Question about Samsung Office Equipment & Supplies
How do i fix the top margin on a samsung printer clx 3160n as it seems there is no top margin when i print
    Problem Solver:
  • 10 Answers
Try changing paper type from letter to a4 or vice versa. Uncheck photo print. Change settings properties for your document.
Posted on Nov 19, 2014
CompuGuy44
  • 432 Answers
SOURCE: Printer does not print whole document
In 'Print Preview' look at the margins, and see if anything is too close to the edge of the paper. If it is, then set your margins further from the edge, or drag graphics further from the edge, etc.
To correct the margins that are set to close to the edge of the paper, open the document in Microsoft Word and follow these steps:
  1. Make sure that you are using the same printer driver that gave you the error in Microsoft Word Viewer.
  2. In Word, on the File menu, click Page Setup.
  3. Click OK.
    You receive a warning dialog box about the unprintable regions.
  4. Click the Fix button.
  5. Save and close the document.
You can now open and print the document in Word Viewer without receiving the error message.
Posted on Dec 19, 2008
  • 4 Answers
SOURCE: My Samsung CLX-2160N will not print black and
See answer posted by Loki
Posted on Jul 07, 2009
  • 113 Answers
SOURCE: Printer is a Samsung CLX 3175FN. It says the
To run a quick check on your black toner, insert your old black toner back to the printer.
press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
get the new toner with the box packing back to the shop for replacement.
Posted on Apr 19, 2010
  • 113 Answers
SOURCE: samsung CLX-3175FN printer instructions - How do
3175fn is acolor printer. if you want to set only grey or black only print. you have to go to printers & fax. select the printer right click properties and go to color and set as gery or black only print.
Posted on May 13, 2010
SOURCE: Huge Margin with Kyocera FS 1000+
If the FS-1000 prints too far down the page or leave too much top margin or leaves a gap at the top of the page etc (<- for google searches). This is a problem with the felt pads on the three solenoids/clutch electro magnets that are under the right panel (2 under the engine/button board, 1 under the inner plastic cover, sometimes 4 in total on other kyocera printers). They get compressed over time meaning the metal leavers come into contact with the solenoid meaning they are released too slowly. Simply replace the felt pads with .5mm cardboard or another non-sticky non-metallic material. Too thick and it prints too far up the page.
Posted on May 16, 2010
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
Red lite on printer-unit gets hot, all panels chkd o.k.
PLEASE RE INSERT WATE INK UNIT & DRUM UNIT OR PAPPER MIS MATCH
Jun 05, 2012 | Samsung CLP-300 / CLP 300N / CLX-3160FN /...
Left margin cuts off
Try changing the left margin size in the page setup. Decrease the left margin size.
You could also try printing in Landscape instead of Portrait just to see if it captures the left margin.
May 31, 2012 | Samsung CLX-3175FW Multifunction Laser...
Reset fax clock
http://www.retrevo.com/support/Samsung-CLX-3160FN-Multifunction-Printers-manual/id/2775ag719/t/2/
Hi please find a copy of your user manual, the information you require is explained in the manual.
http://uploading.com/files/14abb465/Samsung%2BCLX-3160N.zip/
Above is your service and repair manual should you need that too. Copy/paste to the address bar.
Aug 19, 2010 | Samsung CLX-3160 All-In-One Laser Printer
White line down the middle of page on samsung clx-3160n
You need to replace the drum unit or the transfer belt. Both are high-yield consumables with an expected life of 15,000 pages. However, it is common that these parts fail before the expected life.
Apr 15, 2010 | Samsung CLX 3160fn All-In-One Printer
Copy unclear
This is the Document feeder Glass/or Platen glass cleaning issue or CCCD/CIS problem.
First try cleaning the glass else you need to change the CCD/CIS module.
Apr 30, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Samsung 3160N - clicking sound but printing okay
Check the toner cartridge make sure it is all the way in. Also full out all those toner cartridges and check the gear that rotates when you print see if there is no broken teeth. This happens on mine too.
Mar 05, 2009 | Samsung CLX 3160fn All-In-One Printer
CLX-3160 image offset or margin shift
Dear
Please contact samsung Call center in your region. fothis type of support.
Apr 20, 2008 | Samsung CLX 3160fn All-In-One Printer
37 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
