Question about Gentex 2008 Infiniti EX35 - All EX35 models - K5 Auto-Dimming Rear View Mirror w/Compass
Where is the thermostat on a 2008 Infiniti ex35.
The exact location of themostat
  • 9,639 Answers
The top radiator hose connects to the engine. Under that connection is where the thermostat is. Take off the hose and look inside. That is the thermostat.
Posted on Nov 19, 2014
Where is the thermostat location on my infinity j30 1993
Chris, 1993 infiniti J30 thermostat location. Follow large radiator hose to intake manifold by water pump, at the end of the rad hose is the thermostat housing. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Replace the Thermostat in an Infiniti J30 eHow
Thermostat Replacement Write Up
Infiniti Thermostat Replacement
Aug 28, 2016 | Cars & Trucks
Why does it die when turning left after stopped at traffic light?
Go to your browser type in 2008 infiniti FX35 diagnosing intermittent stalling issues ; and its by UNDERHOOD SERVICE . It tells what you should check . hope this solves you problem .
Dec 22, 2015 | 2008 Infiniti EX35
I have a 08 infiniti ex 35 journey with 75k,it had an overheating right now has a bubbles on the radiator at engine satrted ,white smoke in the morning associates to water occasionally. My question is ,if...
Yes a head normally can be milled (shaved) down and a new gasket installed to fix the engine. Be sure to fix WHY it overheated too. Of course change oil and coolant too!
Mar 23, 2015 | 2008 Infiniti EX35
How do I remove my mechanical key from my in dash intelligent key port
gee I believe a dealer might now that one they are just a phone call away too
Feb 27, 2015 | 2009 Infiniti EX35
2008-infiniti-ex35-service-repair-Car-manual
books dont do noise. well.... 100s of causes.
and systems to make noise. 3000 parts on car. so.....
its a hands on deal.
i use a $50 electronic stethoscope.
step 1 find exact location of noise.
and work from there.
Mar 12, 2014 | Vehicle Parts & Accessories
Where is thermostat located in the Suzuki Reno 2006
see radiator
see large hoses,
huge.
one goes directly to the themostat housing. (usually top hose)
(varies by engine option ,exactly on all cars made)
Feb 20, 2014 | Suzuki Forenza Cars & Trucks
2008 infinity ex35, auto. the veh. rpm drops and stalls when coming to a slow, stop sign etc. but it will start right back up every time. the problem is getting more frequent and there is no dtc. please...
fast idel motor inoperative and a conflict in the PCM soft ware which needs reprograming with updated data or too little fuel in the gas tank which slosh away from the pump , athrottle valve pin damage from improper cleaning method and it is not supposed to be cleaning by operating with ouer hand which may misled the PCM wher were the actual position in which it were told by the pre programmed memory data which is out of caliberated settings!
Jun 01, 2011 | Infiniti EX35 Cars & Trucks
Need to know to replace themostat in 2004
Drain the radiator, follow the top radiator hose to the engine, it is connected to the thermostat housing. Loosen and remove the two bolts, lift the housing and remove thermostat, make sure the new thermostat goes back in the exact same way, tighten bolts, make sure pepcock is closed on radiator, refill radiator, start engine, run heater on full blast, add coolant as needed.
Dec 22, 2009 | Chevrolet TrailBlazer Cars & Trucks
How do i change thermostadt on jeep cherokee
  1. Follow your upper raidator hose untill you find the themostat housing which is the ending point for the hose.
  2. Remove the two bolts that hold the housing (you may have to loosen the belt to get to one of the bolts).
  3. Remove housing and replace themostat and gasket ( remove any excess gasket that may have been left over ).
THE DETAILED PROCEDURE IS GIVEN BELOW
  1. Open draincock on the radiator to drain the coolant from your Jeep Grand Cherokee. This draincock is located on the lower right side facing the rear of your Cherokee.
  2. Use a sealable container and reuse the coolant if it is relatively new and clean.
  3. Follow the upper radiator hose to the point where it meets the thermostat housing. The thermosat is located inside the housing.
  4. Use a clamp tool or vise-grip pliers to loosen the clamp holding the hose to the housing. Work the end of the radiator hose free of the thermostat housing.
  5. Remove two bolts holding on the thermostat housing cover. Pull off the cover.
  6. Take note of the position of the old thermostat. Remove and install the new thermostat in exactly the same position.
  7. Scrape off residue of the old thermostat gasket from the inside of the thermostat housing cover using a razor blade. Avoid getting any debris inside the thermostat housing.
  8. Install the new gasket. Reattach the thermostat housing cover and radiator hose. Start your Jeep and run the heater on high. Allow the engine to warm up. Check for leaks.
Nov 08, 2009 | 1996 Jeep Grand Cherokee
Gentex 2008 Infiniti EX35 - All EX35 models - K5 Auto-Dimming Rear View Mirror w/Compass Logo
79 people viewed this question
Top Gentex Optics Experts
Lawrence Oravetz
Timllfixit
ka4iup
ka4iup
Are you a Gentex Optic Expert? Answer questions, earn points and help others
