Question about Pioneer DEH-1800 CD Player
Where can i find the auxila
I want to connect ipod
I want to connect my ipod to the radio
According to Apple, over 90 percent of new cars retailed in the United States are equipped with iPod connectivity.
The iPod has become such a popular device, that many car stereos are now furnished with a 30-pin dock connector cable in order to link to the portable media player.
But this built-in compatibility is not essential for connecting your iPod to your car stereo. In fact, there are numerous options for integrating your iPod with your car.
Recently manufactured vehicles can support an iPod connection through an auxiliary input.
And FM transmitters can be used to stream your iPod's audio files through an FM frequency. iPods can even be connected to much older car stereos with the use of a tape adapter.
Connect an iPod to a Car Stereo Through the Auxiliary Input
Insert an extension cable with 3.5 mm stereo connectors on each end into the headphone output of your iPod. Insert the other end of the 3.5 mm stereo connector cable into your car stereo system's auxiliary input. Press the "Aux" button on your car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With an FM Transmitter Insert the FM transmitter into the 30-pin dock connector of your iPod. Turn on your iPod to activate the FM transmitter. Select the FM frequency you want your device to stream audio to on your car stereo. Turn on the car stereo and tune it to the same FM frequency as the FM transmitter attached to your iPod. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With a Cassette Adapter Plug the jack connector of the cassette adapter into the headphone output of your iPod. Insert the cassette into the car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod.
http://www.apple.com/ipod/car-integration/ http://www.pcmag.com/article2/0,2817,1865467,00.asp
Feb 10, 2013 | Apple iPod Audio Players & Recorders
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
Tip
How to connect an iPod to a TV
<p>The iPod is a very capable media player personal, but sometimes that tiny screen just does not cut it. Fortunately for owners of iPod, Apple allows users to connect their devices to a TV, so that the videos from your iPod to transmit to the screen. For this connection, iPod owners to buy an extra TV out cable, which is sold in most electronic stores. <br /> <p><br /> <p>1. Buy a cable TV output compatible. Apple sells three TV-out cables, iPod composite cable, composite cable Apple and the Apple Component Cable. See the References section for an iPod TV out cable compatibility list to ensure that you have purchased the correct cable. <br /> <p><br /> <p>2. Connect your iPod to TV out cable TV. Depending on the output cable TV you bought, the cable connects the input of the composite or component input on your TV. Each entry is color coded to the appropriate plug-ins to handle. <br /> <p><br /> <p>3. Connect the other end of the cable to your iPod. The cable consists iPod is connected to the headset connector iPod, Apple, while the other two-plug cables into the wall socket. <br /> <p><br /> <p>4. Turn off the TV mode on your iPod through the opening of "Video Settings" from the "Videos" menu on your iPod and change "TV Out" to "On." <br />
Ipod is disabled and cannot connect to itunes as have new laptop
How to restore iPod
  1. Verify that you have an active Internet connection, because you may need to download new versions of the iTunes and iPod Software.
  2. Download and install the latest version of iTunes if necessary.
  3. Open iTunes. Connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel. You will see information about your iPod appear in the Summary tab of the main iTunes window.
  6. Click Restore.
  7. If you are using a Mac, you will be asked to enter an administrator's name and password.
  8. A progress bar will appear on the computer screen, indicating that stage one of the restore process has begun. When this stage is done, iTunes will present one of two messages with instructions specific to the iPod model you are restoring.
    • Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During stage two of the restore process, the iPod displays an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remain connected to the computer or iPod power adapter during this stage.
    Note: The progress bar may be difficult to see, because the backlight on the iPod display may be off.
  10. After stage two of the restore process is complete, the iTunes Setup Assistant window will appear. It will ask you to name your iPod and choose your syncing preferences, as it did when you connected your iPod for the first time.
Apr 02, 2011 | Apple iPod touch
How to I use the stock radio amp to run an ipod?
You can use any of the following methods
  1. Connecting the iPod via headphone jack
    All you need is a simple Y cable, which is available from any home-electronics store. Connect the small plug to the headphone output of your iPod--or any portable audio player. Then connect the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox.
  2. Connecting the iPod via iPod dock
    To connect using the iPod dock, you first need to purchase an iPod dock accessory. Using the same type of Y cable, connect the small plug to the matching jack on the rear of the iPod dock. Then, plug the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox. This method provides a line-level connection that maintains a volume level to your stereo system and allows the iPod to recharge.
  3. Connecting the iPod via wireless FM transmitter
    You can also connect your iPod to your stereo wirelessly. You'll need to purchase a compatible wireless FM transmitter--there are several available--and connect it your iPod. Once your transmitter is connected, simply tune any nearby radio to the correct frequency, and you'll be listening to your own iPod-powered mini radio station.
Thanks for using Fixya
Proton
Sep 07, 2010 | Yamaha Royal Star XVZ 1300 A Motorcycles
Tip
How to make a connection to an iPod and Sony SS2300
<p>The SS2300 is a Sony digital surround sound system with a Blu-ray player. This gives you the ability to play high-definition video, while experiencing the content in full surround sound audio. However, the speaker system audio inputs, so you can connect external devices, including Apple iPods. Although no direct connection to iPod, you can use a single cable to the signal from the iPod surround sound system. <br /> <p><br /> <p>1. Insert the end of 3.5 mm to 3.5 mm to RCA splitter in the headphone port on top of Apple's iPod. <br /> <p><br /> <p>2. Connect the RCA cables into one of the "Audio In" ports on the back of the Sony SS2300. Multiple connections exist and you better take note of the connection you use. This makes it easier later on if the connection to the iPod. <br /> <p><br /> <p>3. Power on the Apple iPod and Sony SS2300 receiver. Press the "Input" and select the connection to the iPod is connected. <br /> <p><br /> <p>4. Press the "Play" button on the iPod and play audio content through the Sony surround sound system. <br />
Tip
How to connect an iPod to my Bose Radio
<p>The manufacturer offers two radios Bose iPod connection kit to connect an iPod to the radio. You can purchase the kit to connect the wave or acoustic wave connect kit. Both kits come with a USB audio connection, an iPod dock for iPod, a battery that plugs into the wall and a remote control to use the iPod while in dock. Download all the upgrades to your iPod through Apple's website before connecting a Bose radio. <br /> <p><br /> <p>1. Connect one end of the audio cable is included with the connection kit for iPod "Aux In" on the back of the Bose radio. <br /> <p><br /> <p>2. Connect the other end of the audio cable to the "Audio Out" on the back of the iPod dock. <br /> <p><br /> <p>3. Connect the adapter to an outlet connection kit. Connect the other end of the battery to the "DC Power" on the back of the iPod dock. <br /> <p><br /> <p>4. Set the iPod dock on the right side of the face of Bose radio out. Align the IR sensor on the front of the iPod dock with the IR sensor on the front of the Bose radio. <br /> <p><br /> <p>5. Place the iPod firmly in iPod dock. Point the remote at the IR sensor, iPod dock. Press the "iPod" for the iPod <br />
Dnx7100 ipod problem
The USB source is not for Ipods, from what I understand. The Ipod needs to be connected with the Ipod cable, $50 or so. I think it is a high speed connection.
Jul 07, 2008 | Kenwood DNX7100 Car Video Player
Ipod not getting connected to itunes nor getting charged, and please recommend which ipod converter to download. Thank you in advance my ipod is not charged, when connected to a computer
hello!
if your IPod touch is not connected to itunes, please try the ff:
Check the iPod touch Display
-- When you connect iPod touch to your computer, the iPod touch should display an image or message on the display
-- If you do not see any image, check some basic troubleshooting here: http://support.apple.com/kb/HT1737
-- If you see a message on the screen, this indicates that the iPod touch does not have sufficient battery charge to operate and will need to be charged for several minutes before it can be recognized in iTunes.
Verify Windows PC System Requirements
--iPod touch requires iTunes 7.4 or later
Check USB Connections
-- iPod touch requires USB 2.0 to function properly
-- Try connecting iPod touch to a different USB port, preferably a port that is built-in to the computer instead of an external USB hub. Connecting iPod touch to your keyboard's USB ports is not recommended.
Restart your PC
-- In some cases, your computer's USB ports may become temporarily disabled or you may experience other software related issues. Restarting your PC is an easy troubleshooting step that may resolve this issue.
Verify iPod touch Driver/Service Installation
-- iPod touch requires two important pieces of software to operate properly on Windows. First, the driver must be installed; for iPod touch the driver is USBAAPL.SYS. Second, Apple Mobile Device Support must be installed as a Windows Service.
May 08, 2008 | Apple iPod touch
My ipod will not charge on the docking station
my ipod wont charge. it shows the charging icon, but when i take it off the charger it dies like it didnt charge at all
May 05, 2008 | Audio Players & Recorders
Pioneer DEH-1800 CD Player Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
