Question about Tally 6306 Matrix Printer
What is the reason of stbcnt=1 error?
What is the reason of stbcnt=1 error in tally t6306 printer?
rtrahan
  • 741 Answers
SOURCE: How do I clear a "config 1" error on my tally t6218 printer
Click start>run>type services.msc. The services window will come up and you can right-click on the Print Spooler and then click Restart. This will clear the print queue and hopefully allow you to print. Good Luck. Let me know if you have any questions.
Posted on Feb 28, 2009
  • 39 Answers
SOURCE: ERROR MESSAGE BLK 1CHKSUM FLT on tally t6045 printer
BLK 1 means your black toner cartridge, and I believe the chksum error may have something to do with the memory file. Check out No. 6 under Unrecoverable errors on this sheet.
http://www.tallygenicom.com/support/technotes/3400/error.htm
This is problably something to be sent in for maintenance.
For this error these are the recomendations:
(Try cycling power; initilizing printer. If error persists, maintenance
service is indicated.)
Posted on Apr 27, 2009
LineMatrix
  • 34 Answers
SOURCE: Tally Printer the error is some times Hammer
In the T6215 Maintenance Manual the fault message: Hammer Voltage has been replaced, in the T6218, with:
Hammer Voltage 1
There is a new fault message for the T6218. It is:
Hammer Voltage 2
Explanation: A high resistance coil fault has likely occurred in one or more of the hammer coils
Note: This fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Corrective Action:
Check the hammer bank for defective hammer coils.
Confirm that hammer drive board is functioning properly.
Posted on Apr 26, 2010
SOURCE: problem for lipi 6312 tally genicom line printer
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Posted on May 19, 2010
  • 21 Answers
SOURCE: HOW TO REMUV TALLY T6306 SHULELL ASSY
Do not do that! You won't be able to adjust this correctly after you installed the shuttle system again. This part can't replaced in the field. Only in the manufacturers repair center with special tools. Btw, it is very unlikely that the Shuttle system fails at this type of printer.
Posted on Sep 21, 2010
What does HAMMER VOLTAGE 1 ERROR indicate?
There is a short on the hammer drive circuit. It can be caused by the
HammerBank
TALLYGEN 093524 HAMMERBANK T6306 Refurbished
The Main Logic, the link is for the standard one, but if you have a Graphics selection then you will need a different one.
TALLYGEN 086153 CONTROLLER KIT STANDARD T6306 Refurbished
And in rare cases the hammer bank cables, but you will normally see a break in the cable if that is the case.
May 26, 2014 | Tally 6306 Matrix Printer
Lipi6306 matrix printer not going to offline mode always in online configure 1
step 1 : change the panel cable
step 2 : change the control panel
step 3 : download firmware as follows :
T6306 FIRMWARE DOWNLOADING PROCEDURE
  1. Connect the printer to pc through parallel port.
  2. Press "FF + ^ + CONFIG" at the control panel and power on the printer .
  3. Panel will show "ready to download".
  4. In dos mode type "vdv3000r -pb" and enter .
  5. After completing the firmware loading printer may show NVRAM fault.
  6. Press "CLEAR"and printer will restart to finish.
Mar 02, 2014 | Tally Line Matrix T6050 Printer
Shuttle solenoid T6306 Printer
Hi we provide Service support for all type of Line printers.
Oct 20, 2012 | Tally 6306 Matrix Printer
Stbcnt=22
Try to find a defective resistor(component parts)near main processors if not.,i guess its the main processors itself Freescale ColdFire 5307 have problem.
Aug 13, 2012 | Office Equipment & Supplies
Printe fault stbcnt
Jun 22, 2012 | Tally 6306 Matrix Printer
PRINTER SHOWN PLATEN CAL CABLE IN T6306
if your platen calibration is not done.
1 Resat All Platen Connection of cabal
2 Replace Logic Card
3 Check Platen Moving proper
4 Than Check Sensor And Platen Aliment
5 Than replace Platen Sensor
6 Please Check Platen Motor
Regards
yogendra Sharma
Nov 27, 2010 | Tally 6312 Matrix Printer
Aug 17, 2010 | Tally 6306 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Tally Data Problem
EXITING TALLY!!
INCORRECT VERSION.
DATA OF INCORRECT VER.(10)
CAN ONLY RUN VERSION 9!
Jun 27, 2009 | Tally T2245 Matrix Printer
SHUTTLE ERROR
check shuttle sensor (during trasmission it will show 5v and when it does not reflect it will show 0.4v) and see where there is ant teer in shuttle belt..
May 12, 2008 | Tally Line Matrix T6050 Printer
Tally 6306 Matrix Printer Logo
57 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
