Question about Sharp Aquos Televison & Video
My sharp aquos TV Guide 46" model won't pick up hdmi connection from the cable box. I already tried changing the cables with no change. Any suggestions
    Problem Solver:
  • 11 Answers
Have you tried a different HDMI input on the TV? Are you sure you've selected the correct HDMI input? Make sure there are no component cables connected to the cable box. Occasionally that will disable the HDMI output.
Posted on Nov 19, 2014
swami nathan
  • 208 Answers
SOURCE: Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Posted on Sep 28, 2008
SOURCE: Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Posted on Mar 17, 2009
  • 8457 Answers
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Posted on Dec 17, 2009
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
SOURCE: trying to hook my roku box to my sharp aquos 46 in using my hdmi
according to roku support hdmi won't work with the aquos as of today (1/6/2010). i have no idea if it's an hdcp issue or not
Posted on Jan 07, 2010
bshldn
  • 736 Answers
SOURCE: My problem is when I
On the Vaio:
right click volume on system tray and select playback devices
select hdmi/ sdip as default and then in the properties deselect dolby
If you don't have those options you may need new drivers installed on your Vaio. Do you have windows xp? The driver can be found here: support.vaio.sony.co.uk/downloads/info/info.asp?site=voe_en_GB_cons&url=Vaio/Original/AR2_Drivers.zip&ip=RAID_AR21.htm
If you have vista the driver can be found here:
support.vaio.sony.ie/downloads/updates/updates.asp?site=voe_en_IE_cons&c=0&s=VGN-AR&m=2418&os=7&osl=1
On the television make sure you are on the right input. Press menu--setup--hdmi setup--audio select--digital
Hope this helps
Posted on Oct 08, 2010
Testimonial: "Thank you very much! Just the first phrase was enough!!!!"
View mode changes when switching tv off then on
If this is the correct tv model number LC42D62U and if you are connecting it to something with an hdmi cable, and it is on one of the hdmi inputs then you need to change the settings. Press the menu button--->scroll to setup on the right--->scroll down to hdmi setup and press enter to select--->If auto view is not highlighted already highlight it then press enter--->disable it then press enter--->press exit or menu menu to exit
Apr 23, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I BROUGHT A USED SHARP AQUOS TV I CAN'T GET IT TO SEE MY CABLE KEEP SAYING FAIL TO RECEVE BROADCAST
How are you connecting it to cable tv?
If you are using a coaxial cable to a cable box you have to turn to channel 3.0 with a Sharp remote by pressing 3.0 enter the dot (.) is down by the 0. There is a way around this if you don't have a Sharp remote. You can go into the menu and complete a channel scan. If the model you own is the one pictured then you should have the coax cable connected where it says analog if you are connecting to a cable box this way.
If you are using composite, component, or hdmi cables you press the input button on the television and pick the right input. It is recommended that you do not use the coax cable anyway unless you do not have a cable box. There is an input button on the television and on the remote.
Dec 15, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Television isnt working correctly
Are you changing the Video Input selector to the proper HDMI port? AKA the SOURCE button.
Couldn't decipher if you said that you've used another console with HDMI video on the Sharp Aquos already.
Jun 08, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
My volumn doesn't work when using the HDMI cable
Your TV and the cable box may not be compatible via HDMI or the digital audio format of the cable box is not set to PCM (contact your cable provider for information on how to change this on your cable box... too many models to speculate). The easiest solution is to use the component connections on the box and the TV (5 wire - Green, Blue, Red, White, Red). This will give you HD and eliminate to question of compatibility. I hope this was helpful, best wishes.
Apr 22, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Television is not recognizing HDMI inputs
there is a possibility that there might have been a power surge sent over hdmi into the hdmi board on the tv. if on your model the hdmi board is seperate from the sine board then youll have a cheap replacement if not its gonna cost you roughly 300-400 is my guess.
call your repair guy
Aug 02, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Apr 03, 2009 | Sharp Televison & Video
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cannot get a connection with HDMI input
When the tv won't scroll to the HDMI inputs, it means that the tv does not detect a signal on those inputs. This either means the tv has an issue and can't receive an HDMI signal(very unlikely) or there is no signal being sent from the source(converter box) The first thing I would do is unplug all output connections from the box except for the HDMI output and see if this gets rid of your problem. If not, I would be more inclined to think you have a problem with your converter box than with your TV. You could also try using the HDMI ouput of a DVD player if you have one.
Jan 14, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Televison & Video Logo
118 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
