Question about Frigidaire Washing Machines
Our Frigidaire front load washer is only 4 yrs old and we are having trouble with the final spin cycle. It turns ok but when it is done there is water in the bottom of the basin and all the clothes a
Nothing
  • 720 Answers
Sounds like the rinse hold button is selected.if that is okay check the penny trap at the bottom front of machine.this will collect buttons coins etc and prevent proper drainage.if not then the relays on the pcb board have probably failed as the machine usually does not reach proper spin speeds as a result.really about checking through the above.replacement boards are expensive but sometimes it is possible to source parts from eBay.
Posted on Nov 19, 2014
  • 10 Answers
SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Posted on Dec 15, 2007
  • 25 Answers
SOURCE: load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Posted on Feb 16, 2008
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
SOURCE: Kenmore Front Loading Washer Slow Final Spin Cycle
I have exactky the same problem Replaced the drum and now it will not final spin, I touched nothing else.Can't figure what could be wrong,speed board too sensitive?
It worked fine before the bearing went.
Any ideas?
Posted on Aug 22, 2008
SOURCE: Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
Posted on Sep 24, 2008
Washer wont spin out clothes when it is in the final spin
i have a atf6000fs1...I washed a load and i thought it was done but items were still wet. So i turned on the spin cycle and it flashed err and turned itself off. It wont run. Any suggestions???
Oct 24, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer will not spin out, it is not flashing
intersting when mine did this it was the pump... maqy i ask how you checked your pump? and can they be cleaned i just had to replace mine and its only 2 yrs old, i dont want to have to replace every 2 yrs
Dec 30, 2009 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire Model fails to spin after wash
my washer had same problems, turned out to be door lock switch. around $75.00. Washer 2 years old. Questioning quality also.
Dec 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Final spin cycle does not work
The motor controller is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 07, 2009 | Kenmore Elite 45986 Front Load Washer
Frigidaire front load washer not spinning
Unsrew the bottom panel and u will find the pump to the right disconnect the hose from the back thats coming down from the tub.You will find a pocket behind the hose connect filled with all kinds of change probably enough to buy a pizza and a couple of beers. I also had a old credit card,gas pass bobby pins,hard plastic tags.chains and a hand full of sand.
My Frigidaire frontloader is 9 yrs old was close to buying a new one but this defintly fixed the problem..
works like new again.
Dec 16, 2008 | Frigidaire ATF6000ES Front Load Washer
Load noise in final spin cycle
Feb 14, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
