Question about Sony Bdv-e500w 5.1-channel Blu-ray Disc Home Theater Receiver Only Hcd-e500w
When playing a disk, external speakers ok. When playing cable/TV, sound only from TV speakers. Any advise?
All connections ok.
    Habit-Forming:
  • 166 Answers
Maybe a faulty cable or the output socket of unit
Posted on Nov 26, 2014
2 Suggested Answers
SOURCE: no sound from Sony STR-DH500 when playing dvds with HDMI
no sound via hdmi cables, you must use optical or coaxial
Posted on Dec 18, 2009
I have a sony smary tv and when I start a movie the viedo is good but there is no audio what am I missing
The first thing I would do if there is any other way to check audio like head phones or aux out to stereo try, this may tell if you have a bad audio chord, not sure exactly how your set up is but a bad chord our improper jack connection might be the answear, good luck ! Bret
Mar 08, 2015 | Sony BRAVIA KDL60EX720 60 Inch 3D 1080p...
Connecting tv external speakers
If you connected R/W RCA cables to the AUDIO OUT RCA jacks on the rear of the TV and connected the other ends to the TV AUDIO IN jacks on the receiver, you should be able to select an input on the receiver that will deliver sound to the Bose speakers. If you went to TV setup and selected external speakers, you directed output from the TV amplifier to external speakers which is not what you want.
Jan 27, 2014 | Televison & Video
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
Dec 01, 2013 | Panasonic DMP-BDT220 DMP-BDT220
No sound playing dvd recorder or hard disk recording or freeview
It is possible as when the jack is used with a plug into it, it is designed to cut the sound to the speakers in the set.
Dec 05, 2012 | Panasonic Dmr-XW380 Dvd Recorder
Picture is fine but there is no volume however, volume comes on when I play a DVD
If sound when a DVD the set is ok.
Look:
Is sound turned down on set or muted and same for a cable or sat box if used for signal.
In menu are speakers turned off or on?
If set has hookup for external speakers is it switched to internal or external.
A setting in the set or the box used is causing this as the set is not smart enough to know when you are playing a DVD or just watching TV.
triple check all connections from box and in the set.
Apr 22, 2012 | Sylvania LC320SS8 32 in. LCD Television
I have just bought the samsung ht c555 home cinema kit connected it to the the tv all is working well when playing a5.1 dvd but ihave no sound out of the system when on ordinary tv how do you get all 5...
you will have to connect an audio output from the tv to the sourround reciver. you should have some audio output on the back of the tv and a corresponding input on the samsung ht c555
Dec 24, 2010 | Samsung Audio Players & Recorders
Hello, I have a very old mitsubishi color tv, model cs 2657r, which I purchased in the late 1980s. The picture is still great, and I'm trying to connect two small external speakers, though the internal...
Try stripping the speaker wires and exposing it about 1 inch. Then connect the speaker wires in a way that the part that grips or holds the wires touches the metal part and not the insulation. If there's still no sound, Please check the external speakers to see if it's working by using them in another device like a home system or audio player or maybe another tv that has an external speaker port. If not, mostly likely the switches are defective and needs replacement by a qualified technician.
Hope this helps.
Oct 25, 2010 | Mitsubishi CS-13103 TV
No sound when I play back using an external micropohone however when I play back on the TV full sound. Any solution?
Microphones are input devices; they don't double as speakers. If you mean that a stand-alone set of speakers do not work, but the internal speakers of the tv do let you hear the audio track from the camera. Then I have a couple of different suggestions: 1) make sure the stand-alone speakers work with other input sources, 2) try a different cable (make sure it is connected properly).
Also how are you connecting to the different devices? The video camera has an HDMI port which will send audio and video to the TV on one cable. If you are using the RCA audio in both cases, then I suspect a problem with the external speakers.
If you mean that the audio track is clear on play-back when you use the built-in microphone during the recording and not heard if the external microphone, check the external mic for problems. Try it on another recording device. I can't rule out a jack failure without more information.
I hope this helps.
Jun 03, 2010 | JVC Everio GZ-HD7 Camcorder
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
Open Questions:
See all Sony Bdv-e500w 5.1-channel Blu-ray Disc Home Questions
Sony Bdv-e500w 5.1-channel Blu-ray Disc Home Theater Receiver Only Hcd-e500w Logo
75 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
