Question about Coleman Heating & Cooling
I have a Coleman Echelon 9.C Series furnace that is blowing cold air. The red light flashes 5 times and the green light is flashing slowly.I had it checked several times by techsbut that can'
Had techs check it out
    Novelist:
    Champion:
  • 373 Answers
This code Signifies that your furnace's ROLL-OUT-SWITCH or auxiliary switch, may be open. This switch can be reset by pushing the center of red button on your furnace roll-out-switch. Make sure the heater has been cleaned out good, make sure the flue is clean, have the service company check to make sure there is not a cracked heat exchange. Call a reliable service company, not the cheapest there is no reason that they can not find the problem unless they are not qualified. If you have had a company out for the same reason and you have payed them to fix it then they have to fix the problem.
Posted on Nov 19, 2014
Testimonial: "I have since learned that this is a common problem with this furnace and they have not figured out what is causing the problems and they are now replacing the entire unit."
2 Suggested Answers
SOURCE:
  • 3421 Answers
SOURCE: coleman echelon 9.T furnace will not turn on. Red light blinking
sounds like it is the pressure switch try jumping it out on some models you fool the heater in too working or see if the tubes are blocked , there should be some codes on the front panel or the fan panel
Posted on Apr 27, 2010
I have a coleman/evcon model DGAT070bdf I have the thermostat set at 74 but furnace is shutting off at about 64 degrees I did notice that the mother board's green led light is blinking 4 times.
Steady light on - normal operation.
One flash - ignition failure.
Two flashes - combustion air switch stuck closed.
Three flashes - combustion air switch failed to close.
Four flashes - limit switch open.
Five flashes - gas valve energized with no call for heat.
Rapid flashing - reversed polarity.
Note: Color of light is green.
Oct 14, 2018 | Heating & Cooling
Combustion switch error on windy days
check gas pressure and flame sensor
Jan 06, 2018 | Coleman Heating & Cooling
Fuel gauge went nuts, ran out of fuel. Replaced sensor in tank. Still bad. Fuel gauge stuck on half now. No faulty wires to find. Tech says control panel is fine. Help 2000 dodge 2500 ram diesel
Fire tech and get a new one. LOL
Did that get checked and replaced by a Tech. ?
Fuel sending units are real easy to check with the ohm meter replacement may not have been necessary at all
Nov 06, 2016 | Dodge Ram 2500 Cars & Trucks
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
Machine is flashing f-28
Is this a top or front load? If it is a top load, there should be a tech book for the unit either behind the control panel, or inside a clear plastic bag, located somewhere on the inside of the cabinet ( tilt machine back and look up from underneath. You should look toward the top, front of the unit). The tech book should list all the error codes and tell you what and where to start checking. If it is a front load machine, you can remove the very top, and you should see a tech book on top of the dispenser assembly, or on the underside of the top in a clear plastic bag. Sometimes the tech book is on the back side of the front, bottom access panel ( located under the door). Again, the tech book will have all error codes and what and where to check. Good Luck!
Mar 05, 2015 | Maytag EPICz 3.7 cu. ft. Washer
Pick up roller
4.1.4 Tech Mode
In service (tech) mode, the technician can check the machine and perform various test to isolate the cause of
a malfunction. While in Tech mode, the machine still performs all normal operations.
To enter the Tech Mode
To enter the Tech Mode, press "Menu + Back + Left + Right + OK + Stop + Menu" in sequence, and the
LCD briefly displays 'Tech Mode', the machine has entered service tech mode.
After entering the tech mode, select the item you want by using a button on control panel.
Scroll to Pickup roller.
I cannot see what comes up on the screen after this but I imagine it will ask if you wan to reset this counter. Press ok and that should do it. You may need to power down but I don't know.
Good luck.
I cannot see what it says on the lcd after this but I imagine
Jan 27, 2014 | Samsung CLP-620ND Color Laser Printer -...
Luxaire by York Furnace,Model# G8T10012UHB11A,8 Red LED Flashes = Ignition lockout due to recycles,Has flame for a few seconds then goes off; does it around three times,Fan is working; blowing cold air
It sounds like you have a dirty or bad Flame Sensor. They sometimes get a white coating on them. It's not detecting a flame so it shuts off. Sometimes you can clean them and they will work.
Nov 06, 2012 | Coleman Heating & Cooling
Heating & Cooling Logo
706 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Paul
Paul
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
