Why doesn't an aux cable work in my neon tv - Audio Players & Recorders
    Top Expert:
  • 6,702 Answers
An AUX input on a receiver expects a signal from about 1 volt P P.
So if you have a signal about 1 V. put it in on the AUX. If it is less, try another input. On AUX nothing comes out. So don't mix up in and output.
Posted on Nov 19, 2014
Volume problem--laptop to tv
I'm confused, are you trying to use a VGA cable for both video and audio? VGA cables don't have sound built into them, nor do DVI. If you had an HDMI plug on your laptop it would be best to go with that since HDMI contains video and audio.
You could just use an Aux cable from laptop to TV. Pretty much it would be a aux to analog type. It's like a speaker plugin, that side is for your computer. Then the other side coming out would be an analog red/white or left/right cable.
Another one, if your TV supports pure aux cable (it's a 3.5MM jack that speakers plug into) Like, my tv has a built in aux port for audio for my computer. So I just use pretty much a standard cable to cable setup.
Feb 24, 2013 | Toshiba Satellite Computers & Internet
I'm plugging in an active speaker to aux 3 of my fx16ii, but it doesn't work. I have it set up the same as aux 1 and 2 where I'm also running active speakers (for monitors). Am I missing...
If you look at the signal flow diagram in your user manual, you will see that while AUX 1 and 2 can be selected are PRE or POST fader, AUX 3 is POST fader only... this means that the channel faders control the AUX3 level as well as the aux out level. Make sure you use TRS balanced lines to your speakers and not TS cables.
Sep 02, 2011 | Soundcraft FX16ii 16Channel Audio Mixer
I'm trying to plug an active speaker into aux 3 for a third monitor mix but it doesn't work (I do the same with aux 1 and 2). Am I missing something? Cheers,
I answered another post of this earlier. The AUX3 is strictly POST FADER... you MUST turn the channel sliding fader up to send signal to AUX 3. Also the AUX3 channel gain KNOB must be turned up. Also the AUX master gain KNOB must be turned up. Make sure your cablles are balanced TRS cables from the mixer to the powered speakers.
Doesn't show anything on TV
I am sure that your cables are connected correctly. If they are your TV and DVD/VCR palyer has to be on the same function. i.e. aux on the newer TV's or channel 2 or 1 on the older models. THis is a easy fix and this will start you on the right track.
Jul 16, 2011 | Toshiba SD-V296 DVD Player/VCR
I have a cable box...(hddvr) and a TV cable set it up on video 2 now i bought a insigna home sound, how do i hook it up the user guide only shows me how to hook it directly to TV and its not working, so...
First, if you have the jacks in back of your TV for audio out, you may have to set the audio on the TV for external audio. Go to menu and then click on audio or audio options, and see if there is a mode for external or aux audio out.If that does not work, then use cables with the RCA ends and hook up from cable box to audio in or aux in of your surround sound system. Look at the back of the cable box for audio out or aux audio output and connect these two jacks to the audio in or aux input of your surround system.
If the cable box does not have extra audio out, you can take Y connectors and branch off the two jacks that are going to your TV. Radio Shack has these Y connectors. They allow two cables to be connected to one jack.
Hope this helps, if so Please rate, and Good Luck!
Aug 02, 2009 | Audio Players & Recorders
Will play dvds with sound fine...but no sound from tv
You have to connect extra red & white audio cable from your TV's (or cable box, if you have one) AUDIO OUT to the Home Theater's AUX IN 2 at the back (below Video In). Set the HTS unit to AUX 2 using the AUX button on the remote control and you should be able to get sound.
Jun 14, 2009 | Samsung HT-P38 System
Home Cinema Samsung HT Z310R- Speakers not working with TV
You need just one cable that goes from your TV to your HT system.
On your TV you should see an RCA jack for "AUDIO OUT" and you need to plug that into your AUXILLARY "AUDIO IN" on your HT system
When you are watching TV and you want the sound to come through the HT system, just set the HT system to "AUX" mode. Most Samsung systems will have 3 'AUX' modes, set the remote on 'AUX 1' then wait a few seconds, if no sound comes through then set it on "AUX 2" wait a few seconds and if it doean't work try AUX 3.
Hope that helps.
Gary
Feb 11, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
I have an old Sansui au999 amp
you can go about this many ways.depending on what you have to work with.are you useing a satilite or cable box?if so assuming they have audio/video out just send the audio to the amp and the video cable to the tv.u could use the aux or the tape in.just put the dvd in the other input aux or tape in.dont matter which.if you dont have a cable box your tv must have some kind of audio out to run to the amp.it can be a rca out or simply a headphone jack.you will need a headphone jack too rca plug cable if you have a headphonejack on your tv.hope i could be of help.
Jan 05, 2009 | Sansui Audio Players & Recorders
Can't play AUX inputs through Panasonic surround sound
Check the TV audio output setting. There may be 3 settings for audio output. Fixed/variable/none. Try all of the settings, and see if you get your audio back. If not, try a different cable between the TV and DVD player. I suspect this is a red/white RCA audio cable.
Dec 12, 2007 | Audio Players & Recorders
65 people viewed this question
 Grubhead
Grubhead
