Question about Cell Phones
How do I he the PIN number for phone number +1 215 525 6044
My phone asks "enter PIN
The default PIN Number is 12345. Please try that and see.
Hope this helps. Good Luck. ~SmokinJoe~
Apr 27, 2011 | Nokia E71 Smartphone
Tip
How to find the PIN code of Cell Phone
Hello <br /> Personal identification number (PIN), is a secret number that is used to unlock the phone, unlock in the sence of accessing the device you are using. It is made up og 4 digits that is giving to you when you buy a phone number. It comes with your phone number not with the device, so that means you can still use the same pin on different mobiles. But always remeber your pin number because if you lose it then your phone will be probably blocked! <br /> Following are the some ways to find the pin code: <br /> Enter the last four digits of your phone number on your cell phone PIN screen. When setting up a cell phone PIN, the default number assigned is the last four digits of your cell phone number for most cell phones. <br /> Enter 9999, and if that doesn't work try 1111. The number sequence 9999 and 1111 are other standard numbers assigned when choosing a cell phone PIN. <br /> Shut off your cell phone, take off the back of your phone and pull out the battery. Record the IMEI number under the battery. Reinsert the battery and power on the phone. Enter the last four digits of the IMEI number on the PIN entry screen. The last four digits on your IMEI number can occasionally be the service provider's preset PIN for the cell phone. <br /> Call your service provider and request the PIN. You will have to prove you are a customer by stating your cell phone number, address and NIC number. <br /> Hope this helps, if so do rate the Tip.......
on Feb 01, 2011 | Cell Phones
How do I find the pin number on a motorola sb5101n
  1. Enter the last four digits of your phone number on your cell phone PIN screen. When setting up a cell phone PIN, the default number assigned is the last four digits of your cell phone number for most cell phones.
  2. Enter 9999, and if that doesn't work try 1111. The number sequence 9999 and 1111 are other standard numbers assigned when choosing a cell phone PIN.
  3. Shut off your cell phone, take off the back of your phone and pull out the battery. Record the IMEI number under the battery. Reinsert the battery and power on the phone. Enter the last four digits of the IMEI number on the PIN entry screen. The last four digits on your IMEI number can occasionally be the service provider's preset PIN for the cell phone.
  4. Call your service provider and request the PIN. You will have to prove you are a customer by stating your cell phone number, address and Social Security number.
  5. Turn off your phone. Hold the keys "3," "*" and "Call" and switch the phone on. Hold the three buttons down until the word "Formatting..." appears on the screen. This should reset the phone lock code.
  6. Go to one of the links in the Resources section and have your IMEI number ready. These websites will ask for your phone model and IMEI number and then charge you a set fee for the unlocking PIN.
Mar 13, 2011 | Motorola Computers & Internet
What is the pin code for nokia 5233?
Hello
Hope this helps.
Feb 01, 2011 | Nokia 5230 Cell Phone
I forgot my cell phones pass word and need to unlock my phone what can i do?
  • 1
  • 2
  • 3
    Shut off your cell phone, take off the back of your phone and pull out the battery. Record the IMEI number which is under the battery. Reinsert the battery and power on the phone. Enter the last 4 digits of the IMEI number on the PIN entry screen. The last 4 digits on your IMEI number can occasionally be the service providers preset PIN for the cell phone.
  • 4
  • 5
  • Dec 18, 2010 | Lands Phones
    Phone's pin number locked me out
    default PIN number for motorola is 0000.
    Apr 02, 2009 | Motorola Mobility V365 Cellular Phone
    Pin Number
    okkkk just type 9 in your phone and then in your leptop.
    Nov 26, 2007 | LG CHOCOLATE VX8500 Cellular Phone
    Pin Number
    The first pin, at least with verizon, should be the last four digits of your phone number
    Oct 22, 2007 | LG Chocolate Clamshell VX8600 Cellular...
    Cell Phones Logo
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
