Question about Ovens
The door on my Nobel model: Nr.: NF 60 SS/1 will not seal when closed.
Nr.: NF 60 SS/1 is the model number. The company has ceased to be in Australia
    Sergeant:
  • 244 Answers
Oven doors can warp over time. Also, if the door has a heat shield that covers the window and locks the door during self-cleaning it can become misaligned and prevent the door from closing properly. Minor alignment and adjustment can be done by loosening the screws on the hinges and taking advantage of the slots provided for positioning the door before re-tightening the screws however if the door is warped too much you may not have enough adjustment travel available to properly re-align the door. The metal gasket around the door may also have become damaged and is preventing a proper seal and you might be able to locate replacement gaskets at an appliance parts house.
Posted on Nov 20, 2014
I have a bassano oven and my door has smashed i am not sure where i can buy bassono parts in qld, thanks
I believe bassano is a type or model name and likely to be little or no use when trying to locate spare parts. You will need more details, including the name of the manufacturer and possibly the serial number as well as the model number.
Appliances, like cars, are often badge engineered - where similar models are produced by the same manufacturer with slight differences in specification but named differently because they are destined for different markets.
You should find manufacturer details in the instruction book or if that is absent an experienced white appliance engineer might recognise the parent company from sight.
If all else fails it should be possible to have a replacement glass door manufactured. A local glazing expert should be able to advise you. Such things aren't cheap but neither are replacement glass oven doors and a manufactured door could even be cheaper, but of course a manufactured replacement will not be painted.
Jun 27, 2016 | Ovens
How do you adjust door closed
Hello Chris;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number, Which is on a metal tag on the face of your oven when you open the oven door.
The only way you can align your door is to loosen the screws on the door hinges, position the door and while someone is holding the door in position tighten the hinge screws. The screw holes have some play in them.
May 23, 2015 | Ovens
Oven door on a Amica upright oven not closing completely. Where can I obtain door hinges for a Amica Oven..it is still under warranty, less than 24 months old. I have tried a few spare part places...no one...
they are Australian company, What country are you in? The wesite for them is www.cimbre.com.au. I would need to know where you are in order to help you. Also need the model number. Usually manufactures warranty expires after 1 year
May 22, 2011 | Ovens
Need door seals for sharp microwave oven model R-9330A
You can probably purchase the seal from RELIABLE PARTS (1-800-663-6060 ) with the model number from the microwave
Feb 05, 2011 | Sharp Ovens
I reinstalled the door of my kitchenaid gas oven/range but the door hinge won't go in the last 1/2 inch. The door is not sealed and doesn't close properly. I have tried pushing very hard at the hinges and...
Go to this site http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD
type in your model number (or at least one that is close) and look up the directions for removing and reinstalling the oven door. Sometimes you have to open the door fully after reinstalling to get the mechanism to work correctly.
Dec 22, 2010 | Ovens
Our oven is about six years old. It works well except that (1) the oven door seems to not close well so as to leave the light on inside, and (2) the digital display is totally out and does not display the...
Your oven door may have a defective hinge or simply is not aligned correctly. I am assuming the door, when shut, is NOT totally sealed around all four sides??? If the door is sealed around all four sides, than you have a switch that activates the light that is possibly defective. As for the electronic display, this display unit will have to be replaced.
Thank You,
Please accept
Jan 28, 2010 | Ovens
Kleenmaid Stainless Steel oven door will not close properly.
The door hinge is probaly broken or could just be the spring. Open the door to the 45 degree position (halfway) and pull on the door. It should come off the hinge assembly. Slide out the oven a little to access the screws for the hinge to see what is broken or wore out.
Aug 10, 2009 | Ovens
Model GPD-60
Look for spring or the lock tear side of the door applied small tin sheet can hold door lock and drill and then revit it.
Dec 30, 2007 | Garland GPD-60-2 Gas Double Oven
Ovens Logo
144 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
