Question about British Telecom Synergy 2110 Cordless Phone
Numbers 7 8 and 9 not working
I opened it up and wiped the buttons with a dry cotton bud -still no joy. Then a wet cotton bud and dried immediately as i thought where i got it wet before -there may be a cleaning residue on those 3 keys. still not working. i also put it on the radiator for a while. Everything else is fine just not theses 3 keys?
  • 57 Answers
This is a generalist answer not one specific to this phone!
One of two problems here, the circuit board still has dirt or water residue on it preventing the signals from the keypad from being interpreted properly (a short), or the keypad its self is not conducting the current from the button pads properly when pressed.
Because there are three keys not working then I would imagine its the first problem as the circuits for a keypad circuit is arranged in a grid and this look like the row conductor is not working.
Damage like this often occurs to mobile phones months after they get wet as they slowly corrode with the smallest amounts of water left sitting in between or under the chips on the boards. If the phone has had water spilt on it then it isn't usually a problem if dried properly, anything else though usually is more of a problem.
The rubber keypad can be removed and washed in warm soapy water. The underside of each button is a conductive rubber and needs to be free of any 'stickyness'. these are usually pretty robust. (Only the rubber bit with the printed numbers on it!)
Once cleaned pat dry, even put it somewhere warm dry, or use a hair dryer.. once your happy there is no water left in the buttons etc put it together and try the phone again. I suspect it wont fix your problem though but that's the easiest fix of the two. If you don't want to pay for it to be repaired then have a poke around as its not going to be much use as it is, you'll need to do a bit of investigative work.
Take the phone apart, look for a track on the main circuit board that goes to each area where the 789 buttons would sit, follow it from the buttons and eventually it will go to a black chip on the circuit board, somewhere between that chip and the button pads is your problem. Look how clean the circuit board is near that chip, its likely the 789 button track goes to one of the pins of the chip and it is shorting to one of the pins next to it. if you confident use a pin and gently scrap between the pins, check both sides of the board in the same area for anything dirt related.
If you can get hold of an air line blow under the chip where the tracks go, (make sure nothing is around that is loose on the board that can blow away)
Other than that without a friend with a soldering iron there's not a lot else you can do.
Posted on Nov 19, 2014
  • karen reed
    karen reed Nov 19, 2014
    Thank you for your reply :) I will try your suggestions - thanks again!
How to Make a Non Working Xbox Disk Work?
    1)Take disk out of Xbox
    2)Try turning off Xbox
    3)Choose one of the methods to try and fix disk Polishing disk
      -Use air first (blow across disk, or use a soft brush to remove any specks from disk before polishing)
      -Get a soft, lint-free polishing cloth (make it damp)
      -Use wet side of cloth to clean shiny side of disk
      -Dry whole disk (dry polishing cloth)
      -Put it in Xbox Using soap or water
        -Use soap or windex-slightly wet paper towel to wipe off disk from middle towards outside
        -Use furniture cleaner Using toothpaste
          -Rub toothpaste on disk, dampen a suitable soft cleaning cloth
          -Rub from centre-then move all the way around to edge
          -Wipe toothpaste off with a wet cloth-wipe any dampness with dry cloth
          -Put it in Xbox Using car polish
            -Get a dry cloth and add a small amount of polish to it
            -Rub in a circle motion, then wipe dry
            -Put it in Xbox Peanut butter
              -Put a dab of peanut butter on a lint-free cloth
              -Don't rub it in a circle motion
              -Put it in Xbox Using rubbing Alcohol
                -Pour out a small amount of rubbing alcohol onto a cotton bud
                -Rub from centre of disk, moving outward to edge
                -Wait for it to dry and try again Wax from candle
                  -Get some melted wax from a normal candle
                  -Gently pour wax on scratches-rub in with soft cloth
                  -Wipe off excess wax with a damp cloth
                  -Let disk dry for 5-10 mins and try again Vanish Oxipowder
                    -Cover entire shiny side of disk with powder
                    -Wait 5-10 mins
                    -Clean powder off completely with soft damp cloth
                    -Place disk in Xbox Other possible fixes
                      -Take disk to game/computer shop
                      -If any of your friends has game, borrow disk from them, install it to hard drive, and hope Xbox recognises it
Oct 20, 2016 | Video Game Consoles & Games
Tip
How do I Clean iPod Ear buds
<p>IPod ear buds can get grungy from regular use and should be cleaned and disinfected frequently. If your iPod headphones with others, there is potential for the transmission of germs and infections. Be sure to immediately disinfect your earplugs if someone uses them. <br /> <p><br /> <p>Soap and water clean <br /> <p>1. Disconnect the headphones from the iPod. <br /> <p><br /> <p>2. Mix a mild soap with warm water. Dampen lint-free cotton with soap and water mixture. Wipe the earphones with a damp cloth. Do not get water into the holes. <br /> <p><br /> <p>3. Enter the cloth under warm running water. Rinse to remove all soap. Twist the cloth to dry. Wipe the earphones to eliminate soap residue. <br /> <p><br /> <p>4. Rub a clean, dry cloth over the headphones to dry them. <br /> <p><br /> <p>Disinfection with hydrogen peroxide <br /> <p>1. Buy a solution of hydrogen peroxide 3% or disinfectant wipes. This product is available in pharmacies and supermarkets. <br /> <p><br /> <p>2. Dampen a clean lint-free cloth to clean the peroxide and the headphones. <br /> <p><br /> <p>3. Wipes clean with a pre-designed for cleaning hearing aids if you do not feel comfortable using a solution of hydrogen peroxide. These scarves are not guaranteed damage plastic, silicone or rubber. <br /> <p><br /> <p>4. Carefully wipe the headphones with a clean, lint-free. <br />
on Aug 09, 2011 | Apple iPod touch
When printing quality check page yellow block not complete.
Try this:
Remove the offending cartridge - yellow.
Take a cotton bud and slightly dampen the end - (put under water and then sqeeze dry with kitchen paper)
Carefully wipe the copper coloured plate of the cartridge with the damp cotton bud to remove any dried ink, then replace it.
If you don't have cotton buds you can use a damp peice of kitchen towel.
If that does not work then you may have a hardware fault.
Mar 18, 2010 | Brother Multi-Function Center MFC-240C...
Video head need cleaning is it wet or dry
The best way to clean a video head is to remove the top cover and Spray the heads (both video head and audio/control heads) with Servisol Video 40 see image below. Just let it dry up (which wont take long) and that should do the trick. If you spot some nasty bits of dirt, spray a cotton bud and wipe it away.
Mar 16, 2010 | Quasar VHQ400 VHS VCR
When I try to record a program I get a "RECORD ERROR" E 4 54037380
Try this. his seems to be a common problem on all DVD players.
If a DVD Lens cleaner (with brushes) fails to fix the problem, then it could be that you have
grease particles on the lens. Do the following:
Note. If unit is still under warranty, you may nullify this by opening unit up
You will need:
Screwdrivers as necessary
Cotton Bud sticks (also known as Q-tips)
Isoproponal/Isopropyl Alcohol (small bottle comes with some CD/DVD cleaners)
Compressed Air cannister/aerosol
1. After disconnecting unit, leave standing for 15 minutes
2. Unscrew lid and remove
3. Carefully remove DVD lens cover
4. Blast whole area with compressed air to remove dust
5. Dip one end of cotton bud in Isoproponal, and very carefully wipe DVD lens (just one wipe
should do.)
6. Now wipe lens with dry end of cotton bud, and leave a few seconds to dry
7. Carefully replace DVD lens cover (watch out for ribbon cables)
8. Replace Lid
9. Reconnect, switch on and test
Feb 23, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording error E4 54037380
This seems to be a common problem on all DVD players.
You will need:
should do.)
8. Replace Lid
After I'd tried every other way possible, this method finally worked for me!
Nov 08, 2009 | Televison & Video
Cd burner makes a noise like it wants to work but it never gets anywhere
Wet a cotton buds with dish washing liquid then clean the lens of the cd burner,then rinse it with tap water, using a cotton buds.Then let dry for a minute.
Sep 13, 2009 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
E4 54037380 Cannot record to disc?
You will need:
should do.)
8. Replace Lid
Nov 07, 2008 | Televison & Video
Recording Disk Problem Cannot Record On This Disk E4 54037380
This seems to be a common problem on DVD recorders.
You will need:
should do.)
8. Replace Lid
Aug 22, 2008 | Televison & Video
When i try to record it comes up error e4 54037380 toshiba d-vr16sb
This seems to be a very common problem with DVD recorders.
You will need:
should do.)
8. Replace Lid
Aug 03, 2008 | Televison & Video
British Telecom Synergy 2110 Cordless Phone Logo
Top British Telecom Lands Phones Experts
honeybun1986
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
