Question about Sony UVW-1800 Betacam SP VTR UVW1800 Beta Deck
Solution of error 32-000
When the tape is in the set... it send me 32-000 error... and the tape can not exit it.
Excel Error Message.What can I do to stop this error?
A corrupt excel spreadsheet can be repaired by using Open and Repair technique. It is a built-in repair function that opens a corrupt excel file forcefully.
*OpenMS Excel >pressCtrl+O >locate corrupt excel spreadsheet and select it.
*Click on the arrow shown besideOpenbutton>selectOpen and Repair.
It will take just a few seconds to be completed and selected file will be opened, if possible.
Or if this doesn't work, one may take help of a third-party
For example Excel Fix Toolbox
https://www.fixtoolbox.com/excelfix.html
Apr 24, 2015 | Microsoft Office Excel 2007
Mr. Heater MRH-MH18B. looking heat a unfinished basment about 1000sq ft
If you're asking if the Mr heater you referenced will heat 1000 sq ft, it won't. You'll need at least 32,000 Btu's to heat that much space. Either a gas mounted convection or infrared wall heater or a vent-free gas fireplace, that has a maximum heat out put of 32,000 Btu's should do the trick. Keep in mind, the air temperature in a basement, doesn't change more than 10 degrees F, thru out the year, so more than 32,000 Btu's is not better.
Hope this helped you and thanks for choosing FixYa.
Sep 12, 2011 | Mr. Heater MRHMH18B Gas Utility
Cassette will not exit, nor play and does a clicking soud
Cassette will not exit,eject nor play and does a clicking sound, one side of cassette door will not close.
Jun 15, 2010 | Sony TC WE835S Stereo Dual Cassette Deck...
Fax confirmation with copy of 1st page
what is the error code 05 for ricoh fax 1140L?
Jul 21, 2009 | Ricoh FAX1180L Laser Fax
Basic business math
8+5+3 = 16
64,000/16 = 4000
4000*8 = 32,000
4000*5 = 20,000
4000*3 = 12,000
so 32,000 : 20,000 : 12,000
Oct 24, 2008 | Televison & Video
Just bought and install fax machine (MFC640cw) I can send faxes but cannot recieve any. Phone rings, it recieves but it does not print.
It was installed on a VOIP connection. The Modem speed was changed to BASIC (9600 bps) which turns the error correction mode (ECM) off. Standard speed -14400 bps which may creat errors.
Steps: Menu/set - Fax - Miscellaneous - Compatibility - BASIC - Menu/set - Stop/Exit
May 21, 2008 | Brother Office Equipment & Supplies
AIT ERRORS
I had/have a similar problem with a SONY SDX-700C.
Emailed Sony tech support (very helpful) who suggested sending them the diagnostics from their TapeTool utility (qv). They then recommended running the cleaning tape 3 times, which seems to get it working (but the 'clean me' light still comes on every 7-10 backups). Hope this helps.
Jan 18, 2008 | Sony (SDX-460VRB) (SDX460VRB) AIT Tape...
Save config
After changing all the necessary parameters using the CLI, use the write command to save your system configuration. If you receive any error messages, your configuration has not been saved. You must correct the errors and re-issue the write command. Notification of write errors is presented in a two column display: ? The left column contains the parameter values that you set in this session and need to be changed. ? The right column contains the parameter values currently saved in the Cajun P116. Wait 15 seconds for confirmation of the write process. Then exit Privileged level by typing exit at the prompt. For example, CajunP116-priv# exit. The cursor changes to CajunP116> to indicate that you are in Normal level. Verify that all the parameters were accurately saved by using the show all or show all list command. The Cajun P116 is now ready for cabling and operation. You may exit your CLI session.
Aug 23, 2007 | Lucent Cajun P116T (108360843) Networking...
SONY LIB-81 Error on LCD screen - Drive Information 51
I think this sounds like the drive is having a issue loading and moving the tape in slot 1.
AIT units are known for having this kind of problem.
Try a cleaning tape and then a new tape fresh out the wrapper for a test backup.
if it fails with a known good tape then its time to send it out for repair
www.tape-drive-repair.com
Tape-Techie
Jul 26, 2007 | Sony (LIB81A3BB) AIT-3 Tape Drive
Sony UVW-1800 Betacam SP VTR UVW1800 Beta Deck Logo
76 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
