We have two DL5000 with both codes missing and override keys locked in one of them. How can I get into the one with the keys without destroying it?
    Top Expert:
  • Televison & ... Master
  • 75,571 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Posted on Nov 19, 2014
How can I get the safe open? I have no key and I dont know the combination
With a carbon tipped drill bit. You'll have to drill the lock. This will destroy the safe. A good locksmith may be able to open it without destroying it. It's worth a try.
Jun 05, 2015 | Home Security
My child lock is on on my phillips 755vr dvd player how do i turn it off without the remote
Basically, the child lock feature is a security feature to keep the children away from unauthorized video content.
Your best bet is to get an original replacement remote.
You may try this general step to unlock without the Remote. However, it may not work for all the models.
Please hold down the Power button on the Player until "CHILD LOCK" or the "Key symbol" disappears from the front panel display. The Player will be unlocked.
If you had set a code number - the override code should be able to resolve the issue. Please follow the below steps to enter the override code.
1. Press SYSTEM MENU to display the Setup menu.
2. Use the Number buttons to enter the 6-digit number
"210499". The previous password will be cleared.
Hope this helps you in resolving the issue.
Thank You,
Ravi Yelde
Aug 18, 2014 | Televison & Video
2007 toyota corolla S is missing button above "P".
the button ,is not a button it is a cover for shift lock override if you need to to move the shiter without your foot on brake or without the key you push a key or pin in the hole so it can be shifted
Jan 21, 2013 | 2007 Toyota Corolla S
Kaba lock won't open with code
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Aug 18, 2012 | Simplex Kaba Ilco Unican 1011 keyless...
I dont have the keys for godrej taurus safe locker and i forgot the lock code
i dont have the keys for godrej taurus safe locker and i forgot the lock code
Feb 20, 2012 | Safe International Safelock Front Loading...
How to unlock the child lock without remote oc philips portable tv
No, I 'm afraid not my friend. Maybe you have a friend or someone you know who has a Philips or Magnavox remote control so you can unlock your set.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Jun 28, 2011 | Televison & Video
Its lock and i dont have the remote what to do help
Hello
Without its original remote control it is immpossibel to open its lock. Just try to get it from one for the same model amoung your relatives or from others, just to open the lock of your TV. If you can collect one, do the following with it.
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
OK.
Mar 26, 2011 | Apex Digital AT2002S 20" TV
I lost my sentry safe code! what can i do to program the safe! can i do it without the code? please help! thanks
Depending on model, some safes have a key override that can be used to open the safe. Most models do not. Without a key override, probably the only thing you can do is to contact a lock smith, otherwise, start checking each possible code combination until you find the correct code.
If there are valuables in the safe, then take it to a locksmith. Otherwise, it might be cheaper to get another safe.
Jul 14, 2010 | Sentry Fireproof Safe
Child lock on and do not know how to disengage
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the function or F button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
Apr 09, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Locked
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired. Good Luck
Oct 26, 2007 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
