Question about Acer Computers & Internet
Lenovo g550 laptop with an external monitor would only display of broken original screen after crash dump
I have a lenovo g550 laptop with a broken screen, and use an external monitor (usually an lg flatron 1215s and sometimes an al1917c acer one). My computer went into crash dump a day after I installed and uninstalled a program called spybot search and destroy, so I ignored the blue screen msg (big mistake due to panic), and tried removing spybot once when I managed to reach the desktop. This happened a couple of times, and I think I managed to remove all of the program, before the blue screen came up again. This time though my computer couldn't display info on my external screen- only on my original and broken monitor, which is completely unusable (I can only see shaped and flickering lights). It might also be useful to mention that a day before these crash dumps I had installed a new nvidia driver. I tried all the hotkeys and closing the lid right after starting the computer, but so far nothing has worked. My computer is still working (I can hear the fans and see a change in the colour patterns) and the external monitor worked when I tried connecting it to another computer, so what is the problem?
  • 57 Answers
Firstly you need to get your external monitor working. Have you tried pressing FN+F3 while turned on, (may take several presses).
If you can get the external monitor working then you'll need to run windows in safe mode and try removing any new drivers you installed. or try a 'Last Known good' on start up this depends on the OS version.
Posted on Nov 19, 2014
Riziel
  • 116 Answers
SOURCE: Screen Flickering on Acer 3680-2682
Ok we must remember when we setup any device on our PC, one of the many non PnP devices is and LCD Monitor, your PC should always be shutdown before installing a new Monitor. If you did not do this you could have damaged the I/O port on your PC. Not a definite, but possible! When you plug up a monitor or any serial cable while the PC is still on, it is of a low voltage which can casue some issues for you! Sounds like this one is yours!
Posted on Nov 26, 2007
dapidc
  • 111 Answers
SOURCE: Acer Aspire 5580 wont power up at all
Remove the adapter plug.
Remove battery and insert again. I use a USB optical mouse, when inserting the battery, the lights will flash a moment. That signs OK.
Try turn on the notebook.
For my 5580, this trick always work. After it is on, I plug in the mains.
Posted on Dec 08, 2008
tleeski
  • 29 Answers
SOURCE: D800 laptop will not display on external monitor
Most laptops go into standby mode when the lid is closed. To stop this, (Windows XP) click Start, Control Panel, Performance and Maintenance, Power Options, then click on the Advanced tab, select "Do nothing" in the drop-down for "When I close the lid of my portable computer"
Posted on Feb 12, 2009
shahabdun
  • 249 Answers
SOURCE: acer 8920 intel x3100 lcd and external monitor blank or black
Problem with the Power supply.
Posted on Jul 19, 2009
nanbuenbrazo
  • 553 Answers
SOURCE: Gateway W340UA laptop - no display...
Sometimes it di happen , specialy in most laptop which is being used more frequently and longer usage, the advisable use of a laptop is atleast 2 to 4 hours then shut it off and have cool down for 30 minutes to one hour then you can used it again, unless you got a support inclined base for laptop with support ventilating fan to help down minimize the heat accumulated during the usage.
have it check your video card with the proper technician, but first try to cool down your unit and try to open it again, and if still does'nt work then have it check by the service center
Posted on Nov 03, 2009
Lenovo g550 laptop with an external monitor only displays on broken original screen after crash dump
Download and install the display driver from the link below:
http://support.lenovo.com/us/en/products/laptops-and-netbooks/lenovo-g-series-laptops/lenovo-g550-notebook
Nov 19, 2014 | Lenovo G550-29583AU Notebook
When the computer is starting up PRESS & HOLD the "F" key which controls the external monitor. It may be F4, F5, F6. You should get image on the external screen. Go into video properties and select dual monitors or allow computer to use external display or something like that.
Nov 19, 2014 | Acer Computers & Internet
Laptop screen flickers
try to plug the laptop to a external monitor. I the display doesn't flicks your Motherboard or the graphics card fine and you need to replace your screen LCD
Aug 20, 2012 | Lenovo G530, G550, G560...
Hi i have problem with my lenovo g550 ...after turning on ...the screen is white...could be a screen tape?
Welcome to Fixya
Try to perform power drain to the system. Take out the battery and unplug the power from the wall. Press and hold the power button for 15 secs. Plug in the power afapter then trun on the computer.
If same thing will happen, try to use external monitor and connect it to your laptop. If still no display then the problem is the onboard video card. If you get a display using the external monitor then the problem is the LCD. Could be loose flex cable inside.
Thank you for using Fixya!
Aug 04, 2011 | Lenovo G550 Notebook
Lenovo G550 laptop boots with a white screen??
Welcome to Fixya
Sounds like you already have LCD problem. Try to test the issue further. Use an external monitor and plug it to your laptop. If you get a display using the external monitor then the problem is the LCD. If there is no display coming out then the problem is the motherboard.
Aug 01, 2011 | Lenovo G550 Notebook
When i switch on my Lenovo g550 laptop i am getting white screen, if i connect same on other monitor i am getting display
you seem to have a problem with your lcd display, defective flex ribbon. if you can do open and check it out that would be better. this things really happens because we always need to open the laptop more than ones a day.
Jul 12, 2011 | Lenovo G550 Notebook
Blue thin line on lcd screen.G550 lenovo
HI.
There can be two reasons why this could happen.
1. The LCD screen might have gone bad.
2. or, There might a problem with your video driver.
To rectify,
If you have an external monitor, you can connect that to the laptop & toggle the display, so that you can see if the display is fine on the other computer.
Hope this helps..
Cheers!! Have a nice day!!!
Sep 17, 2010 | Computers & Internet
Blue screen coming frequently in my ideapad g550.all programs suspended immidiately followed by restart of laptop.
Check to see what free space is available on your hard drive. If you have less than 15% free space, this will cause it to crash. Delete all unnecessary files, empty recycle bin, remove all unused software packages no longer used. You can also transfer data to an external hard drive to free up space.
Jul 26, 2010 | Lenovo G550-29583AU Notebook
Computers & Internet Logo
90 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
