scrap
they use steel lines inside the cabinet and when you unplugged it the lines rusted through
Jul 30, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Problem with Maytag Chest Freezer model MQC1557aew.
First make sure than the condensing coil in the freezer is clean of dust and dirt(it is behind the grill vent in the bottom side of the freezer where the compresor is) If it is clough brush the dirt off after you unplugit.When is clean wait a few minutes ,5, and plugg it back at the GFI outlet and see if work If still tripped the outlet you may have to replace it.
Apr 04, 2009 | Maytag 14.8 cu. ft. / 419 liter Chest...
FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Mar 10, 2009 | Danby 5.5 cu. ft. / 156 liter Chest...
Can a chest freezer be put in an unheated garage?
Jan 20, 2009 | Haier Chest Freezer HNCM070E
Freezers Logo
112 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
