Question about Whirlpool Washing Machines
My whirlpool Fully automatic washing machine is not functioning properly,what can I do to repair it?
My whirlpool Fully automatic washing machine is not functioning properly, it is not taking water from pipe,it"s wash and rinse function not working only spin function working . what can I do to repair it?
  • 720 Answers
Check to see if the machine has touched the on off tap at the back during spinning and cut off water supply.Or check the penny trap at the bottom of machine.if both are okay the it is likely to be down to faulty board or impeller motor which helps the flow of water into machine.
Posted on Nov 19, 2014
SOURCE: Washing Machine not draining
same thing happened to me but the obstruction was in the hose at the back of the filter and coudnt be seen in the filter. i paid 150euro to engineer to fix this. i watched him fix it and can do it myself now. they rob you for something that is so simple to fix.
Posted on Sep 26, 2007
  • 209 Answers
SOURCE: Inglis Washing Machine - Heavy Duty Extra Large Capacity
if it doesn't empty check the pump for blockages or just not working electrically, or check cold water supply to machine, or the cold water solenoid, this may also be faulty hope you can find what you need starting from the above, if i have helped please rate me
Posted on Oct 04, 2007
  • 213 Answers
SOURCE: whirlpool washing machine won't spin after rinse cycle
there is a coupling between the motor and transmission that has cracked. with the crack in the coupling the transmission cant spin as fast as the motor causeing the loud noise. replace coupling to solve problem
Posted on Nov 21, 2007
  • 96 Answers
SOURCE: does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Posted on Feb 17, 2008
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
Where is slot sensor located in whirlpool fully automatic top loading washing machine
Anuj,
If you lift up the top of your unit you will find the paper work and code sheet inside that will show you all you need to help you with your problem.
Feb 10, 2016 | Whirlpool Washing Machines
Machine will not spin or drain
good day?
fully automatic machine? washing cycle is normal?
if yes, do the same.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Whirlpool Washing Machines
0f17 error code what does it mean?
code 17 means you have low or no water pressure coming into the machine- check for water valve turned on fully- hose kinked off or water valve on machine not functioning properly-cheers Denny
Oct 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Fully automatic washing machine top loading model water is getting drained out automatically
Look at the height of the discharge hose. It must be run higher than the machine, or all water can run out.
Jun 08, 2011 | Whirlpool Washing Machines
Water supply hose(cold) blocker dont work
i am sameer from india... i want whirlpool fully automatic washing machine pcb circuit diagram
Jul 28, 2010 | Samsung Washing Machines
The agitator spins automatically(not the drum)when the power is switched on and stops only when power off in the top loading fully automatic whirlpool washing machine
If you saying that the machine agitates when ever it's plugged in. You will most likely have a bad timer. You will find that the points are welded together inside the timer
Nov 17, 2009 | Whirlpool Washing Machines
How to operate a whirlpool fl 5053 washing machine
Dear Sir,
How to operate fl5053-500 model whirlpool washing m/c (fully automatic),
pls forwad manual for mail id.
this is my mail id = rajan_raman@yahoo.com,
solution = a picture or video is helpful for as,
pls reply me on further information by mail.
thanks & regards ,
raman.
Nov 14, 2009 | Whirlpool Washing Machines
I hear some different noice along with slight vibration, when water filling in the washing machine. my washing machine model is Whirlpool F65 fully automatic one 2 one 2 wash. Its need any service?
Could the sound be described as a chatter / rapid clicking?
If so, it's probably the inlet valve for either the hot or cold water which is not opening all the way due to a dirty/malfunctioning solenoid valve.
Charlie
Aug 14, 2009 | Whirlpool Washing Machines
Washing Machines Logo
97 people viewed this question
Dan Webster
Dan Webster
Sal De
