Question about Panasonic NIL70SR Cordless Steam Iron
Once I select the temp. (Low/Med/High) it blinks for awhile as if it's setting. Then it jumps back to the on/off button and just blinks. Will not heat at all.
I have tried unplugging and replugging, cleaning, inspecting and plugging into different outlets.
    Master:
  • Panasonic Master
  • 996 Answers
Temp.adjustment electronic circuit plate defective,change by expert professional
Posted on Jan 21, 2015
How do i increase the iron heating temperature (thermostat) in Panasonic Electric Iron NI-22AWJ
Check the voltage at your power point, irons draw a lot of power. most irons have a temp setting switch cool med hot . If this a new iron return for service.
Feb 18, 2015 | Panasonic Irons
Shark iron g1462
the lights you witness are correct. once the iron has reached tempreture.
ensure the iron is stored in an upright position between ironing items if left laying down the iron may switch off as an anti-burn or fire safety feature as if left unattended. with the iron placed on its back plate with its point facing upwards the iron should stay on.
I hope this was useful.
May 14, 2014 | Irons
BRIJ 35 Solution (25-30%) Tween 20 Water, Deionized/Distilled are Ancillary (ELISA)
cant get steam to come out of my steam press the temp is high I keep pressing the steam button water at max lid up brand new please help thank you
Sep 03, 2013 | Irons
My iron temp cuts off and only stays at a low temp even thou it is at it highest settings regards Mike
It is possible that the BIMETTALIC cut off is OFF set and so the cut off happens vry early .
You might need to remove the unit and get access to see if this can be set to higher level- tighter- so that the bimetal takes more heat to cut off. This will provide you a higher heat.
You can calibrate using the highest/lowest settings.
Aug 08, 2011 | Philips GC 148 Iron
Security auto stop light is on and iron wont heat up
Ur thermostat has been jammedat low heat. fix it to high temp.
Aug 08, 2009 | Irons
Blinks and doesn't heat.
Could be a loose connection or a damaged cable. Try gently moving the cable and see if it starts to blink etc?
How old is it? Is it still in warranty Guarantee? If it is, take it back to where you bought it from and they should repair it or replace it.
Failing that you may have to buy a new one. Wallmart or similar have cheap electrical appliances
Aug 03, 2009 | Irons
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Mar 21, 2009 | Rowenta Powerglide DE013 Iron
HINARI LIFESTYLE STEAM PRESS
The RED button is located on the pull down handle.
Sep 22, 2007 | Irons
Burst of Steam
if no steam at all, there is most likely a small port where some particles have clogged...fill it with vinegar and water (50/50) and allow to soak 24 hrs, then reheat then shake vigorously to drain then rinse then retry
May 23, 2007 | Conair DPP4000 Iron
Iron whuts off
check the circuit at the switch it could ave faulty cap that is not regulating the voltage properly.replace it.good luck
Apr 11, 2007 | Sunbeam 4237 / 4238 Iron with Auto...
Panasonic NIL70SR Cordless Steam Iron Logo
136 people viewed this question
Top Panasonic Irons Experts
Jim Goldsmith
Jim Goldsmith
Bill Boyd
Rani wadia
Rani wadia
Are you a Panasonic Iron Expert? Answer questions, earn points and help others
