Question about Canon IR2870 COPIER FOR 220 VOLTS ONLY
I dont oprate A4 paper only oprate A4R paper
Evry time paper jam in A4 size and A4R are Ok oprate?
    Champion:
  • Canon Expert
  • 234 Answers
I've allready answered that question
Posted on Nov 19, 2014
4 Suggested Answers
  • 1126 Answers
SOURCE: paper jams at heater section in ir4570
Depending on your voltage requirements; Fixing Film Unit FM2-1793-010 120V FM2-1812-010 230V FM2-1792-020 100V These numbers fit iR4570 and iR3570.
Posted on Jun 15, 2009
  • 92 Answers
SOURCE: canon ir 2016 digital copier
you can have 1 of 2 problems.
the cassete paper are in A4 position ,or you can trie to clean the registry roller.
Posted on Nov 02, 2009
  • 92 Answers
SOURCE: My machine Canon iR2016J Problem: Change
hello.
on the cassette you must change to a4.
Posted on May 23, 2011
Why my canon ir 2870 oprate A4R But dont oprate A4 ?
I may need more informaton about this problem,but anyway...Did you check the cassete,or try to change format in the other cassette.If so,there may be somethig on the A4 paper way.Where the paper stops? is it picked up from cassette?
Nov 19, 2014 | Canon IR 2870 Digital Copier RECONDITIONED
TOSHIBA ESTUDIO 455,PAPER GETS C FOLD FROM TRAY 2 IN A4R AND GETS JAM IN A4,BUT FROM BYPASS & FIRST TRAY A4R & A4 OK,EXCHANGED FEED ASSEMBLY,FEED CLUTCHES,REGISTRATION CLUTCH EVEN COMPLETE DUPLEX...
Try looking for distorted paper guides and trace the paper passages for any disposition or maybe foreign object stuck on it. try shuffle the papers too.
Apr 17, 2013 | Office Equipment & Supplies
When i press to copy it makes print but not all the page..then says load correct paper. down says A4R PLAIN COPY
A4 paper is used in Europe but some documents may be in that size. Try feeding legal size paper into your printer. Your document should be fully printed. Good luck !
Aug 22, 2012 | Canon Office Equipment & Supplies
No cassette with paper of size requested is available when print from network
set up the copier derive again & set the paper size
Make sure that the tray's paper size setting is the same as the tray's
paper size setting in the printer driver. For example, if the tray's paper
size setting is A4R (LT-R), set "Setting Paper Size" to "A4-R".
Jun 29, 2011 | Toshiba e-Studio163 Copier
I need to copy from A3 to A4R and cannot find how to change the paper to A4R
Right click on printer. Click on Printing preferences. Under quick setup tab, on the printer paper size box click the drop down arrow, choose A4.
May 16, 2011 | Computers & Internet
My canon ir 2018 is asking me to load correct paper in the tray even when the paper size is correct and all the settings are correct. It would print one copy then ask to load paper, i pull out the tray and...
Check the proper orientation of the paper. For example, if you are loading A4 size. In your tray you can find 2 A4 size. Select A4R in you want to position your paper Landscape or A4 if portrait.
To verify also the correct paper size, put your paper on the platen glass. Markings on the two sides of the platen glass shows the correct paper size.
Sep 16, 2010 | Canon imageRUNNER 2000 Copier
How TO change paper size dc 3535
Enter in the user tools mode or mechanically in the paper cassette.
Sep 01, 2009 | Xerox Office Equipment & Supplies
How do you change the paper size on a canon ir3025 photocopier from A4R to A4
Open the drawer,detach the blue paperstop by pushing it left and downwards.Insert the stop again at the A4R holes.Unlock the top and front vertical lock and slide it to the A4R possition.Set the blue dail to A4R so that the machine knows wat tipe of paper is loaded.
Aug 17, 2009 | Office Equipment & Supplies
Cant save A4 settings
edit your printer settings and set the paper settings to A4
Jun 16, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Paper jams at heater section in ir4570 in A4, A4R is OK for some time. replaced film but problem not solved. require original fixing film for ir4570 part number
May 21, 2009 | Canon Office Equipment & Supplies
Canon IR2870 COPIER FOR 220 VOLTS ONLY Logo
116 people viewed this question
old marine
old marine
