Power went off now monitor is giving check cable error
I have had this problem before and am never sure how i fix it. Mains tripped and then error message shown
    Top Expert:
  • 6,702 Answers
Perhaps you try to switch of all devices and start switching them on one at the time. Starting with the TV and then the other devices. Switching of is like a cold boot. If there is no on / off switch, please unplug the device and reinsert the plug after a few seconds.
Posted on Nov 19, 2014
My Aqualtis AQGD 169 S keeps tripping the mains switch
Make sure you are on a dedicated circuit for this machine and that it is a 50 amp circuit. After that you may have a bad breaker switch which is pretty easy to fix. You also cannot rule out that one of your components went bad on your washer.
Feb 28, 2015 | Washing Machines
Power went off no monitor is giving check cable error
If you're seeing a "Check Cable" message on the monitor - it's working. If this message appears, it means the monitor isn't receiving a signal from the computer. Cable could be loose, or video circuit has failed.
Nov 19, 2014 | Computers & Internet
GW708U Fisher and Paykel Washing machine Power Controller board trips earth leakage breaker
Hi your pump may be leaking the earth to trip breaker.
Check or replace the pump.
Feb 04, 2013 | Fisher and Paykel Washing Machines
Hi, We have recently purchased a Behringer PMP6000/VP1220/VP1220F PA package we have a pair of speckon to 1/4 TS connectors and a pair of 1/4 TS to 1/4 TS connector cables we have the mains on tripods and...
Please read a tip I just posted regarding a hazard of the Speakon to 1/4 inch cables when used with these PMP mixers.
If you are using your main speakers as stereo, then you will need either powered monitor speakers OR an additional seperate amp for them. The mon outputs on the mixer are LINE LEVEL and are not driven by a power amp. Use TRS (balanced) interconnect cables from these to POWERED monitor speakers.
You can parallel your two mains providing the parallel impedance is 4 ohms or greater (two 8 ohms in parallel at most). The the monitor speakers can be paralleled and the switch set to Main/Mon so that one side of the power amp drives the mains and the other drives the monitors.
To prevent damage to the mixer, make sure all speaker leads are secure before powering the system. Run the speaker leads through the handles of the speakers to prevent inadvertent unplugging due to personell tripping over cables.
DO NOT use the bridge mode in your use.
Aug 07, 2010 | Behringer Europower Pmp5000 Powered Mixer...
My DELL flatcreen just went blank and is now flashing yellow light, won't turn on
Check and make sure your connections on the back of the PC are snug...and make sure you have a good connection at the back of the monitor.
Flashing light...is loss of signal.
Good Luck,
Mike
Nov 06, 2009 | Dell 1702FP UltraSharp 17" TFT LCD...
I have a Neovo X-17AV LCD monitor that just went blank. Powered off, then on again, and get a "no signal" post then blank. Tried on another comp. same thing
First of all your VGA cable might be faulty if it is showing you "No signal" Please try to check your LCD menu and try to set some colour bars and audio tone if you get any one of these happen, then your LCD is ok and only the problem is replace your VGA cable.
Please revert back incase you find any issue and next time please write more and in details to understand your problem.
Thanks
Ashish
Oct 28, 2009 | Neovo AG 17" LCD Monitor
No power - suddenly went dead, no green or orange power light.There is mains power at the monitor's power input socket.
Check all caps in power supply. Look for the tops of the caps to bulge. Replace any that looks or smell bad, like a sulfur smell. Make sure you put them in the right way. I usually increase a cap that blows. If its a 16v I go to a 25v or a 25v to 35v. keeping the same ufd. Because of the surge, off and on, It helps.
Oct 26, 2009 | ViewSonic VX924 19" LCD Monitor
Bosch exxcel
The likely cause of this is a failed heater element which would cause the fuse to blow. You will need to get the heater element checked out and replaced if necessary. A visual inspection of the element may reveal the problem jf not an electrical test will be necessary. Be sure to switch off the power before touching the heater element.
Oct 20, 2008 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
No display
check the power cable, whether pluged well or not remove the monitor cable which is connected to your CPU only pluged the power cable and watch the LED status and let me know
Oct 10, 2007 | Proview PS 720F-1s (Silver, Steel Blue) 17...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
