Question about Eaton Powerware 9130 UPS Battery
And my ups not accept A.C power - Eaton Powerware 9130 UPS Battery
  • 9,587 Answers
Look at the fuse for the inlet power. It may be bad. There is a transfer relay inside that may not be switching correctly.
Posted on Nov 19, 2014
Testimonial: "ok thannx"
My I pad shows software update ios9.2.1.& when I click install it says it's unavailable. I can't seem to get rid it and can't use it like I normally do. What do I do?
whenever you accept a software update from Apple, always do this.
Put device on charge. Must be over 50% to accept.
Backup to iCloud or computer.
Power down, count to 10 and Power back up.
Take the Update.
Doing this protects your data and frees up all the memory to allow the update to make full use of it.
Jan 23, 2016 | Computers & Internet
Hard reset zte n817
1: Power off phone
2: Hold volume DOWN (not up) and POWER BUTTON simultaneously until ZTE logo appears
3: With volume keys scroll down to wipe data/Factory reset press POWER button to accept
4: Scroll down to YES press POWER button to accept
5: Press POWER button on Reboot Phone and phone should restart like right out of the box
Many forums say volume up and power button but that is only for FTM mode on ZTE N817. So remember VOLUME DOWN AND POWER takes you to screen where u can choose to reset etc.
Dec 06, 2015 | ZTE Cell Phones
Usb is not showing up on source
some tvs require a drive that has its own stand alone power source, & a compatible file system, not all will accept NTFS, Fat32 will only hold files under 4gb try EXFat, or check your manual for what usb devices it accepts, most older tvs wont accept a stick, need external hdd with power.
May 09, 2015 | Alba LDVD1538WDCH LCD TV
How to reset zh&k mobibe
1.Turn-Off Phone
2.Hold and Press Volume up and Power Button
3.Select Recovery using volume up and accept it by pressing Volume Down.
4.Click Power button twice to go to Android System Recovery
5.Use Volume Down to Select wipe data/factory reset,Volume to accept.
6.Select Yes-delete all user data,again click volume up
7.After Format,Reboot System.
8.Wait Until Powered on,And you can now use phone back to normal.
Jan 01, 2015 | Computers & Internet
My smart ups 3000ux is not on in ac power , ups is working in dc power. so what is problem.
most probably it can be an issue with your incoming supply check if it it within the accepted range check your power cable inside the ups check if there are any open cct
Aug 11, 2013 | APC Smart-UPS 1000VA UPS System
Red light blinking won't accept tape
If a tape "hung" up and it won't accept one you have a loading issue.
The unit may use a belt to drive the tray or a geared mechanism.
In any case someone needs to open the unit up to "see" what is happening. Most of these a tape can be inserted with power off and manually cycled into the unit to see the issue---we usually use a old cassette with the tape inside removed to avoid issues.
If you cannot do that consider looking for a shop who will (some no longer work on this type of equipment.)
Dec 05, 2012 | JVC BR-DV3000U DV/Mini DV VCR
4 beeping sound every 20 seconds, even when there is no gadget attached to it.
This alarm indicates that the UPS has transferred from On Line operation to On Battery operation. The Battery Power Supplied outlets are now battery powered.
- If the input voltage is determined to be unsafe for your computer equipment, the UPS will transfer to On Battery. The alarm will stop once the unit returns to On Line operation. Please refer to the technical specification section of your user manual for the acceptable voltage window. Occasional transfers to On Battery should not be a matter of concern, but rather, should be considered normal operation. The UPS is trying to provide clean, safe, and reliable power. If your unit shipped with APC management software it may be possible to change the default acceptable voltages that the unit shipped with. Please see the help section of the APC management software for instruction to do this.
- If the Frequency deviates + or - 5 % this will also cause a Back-UPS product to transfer to battery power. Frequency distortions are most commonly caused by generators that are undersized. Always make sure a generator is 3 to 5 times the size of the total load attached to unsure it can maintain a steady output frequency. There is no way to change the +/- 5% deviation.
- If the shape of the incoming power is considered "too dirty", some Back-UPS products may transfer to battery power. This is most likely the problem if you have already confirmed that the input voltage is within the acceptable limits. Most Back-UPS products have the ability to change their sensitivity to the shape of the input power from high to medium or even low. Please see your user manual for details as to how to adjust this setting.
Jun 27, 2011 | APC Computers & Internet
Power supply issues, wont charge.
Dear,
This is isse with your power adaptor. Its not having the capacity to light up the scree while working. But it is having the capacity to charge you battery. You have to replace your power adaptor
Oct 13, 2009 | Toshiba Satellite P205D-S7479 Notebook
Samsung 4010 camera wont accept a 4g sd card
The camera will only accept true SD cards i.e. up to 2Gb. Your 4Gb card will be an SDHC which is not compatible. See here http://en.wikipedia.org/wiki/Sd_card#Compatibility_issues_with_2_GB_and_larger_cards for further explanation.
Feb 03, 2009 | Samsung Digimax 4010 Digital Camera
Eaton Powerware 9130 UPS Battery Logo
747 people viewed this question
Top Eaton Computers & Internet Experts
Lawrence Oravetz
Vuk B
Are you an Eaton Computer and Internet Expert? Answer questions, earn points and help others
