Question about Electrical Supplies
Alarm # 194 site wiring fault - Electrical Supplies
Site wiring fault
Hi Viqtah, (<------ Clever!!)
If you hit the ESC key and get to the main menu there is a Setup submenu. In there you can change the line voltage values coming into the UPS. Sometimes a previous owner will change those values and cause the UPS to fault when properly connected. NOTE: A CERTIFIED ELECTRICIAN SHOULD VERIFY ALL CONNECTIONS ENSURE PROPER PHASE ROTATION.
Reply or call if you have any more questions -- 800.260.2259
Oct 04, 2013 | APC Smart-UPS VT 10kVA - SUVT10KH2B2S UPS...
Random misfire p0300
You have to do tune up,wires, sparks plugs,coils.vacuum leak.
May 06, 2013 | Cars & Trucks
Eaton UPS error code 194
how to solve this problem ???
error displayed on screen = alarm # 194
Jun 25, 2012 | Eaton Evolution S Exb 25003000 Rt2u...
What are the Standard diameter for Razor Wire?
· 0.450m Welded Razor Diamond Mesh 6m
· 1.200m Welded Razor Diamond Mesh 6m
· 1.800m Welded Razor Diamond Mesh 6m
· 2.100m Welded Razor Diamond Mesh 6m
· 2.400m Welded Razor Diamond Mesh 6m
Jun 22, 2011 | Razor MX350 DIRT ROCKET - BLUE
What does e 62 error code refer to?
E62: Overheating during washing this is real ans now iam giving u more tips abt error -
E11: Difficulty in filling during wash phase
E13: Water leakage.
E21: Difficulties in draining .
E23: Malfunction of drain pump triac.
E24: «sensing» circuit of the component (triac) that controls the drain pump faulty
E33: Incongruence between closure of anti-boiling and 1st level contacts of pressure switch
E35: Water level too high
E36: «sensing» circuit of anti-boiling pressure switch faulty
E37: «sensing» circuit of 1st level pressure switch faulty
E39: "HV" «sensing» circuit of anti-overflow pressure switch faulty
E40: Door open, Interlock, wiring or main PCB
E41: Door open
E41: Problems with aperture of door
E42: Problems with aperture of the door
E43: Problems with the triac which actions the door interlock
E44: Door closure «sensing» circuit faulty
E45: Problems with the «sensing» circuit of the triac that actions the door interlock
E51: Motor power triac short-circuited
E52: No signal from the motor tachymetric genetaror
E52: No signal from the tachymetric generator
Procedure for checking commutator motors
E53: Problems with the «sensing» circuit of the triac which powers the motor
E54: Motor relay contacts sticking
E61: Insufficient heating during washing
E66: The contacts of the heating element power relay are always closed
E71: NTC washing sensor faulty.
E82: Error in reading the RESET/OFF position of the programme selector.
E83: Error in reading the programme selector code
E93: Incorrect machine configuration.
E94: Incorrect configuration of washing cycle
E95: Communications error between microprocessor and the EEPROM
E96: Incongruence between control panel version and configuration data
E97: Incongruence between selector version and configuration data
EA1: Drum positioning system (DSP) faulty (top-loaders only)
EB1: Incorrect mains frequency
EB2: Mains voltage too high
EB3: Mains voltage too low
E32 INCORRECT CALIBRATION OF ANALOGIC (ELECTRONIC) PRESSURE SWITCH. IF THE MACHINE IS DRAINING OK, THEN IT IS THE SWITCH
E32 relates to the electronic pressure switch, normal pressure switch,inlet valves,poor water mains pressure and finally the main control board
E90 means theres a fault on the main control module so A;will need a new control module or B; get an engineer to try re-configureing the module
May 16, 2011 | Hoover Washing Machines
Specifications only
CPU º Socket 478 for latest Intel Pentium 4 / Celeron processor
º FSB 533/400 MHz
º Support Hyper-Threading Technology CPU
CHIPSET º VIA® P4M266A & VT8235
º North Bridge: VIA® P4M266A
º South Bridge: VIA® VT8235
GRAPHICS º Integrated S3 ProSavage8 2D/3D Graphics
º Share Memory : 8/16/32MB
MEMORY º 2 x 184-pin DDR DIMM socket support up to 2 GB
º Support DDR266/200 DDR SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS.
For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
EXPANSION SLOT º 1 x AGP 4X slot
º 3 x PCI slots
º 1 x CNR slot
STORAGE º Support by VIA® VT8235
• 4 x Ultra DMA133/100/66 devices
AUDIO º Realtek ALC655 6-Channel audio CODEC
º Compliant with AC'97 2.3 specification
LAN º VIA® VT6103 10/100 Mbps Fast Ethernet PHY
REAR PANEL I/O º 1 x PS/2 keyboard & PS/2 mouse connectors
º 4 x USB ports
º 1 x RJ45 LAN connector
º 1 x VGA port
º 1 x Parallel port (LPT)
º 1 x Serial port (COM1)
º 1 x Audio port (Line-in, Line-out, Mic-in)
INTERNAL I/O CONNECTORS & HEADERS º 1 x 20-pin ATX Power Supply Connector & 4-pin 12V Connector
º 1 x FDD connector supports one 360K~2.88MB FDD
º 2 x IDE connectors
º 1 x IrDA for SIR header
º 1 x SPDIF out header
º 1 x USB 2.0 header support additional 2 USB ports
º 1 x Front panel switch/LED header
º 1 x Front panel audio header
º CD in/ AUX in headers
º CPUFAN/CASFAN connectors
SYSTEM BIOS º Award BIOS with 2Mb Flash ROM
º Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
º Supports ACPI revision 1.0 specification
FORM FACTOR & LAYERS º Micro-ATX Size (244mm*244mm), 4 Layers
for more detail look at this site
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=436&CategoryID=1&MenuID=18&LanID=19
i hope this helpful
thank you for using fixya
Feb 06, 2011 | EliteGroup P4VMM2 V8.1 Motherboard
Asko w6 222 has a F1 error. how do I fix it. thanks Rose
Hello Rose, here is a chart to help you identify what the problem is with your asko
Failure
Code
Condition Check/Repair F1 Water supply/low water fill · Check water supply to machine
·Replace water inlet valve F2 Water level too high · Plugged/Bad water pump
· Faulty water valve F3 Pump problem Check pump trap and clean. F4 Thermistor problem · Open thermistor, replace
· Bad wiring to thermistor F5 Fault in thermal cutout or heating pause fault. Selected temperature not reached in 90 minutes · Check heating element
· Check thermostat F6 Motor fault · Check wiring to motor
· Replace motor if necessary F7 Door lock release fault · Bent pull-rod for door latch
· Bad door latch solenoid 00 00 Machine did not spin Check load for out of balance Redistribute load and restart
usually this means the water valve that the hoses are connecting into the machine has gone bad and needs to be replaced if your looking to order the part online i would suggest marcone appliance parts they seem to be the cheapest when it comes to repair parts and they are also one of the biggest I hope this opinion has helped in your appliacne situation and if i can answer any further questions please message me back. Please also remember to rank how this opinion has helped in your appliance situation
Thanks again
Rick
Nov 28, 2010 | Washing Machines
Tone alarm goes off and flashes "overload" and on the back "building wireing fault" is lit up
The "Overload" light and alarm is to tell you that the devices connected to the UPS are drawing more current than the UPS can safely provide with battery backup. You should disconnect a few items, and the alarm and overload light will turn off. The "Building wiring fault" light on the back is to tell you that there's no proper ground wire inside the wall outlet that you're using. These two problems are not related to each other.
Mar 04, 2010 | APC Back-UPSĀ® XS 900 (BX900R) UPS System
What does wiring fault light mean?
The Site Wiring Fault LED will indicate three status:
• Led On: The site wiring fault function is enabled and a site wiring fault is present.
• Led Off: The site wiring fault function is disabled.
• Led Flash: The Site wiring fault function is enabled and there is no site wiring fault.
When the input power is normal the Site wiring fault LED will flash.
• To disable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
• To enable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
Is the wiring fault light indicator lit? This means that the outlet that the unit is connected to is either not properly grounded, or has reversed wiring. First, try connecting the unit to another outlet. If the unit does not display the wiring fault light in the new outlet you will need to have an electrician correct the problem with the other faulty outlet.If it still displays the wiring fault more troubleshooting will be necessary to determine the cause
Feb 09, 2010 | CyberPower 725SL UPS System
Wiring up car alarm for nissan pulsar n15 1999
No mention of which model of alarm you are going to install???
so heres some sets to concider,,,,,
That makes it interesting.lol
sounds like the wiring loom is transposed,
wiring around the wrong way.
Go to each of the motors that drive the central locking,
visually site the colours and where they are connected ,
get a multimeter and test the output from alarm to each of the motors ,
Arm/disarm each motor as you remove each cover.
this will elliminate each area and rule out as a possible fault,
Have you changed the battery on your remotes lately???
Hope this helps....
Jul 27, 2008 | Home Security
Electrical Supplies Logo
56 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
