Question about Saeco Titan GT1 Burr Grinder
Is my saeco titan coffe grinder clock switch broken?
Hi, I think I foreced the knob on my grinder or turned it the wrong way. Since, the time seems to stay on all the time until I unplug it. I think I broke the cleock switch. Can anyone tell me if that is the problem and where i can find a part to replace it? Thanks! Julie
  • 2039 Answers
SOURCE: saeco vienna superautomatica
oily coffee residue on the grinder prevent the bean from going down be carefull push coffee down in the grinder with anything except our finger by forcing coffee down will making expresso it should grind if it does remove the coffee cointainer little star screw driver after removing the container inside the grinder where the coffee go down you gonna see a steel piece the coffee goes down the slot remove the old coffee residue on that part clean it good with a tooth brusch or somrthing like that put back without old coffee stuck on the grinder you gonna see the coffee gonna go down in the feeder cheers and if it help you dont forget to rate this cheers
Posted on Jan 23, 2008
mirran
  • 515 Answers
SOURCE: SAECO Incanto Rondo espresso machine
I think you have to take it to a Saeco service center, they have to upgrade your power board in the machine.
Posted on Jul 22, 2008
SOURCE: Manual for Saeco Vienna Super Automatica machine
Here is a link to the manual
www.powner.name/vienna.pdf
Posted on Jan 04, 2009
  • 1089 Answers
SOURCE: Grinder settings for Vienna Deluxe
Hi
To start off with, you should not change the big knob unless the grinder is operating at the time.
Set the small knob to the middle position. You can move this any time. Move towards the + mark to strengthen the coffee, but never all the way to the full +.
Set the big knob to the #8 to start off with. Move it 1 # smaller to make the coffee stronger but be careful not to get it to fine as you will clog the grinder and you will have to take it apart to clean. If you ever get an out of beans light, but there are beans in the hopper, open the knob to #16 for 1 cycle, then turn it back down to a # 1 larger than you had before and leave it unless you get the message again. Shiny beans call for a coarser grind than a dull bean because of the oils in the coffee bean. Oils will cause the grinds to stick together and cause clogs faster than beans that have less oil.
Posted on Jul 16, 2009
EsWorld
  • 1618 Answers
SOURCE: Hi i have a grinder problem with my Saeco Odea Go
Try this remove all the beans using a vac cleaner, then turn to lowest-finest number, then remove screws on grinder lift chamber and turn knob to coarsest setting and reassemble and try machine, remember to adjust grind when machine is grinding.
Posted on Sep 17, 2009
Hi, can you adjust the portion size of beans ground per cup for a saeco rotel conforta automatic espresso machine. The coffew is coming out fine, but too weak.
In the waste basket you got a nice round coffee puck i think you need to ajust the grinder its not chopping fine enough press for a coffee and put the dial down 1 like if your at 6 put 5 remmember the coffe you grind will take 2 coffe to reach try a couple and if your satisfied good if not go down on more try again
Mar 29, 2015 | Saeco Coffee Makers & Espresso Machines
My coffe comes out too watery. the grinder is set at max (fine grid) is there another setting for the water? or to maximize coffee grinds?
Remove all the beans in the grinder chamber, then remove the screws and slowly lift the chamber about 1 inch high, then turn adjustment knob 3 numbers back and lower chamber making sure the gears on the bottom line up.
Feb 28, 2011 | Saeco Incanto Classic Espresso Machine
In my Saeco odeo go the the coffe that is discarded (pugs) is too wet and mushy.
make the coffe finer by adjusting the grinder this should help
Dec 04, 2009 | Saeco Odea Go
Sep 10, 2009 | Saeco Odea-Giro Espresso Machine
Hi
Jul 16, 2009 | Saeco Vienna De Luxe Espresso Machine
Grinder not working
Hi
First off the grinder motors are 110V DC not AC. I would say that your problem is in the micro switch for the doser box under the solenoid. It sounds like it might be stuck closed and that would by pass the grinder saying the the doser box is full and don't run the grinder. You may just need a new micro switch which is specialized.
Nov 07, 2008 | Saeco Royal Digital Plus Coffee...
Jul 22, 2008 | Saeco Incanto Rondo RS SBS Espresso...
Grinder says no coffee beans after grinding, why?
does it realease the grinded coffe beans in the dregdraw with out using it?
if that is the case it a very small electricboard on the grinder that has stoped working or the connecter has fallen of from it.
Jun 26, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Grinder problem
I think your micro switch in the machine has broken.
The spare part number on this switch is: NE05.038.
You can find it if you get the top off and look behind the bobbin.
Jan 02, 2008 | Saeco Vienna Espresso Machine
Saeco Titan GT1 Burr Grinder Logo
54 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
