Question about Dometic Refrigerators
Dometic 3 way fridge, what should the voltage be at the flame indicater
It all works but the flame indicater does not, the voltage at the flame indiater is 09.0 all else works , think the indicater is not working. thanks
    Top Expert:
  • Dometic Master
  • 5,062 Answers
Clean or replace indicator
Posted on May 27, 2016
22yooper
  • 828 Answers
SOURCE: Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
Posted on May 26, 2008
SOURCE: Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Posted on Jul 20, 2008
  • 51 Answers
SOURCE: FRIDGE WILL NOT IGNITE IN GAS MODE
The part you are looking for is the thermo couple. It senses the heat from the flame and holds the gas valve open. The clicking will try three times and then go into lock out. You then will need to reset on the front of the fridge. When installing the thermo couple do not over tighten.
Posted on Sep 07, 2008
VtToolMan
  • 704 Answers
SOURCE: Dometic rv fridge runs fine on elec, lights on gas
It is key that all control switches are in the correct position, depending on what power source you are using, gas, electric, etc. If the switches are not in the proper setting, the unit will not operate.
Here's the manual for your fridge that should be printed out for your use and reference (and reading enjoyment). It has all the info needed to operate and troubleshoot it.
Typically, when using any gas appliance with a pilot light, the sensor has to first be hot enough to trigger it to allow the safety gas shutoff to open and allow the gas to flow to the pilot/burner. Follow the instructions and you should be all set.
http://gasrefrigeration.net/dom_techdata/2707_2811SM.PDF
Hope you find this helpful and best regards!
Posted on Jul 30, 2009
SOURCE: I have a dometic RM2201 3 way fridge my problem is
Sorry woodchuck789 Rank: Guru. The Dometic RM2201 does not have any of these things; vent(damper), fan in the freezer, auto defrost, defrost timer, defrost heater, or a defrost thermostat.
mickamoose, Most likely the camper is not sitting level. It needs gravity to work correctly. The fins in the back of the refrigerator get cooling from the refrigerant leaving the freezer compartment. If all else fails, leave to freezer compartment door open inside the refrigerator. Parts for this unit are getting hard to find and these RM2201 refrigerators will never work as well as the one in your house. One alternative is to replace the refrigerator with a dorm or office type refrigerator. They are cheep and work well except only on 115 Volts AC.
Posted on Aug 21, 2009
How do I keep Dometic 3-way fridge flame lit on propane while driving?
not a good idea run on electric while driving especially when pulling into fuel up open flame not a good idea
Feb 26, 2015 | Dometic Refrigerators
Dometic 3way fridge model RM2350R. the fridge works ok, but when i run it on gas the flame lights first time, but the flame indicater does not work,the thermocuple has the right ajustment,is clean,wh
The flame indicator works on very low voltages from electricity generated via the thermocouple. Check the connections and if OK, I would say you are correct in assuming the indicator has failed. These are very sensitive and a bit of a knock can damage them. Try Dometic or Electrolux for a replacement indicator.
Nov 21, 2014 | Dometic Refrigerators
Low flame on a 2600 dometic fridge/ flame is not enuff to keep fridge cold
Hi and welcome to FixYa, I am Kelly.
Download this manual:
http://www.dometic.com/9efb3e8b-c980-4383-952c-996a35e3c872.fodoc Go to page 12 for burner cleaning. Clean the burner and the gas orifice (jet) thoroughly. If after cleaning you still have the problem you may have to remove the solenoid vavle and clean out the gas safety valve. The manual also mentions checking LP gas pressure. A weak LP regulator will cause a low flame. I would clean it first... and if you still have a low flame check / replace the LP regulator before tearing into the gas safety valve.
Thanks for choosing FixYa,
Kelly
May 09, 2011 | Dometic RM2620 Refrigerator
I bought at Dometic propane/ electric fridge for my cabin last year. It has not run properly since. The fridge will light and run for a while with a blue flame but sometimes in the idle mode it goes out....
I have to ask, what is idle mode? I've never seen one that runs on idle mode, in a RV in 15 years. Has anyone used a manometer and tested Inches of water column in propane supply to fridge, as well as other appliances?
Any I've seen run on propane, are either on, (flame present, or off, no flame present.) Flame goes out completely when not calling for cool.
Jun 13, 2010 | Dometic RM2620 Refrigerator
Dometic rm 2620 fridge problem
The flame is not hot enough check gas pressure
Jun 22, 2009 | Dometic RM2620 Refrigerator
Aug 11, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
51 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
