I NEED A roller bushing,where can I GET PARTS?
Sound wavers on play back
Did you try a different tape?
May 14, 2014 | Audio Players & Recorders
Can anyone give me installation instructions for a pickup roller assembly on a HP m3027x mfp? Part number 5851-4012 (formerly RM1-3762).
Tip the device over on its rear side, with the top of the device facing you.
2. Rotate the bushings on each side of the roller upward.
3. Remove the left-side bushing by sliding the bushing to the left.
4. Slide the roller and shaft toward the left until they clear the hole in the right-side bushing, and then
lift the right end of the shaft.
Slide the roller and shaft toward the right, and then lift the roller and shaft together out of the device.
Oct 24, 2013 | HP LaserJet M3027 MFP Printer
How to remove and replace a printer roller on HP Laserjet p3005
Hi Adam,
I suspect that you are talking about the tray 2 pick up roller. Here are the directions for that:
1.)Remove paper tray
2.)Unlock left locking tab and rotate forward untill bushing slides off
3.)Remove black plastic roller retaining bracket
4.)Slide roller to the left untill right side of shaft clears the bushing
5.)Lift roller out of printer
6.)Place spring loaded end of roller shaft into left housing
7.)Slide roller to the right and rotate until roller locks into pickup shaft
8.)Reinstall black plastic roller retaining bracket. Left side first.
9.)Reinstall left bushing and lock into place
Let me know if you where sucessfull,
Printer Piete
www.allprotech.com
Dec 28, 2010 | HP LaserJet P3005 Printer
Canon 6551 copier-rollers are grabbing & cause smear
check the paper path roller and check the bushing, this is a picture of bushing: mabroukmedal_43.jpg
the roller that you need to check:
Dec 21, 2010 | Canon NP 6551 Black and White Copier
Canon 6551 copier-rollers are grabbing causing smear on the copy
check the paper path you need to control the main drive mecanism, and all bushing roller : registration roller, pickup, fixing and exit: you can see exemple of the bushing to check: mabroukmedal_41.jpg
the roller that you need to check and replace the bushing:
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
I have an Amana gas dryer that is squeaking. Does something need to be lubricated? If so can I do this myself?
Good Afternoon,
Lubricating would be just a temporary fix. You need to replace the drum rollers. If you think you can do it yourself I'll try to walk you through it. Once the rollers are worn they start squeaking and squealing at a very high pitch. This happens because the roller bushing spinning on the shaft has dried out from the heat. The weight of the clothes in the dryer plus the drum itself rests totally upon these rollers. If you decide to install new rollers clean up the shaft with lite emery cloth then wipe clean. Next apply "High Heat" Lithium Grease to the shaft and inside the new roller bushing, they will last 2 to 3 times longer. Let me know if you need guidance if you attempt to change the rollers yourself.
Have a great day!
Mar 26, 2009 | Amana ALG331RAW Gas Dryer
Xerox Workcentre XD100 Accordion Jam After A Few Copies
What is most likely happening is the pressure and heat roller bearings and bushings are very gummed up.
When you remove a the fuser when its cold, try turning the heat roller gear, I would assume it is very very tight to spin.
What you can do it take the fuser apart, soak the pressure ( soft roller) roll bearings in some alcohol and then clean the heat roll ( aluminium) roller bushings and the end of the heat roll. Make sure you lubricate with some silicon lube the ends where the pressure roll mounts into the small holes in the nip fingers. That should help.
You can call a business called , ( you can google, The Parts Drop) and talk to Britt there. I am pretty sure he has the bearings for that machine. I don't work there, just have done business with them for years and they are top knotch.
You probably want to replace the gear also. Sometimes it can look really good, but be worn just enough to cause a problem.
Make sure you take a real good look at the condition of the rollers before you spend money replacing small parts, so that you don't wind up replacing 40 or so dollars worth of parts only to find out you do need the entire fuser.
Nov 29, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
UF-8000 jamming and not transmitting consistently
what exactly is the error code on your machine, and if you replaced some of the fuser parts already you might have pinched the ribbon cable by the fuser
Nov 04, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Replacing paper pickup roller
on both sides of pickup rollers there are white bushings rotate the white bushings towards you
then lift the right end of the shaft.
Slide the roller and shaft toward the right and lift the roller and shaft together out of the printer.
install your new roller then reverse this process to reinstall
Oct 21, 2008 | HP LaserJet 2430n Printer
43 people viewed this question
k24674
jasbo
jasbo
