I have a Honeywell RTH2300B1012A digital thermostat and the display got broken and now the display just lights up green and blank. Is there still a way I can program it to a warmer temperature or do I have to buy and replace the old one with a new thermostat?!??
  • 3 Answers
Replacement is Strongly Recommended.
Posted on Nov 19, 2014
I have A LCD Honeywell thermostat that has a display that is blank. also it is not sending anything to my furnace. there for my main level in my house is very cold. I have the same one up stairs and it is...
Replace the batteries first. Some cheap thermostats require the batteries to function. I don't know of a honeywell model that does though. Its cheap, so do that first.
If still nothing comes on and you still have a blank display with new batteries, I'd say probably the thermostat is defective. Even if the furnace is broken, new batteries SHOULD bring up the display.
Feb 20, 2015 | Heating & Cooling
My Honeywell programmable thermostat's display is blank and I do not have any heat?
The thermostat, depending on the model, normally does not get powered by batteries, they are for backup power. You might be losing 24 volt from the furnace, causing the thermostat to run on batteries.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
Honeywell wifi thermostat display blinks on and off
Doesnt this run on batteries? are they loose inside or the contacts to them dirty?
Dec 21, 2013 | Heating & Cooling
Honeywell thermostat is locked in the off position
sounds like keypad is programmed in lock position read manual for set up to activate keypad again.
Nov 25, 2012 | Honeywell Programmable Thermostat Heater
The display on my honeywell thermostat is blank, what do I do
Hi, Check the batteries and replace as needed or check for power from the air handler/ furnace...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Sep 18, 2010 | Honeywell Programmable Thermostat Heater
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
A/C not turning on - Digital screen is blank
Your honeywell should have battery back up but the primary power for this is a 24 volt transformer located in the air handler probably in your attic. All these controls run on 24 volts
Jul 11, 2009 | Honeywell Programmable Thermostat Heater
How to remove thermostat cover to replace
the cover pulls off if it has a green screen then most likely takes batteries if does not light up then no batteries with a small piece of insulated wire jump from green to red if indoor fan does not come on then transformer bad
May 15, 2009 | Honeywell Programmable Thermostat Heater
Display is blank and furnace fan stays on
Remove wires at tstat Turn switch for furnace off than on.
touch the red wire to the white to simulate a call for heat.
Or Touhc red green and yellow to simulate a call for cool.
If that works get a new thermostat.
May 10, 2009 | Heating & Cooling
T8411r1028 honeywell thermostat
Check in the heating unit itself for an automotive style fuse.
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
