Question about Tablets & eReaders
Ipad 1st generation showing a 'not charging' notice beside the battery icon when first plugged in at mains. I can usually resolve this after a few tries of pulling out the usb cable from the plug & placing it back in. But on occasion now I will get no change in battery percentage while it's 'supposedly ' charging. Could this be a faulty usb cable or the plug..or is it the device itself? The iPad works just fine while not on charge so I'm confused.
  • Tablets & eR... Master
  • 3,320 Answers
The connector on the iipod is damaged.
Posted on Nov 20, 2014
SOURCE: how do I charge the iPad battery.
USB hubs typically don't generate the 10 watts necessary to charge an iPad when it's connected to your computer. This basically means you can't use your laptop to recharge your iPad.
Apple recommends finding an AC outlet and using 10-watt power adapter that came with your iPad.
Posted on Jan 08, 2012
charles0285
  • 160 Answers
SOURCE: my ipad wont charge , icon shows it's charging but it not ?
To get Ipad to show as charging download Asus AiCharger from web and restart computer after install.Plug in usb from Ipad and should now show charging http://event.asus.com/mb/2010/ai_charger/
Posted on Nov 02, 2012
charles0285
  • 160 Answers
SOURCE: Can't charge the ipad from the USB charger
Please Rate
charles0285
  • 160 Answers
SOURCE: Unable to access some apps installed on my iPad because no icon shows up on the iPad for these apps
When you exceed your allowed pages for apps,they will still install,but app cannot be created for lack of pages.You can get more room by grouping similar apps into 1 folder to make space.You can also use search function to fill any app installed.Scroll all pages to right until keyboard appears,then type name of app,it will appear in dropdown list.
Please Rate
Posted on Nov 05, 2012
chassharp19
  • 24 Answers
SOURCE: How do i change the battery on a ipad generation 3
You have to remove the digitizer with a heat gun then remove the LCD disconnect all ribbon cables from mainboard remove mainboard to disconnect the three batteries. 2_3_2014_8_45_18_am.png
Posted on Feb 03, 2014
Benefits of apple iPad over any PC and Laptop?
The main benefit of an iPad is that you will have a device that it light weight and portable. Usually has a longer battery life and can get apps. The downside of an iPad is that it will not replace a laptop. iPads are a great addition to your current set up but there will be times when you will need the power of a laptop. Example would be if your iPad acts up, you may need to plug it into a computer with iTunes on it to restore the software. If you really just plan on surfing the web then an iPad is great but if you will need to do more work related things, it may be best to get a laptop 1st.
Apr 04, 2017 | Apple iPad Tablets & eReaders
My 2013 kindle fire HD 7 3rd generation screen is black and there is no reset hole.
Not many buttons to control it but you might hold down the on button for a long time while the charger is connected.
Nov 27, 2015 | Tablets & eReaders
My first generation iPad appears to be totally dead. When I plug it into charge all I see is the flashing Apple. Is there a way to get the system going again ?
The battery in it has most likely expired and may cost more than a new iPad to replace. A voltmeter across the charger or a friends iPad may be useful to test your charger works ok.
Oct 11, 2015 | Apple Tablets & eReaders
My Apple iPad 4th Generation will not charge when plugged in. What should I do?
My ipad has done this twice. Both times it has been due to the battery going totally dead and a bad charger cord. Take it to a radio shack or to someone and have them to use one of there chargers wait a few mins. See if it begins to show any signs of taking a charge at all. It may take 20 mins. or so. If it doesnt then you will more than likely have to replace the battery inside the ipad. There have been some ipad batteries that havent lasted very long. Good luck and I hope this helps you.
Jul 20, 2014 | Apple iPad 4th generation
Ipad will not start?!
There are a few things to try. 1) Press the power button and the home button (on the front) at the same time. If that doesn't work 2) try plugging it into a different charger than you normally use. If that works, you need a new charger. If it doesn't show that it's charging within 30 seconds, your iPad charging port or battery probably has a problem and will need repaired.
Jun 25, 2014 | Apple iPad 32 GB WiFi Tablet PC
My ipad wont charge , icon shows it's charging but it not ?
Oct 12, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Forgtton unlock code on ipad2
hard reset the device
OK, you have noticed the strange behavior of your iPad / iPad 2 or even new iPad 3. It tends to freeze for about a few seconds every minute or is running too slow or something else. This is probably the best time for the hard reset of the tablet. To make things easy follow simple sequence:
  1. Make sure your iPad /iPad 2 / iPad 3 battery is charged above 20% (we would recommend at least 50 - 60 %). If you are not sure charge you tablet for at least 40 minutes.
  2. Make sure your Apple tablet is in Power On state.
  3. Watching the shining screen of iconic tablet with apps' icons on it press and hold down the Wake/Sleep and the Home buttons simultaneously, ignore the red slide "to power off", just keep both buttons holding until the Apple logo appears. This logo is the signal that the hard reset has succeeded. Be patient, some times the hard restart of iPad may take up to 10 - 15 minutes. But such a long restart is a rare case.
Be sure that hard reset retains all data and settings on iPad, it doesn't delete anything. If you want to start over and delete all personal data from iPad you should use iPad Recovery Mode.
Jun 19, 2012 | Tablets & eReaders
How do I charge the iPad battery.
Jan 08, 2012 | Apple iPad2 WiFi 64GB
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
