Question about Garden
Partner cement saw. Did not put correct gas/oil mix in. Now won't start. Any suggestions?
  • 1,169 Answers
Not good...Pull the muffler and check the cylinder and piston condition. Hopefully it is just a struck ring but most times it is usually worse and which would require a cylinder, piston and ring(s) replacement.
Posted on Nov 19, 2014
4 Suggested Answers
  • 468 Answers
SOURCE: correct mix of gas and oil for Chain Saw
The ratio is 40:1, provided this is a gasoline homelite chainsaw. Find the suitable amount to put into the gas can at a ratio of 3.2 oz per gallon. The bottles that you buy the oil in have marks on them telling you how much there is, and often times, are sized to dump into a preset amount of gas. Put the oil in the can, then put the gas in the can, cap, and shake. Always shake before dispensing.
Posted on May 30, 2010
Testimonial: "Great advice, thanks for the info."
dontbother10
  • 2220 Answers
SOURCE: What is the correct oil gas mix for an older
If orange (FarmSaw) 24:1
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/373683b7e144c81188256b00001f8ba0?OpenDocument
If yellow (FarmSaw II) 40:1
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/c277be66a123264788256b000020229f?OpenDocument
I run my orange FarmSaw on 50:1 and have for some time without a problem. 50:1
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 06, 2010
philwalker78
  • 608 Answers
SOURCE: Poulan Pro - won't start after quitting
Hi, unfortunatley you have partially siezed the chainsaw. You will still feel some compression with your thumb but the rings will be siezed in the piston. Hence no fuel transfer to the sparkplug. Sorry Phil.
Posted on May 31, 2012
I have trouble starting my 738 partner chainsaw
well was the gas fresh
is it even getting to the carb
have you sprayed carb cleaner into the carb and then see if it starts
yes it does
get a new carb
Aug 19, 2014 | Garden
My cutoff saw won't start, compression is good, has oil/gas mix, gets spark from wire but sparkplug was dirty so i cleaned it and she still won't turn over
If the saw briefly runs when you prime the carb and/or cylinder with gas then most likely fuel is not getting thru the carb. Try rebuilding the carb and replacing the fuel filter first. You can also search on youtube and google for troubleshooting tips.
Jun 03, 2012 | Homelite Xl-98a, Xl-98c, Xl98-d, Xl98-e...
May 30, 2012 | Poulan Garden
Ran out of gas put gas in wont start,pulled spark plug and put a little gas in ,it fired but wont stay running,the primmer bulb seems to be not working
Hate to tell you this but if you didn't mix oil with the gas properly (most likely a 40:1 ratio) then the chain saw will seize up and won't work again.
Jun 17, 2011 | Garden
Correct mix of gas and oil for Chain Saw
May 30, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
What solution do you put in the gas of a chain saw
The oil they gave you was to mix with the gas. The chainsaw has a 2 cycle motor that requires two cycle oil to be mixed with the gas.
May 06, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Have '70's Partner R420 chainsaw. What's the
The Oil:Gas ration for a Partner 420 saw is 25:1 if using standard, quality two-stroke air cooled oil. The service manual says 40:1 can be used if you are using Baird/Poulan branded 2-stroke oil designed to be run at 40:1.
Please rate this solution on FixYa!
Thanks
Mar 30, 2009 | Garden
Chain saw emitted sparks and now does not start.
Hi
When the engine get warm and die(I suppose)check the spark at the sparkplug.You can let the saw run until it ran out of gas and you will not distroy the engine.Change the sparkplug.
best regards savumihai71
Dec 16, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
