RCA LED 19 TV MODEL DETK185R Usb port was disabled from the factory is there any way to turn ot on
    Problem Solver:
  • 8 Answers
Disabled? What do you plan to use it for? They are used for servicing the tv. They also provide power to peripherals such as chromecast
Posted on Nov 19, 2014
3 Suggested Answers
tthekraut
  • 374 Answers
SOURCE: 19" LED TV INSIGNIA HD
I have one of the same tvs. Start by going under menu,setup,tuning band and set it up for antenna. When you get that far put in auto channel search. To see how to get best reception where you live go to http://www.antennaweb.org
Comment if you need any further help
Posted on Mar 17, 2010
  • 8909 Answers
SOURCE: just bought a 42 inch
Possibly copyright issues?
Posted on Dec 31, 2010
I have a RCA LED TV model# RLDED4213A. it looks like it has a USB Port. B ut i cant get it to work. The TV doesnt recognize the flash drive. any ideas?
Make sure that the flash drive is formatted compatible - for example NTFS will not be recognized by a FAT32 system. I suggest researching the tv and find out what kind of system it uses to read files and then make sure your flash drive is compatible.
Apr 02, 2015 | RCA Electronics - Others
Rca 19 inch led tv model detk 185r usb port wont work
Check your manual to see if the USB port is used for anything else besides upgrading the software in the TV. Some do and some don't.
Nov 19, 2014 | Televison & Video
How do i adjust picture quality settings TV
Find your owners manual that came with the television, it should have all this information in it.
May 15, 2014 | RCA 19LB30RQD 19-Inch LCD 720p 60Hz TV
NEED SOFTWARE FORMATS FOR RCA 19" CLASS LED HDTV DETK185R
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 28, 2014 | RCA 19" Class LED 720p 60Hz HDTV 1.7"...
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
Apr 15, 2013 | RCA Detk185r 18.5" Led Hdtv
Where do I plug in headphones?
Looking at the specs for your TV, it does not appear to have the jack for earphones.
You will have to connect an audio receiver to your TV and use the reciever's jack.
Connectivity
  • HDMI ports qty4
  • PC interfaceVGA (HD-15)
  • Input/Output connections3 x HDMI (19 pin HDMI Type A) - Rear,
    1 x HDMI (19 pin HDMI Type A) - Side,
    2 x Component video input (RCA phono x 3) - Rear,
    1 x Composite video/audio input (RCA phono x 3) - Side,
    2 x USB (4 pin USB Type A) - Side,
    1 x Ethernet (RJ-45) - Rear,
    2 x Audio line-in (RCA phono x 2) - Rear,
    1 x VGA input (15 pin HD D-Sub (HD-15)) - Rear
  • Video interfaceHDMI,
    Component,
    Composite
Jul 14, 2012 | Samsung PN50B650 50-Inch 1080p Plasma HDTV
I deactivated my usb ports coz my sister puts a lot a of virus thru her USB. Thru bios i deactivated itnow i cant use my keyboard anymore. how can i active it again?
You have to go back to your bios setting and re-activate the usb ports, try getting usb lock software to lock the usb ports rather than disabling them.
u can get one following this link
http://www.4shared.com/file/hiuMteKe/USB_LOCK_AP_23.htm
Jan 10, 2011 | Computers & Internet
Hello-I have a 19" Philips flatscreen LCD television set model#19PFL3504D/F7. After attempting to upgrade current software via a USB flashdrive I reversed the disconnect instructions. I removed the...
connect a laptop to the set, using the usb port contact phillips on line download the old flash to the computer save the old flash download as a file and, to the usb flashdrive connected to your laptop reload the set either with the laptop or, the flashdrive unplug the set first then: remove the flash drive
Jul 17, 2010 | Philips 19PFL3504DF7 19 in. TV
My d52w20b rca tv will not turn on and if you hold down the power buton down the led flashes a code 19
All the ITC222 series will blink 19 if they have a no start situation regardless of the problem, Since the set wont power up the Main eprm cant communicate so it blinks 19 which means it cant identify the chassis. When you press the power to turn it on does the power light come on briefly then go out 3 times? Let me know and I will assist you with the problem. Also do you hear any sounds when the power is pressed?
Nov 27, 2009 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Electro Med Services...
