My totaline thermostat model #p474-0100-a the backlight is staying on and when the furance is running after only a couple of minutes it shuts off and my furance shuts down .
I just had the motor replaced in the furance .When i light the pilot light and turn the furnace on , long before it reachs the temperture its set on the furance just shuts down pilot light also , the backlight on the thermostat is staying on and a black haze is covering the green
  • 15,756 Answers
Multiple issues that are not related. If the pilot light goes out then the thermocouple might be bad. If the pilot ignites the gas and everything shuts off, it sounds like the over temperature sensors are detecting heat in excess of what is allowed in the firebox. The thermostat issue has nothing to do with this.
Posted on Nov 19, 2014
Totaline P374-1100, backlight not working
Are you referring to the thermostat? If so pull it off the wall and see if it has battery backup, most all do.
Oct 12, 2016 | Heating & Cooling
Thermostat Totaline P7470100
It's probably the liquid crystal has a crack and is flowing inside the glass. It can only be repaired with a new display.
Why not contact Totaline directly and see what they can offer?
Contact Us Totaline
Jul 21, 2016 | Heating & Cooling
How do I get the thermostate out of the Hold mode?
[PDF]Troubleshooting Common Thermostat Problems - Totaline
https://www.totaline.com/dl/troubleshooting_signature_star.pdf
When the temperature limit is exceeded, the furnace shuts off the burners ... buttonthermostats, hold Mode and Fan (or Mode and Override) for SEVEN seconds.
Sep 25, 2015 | Heating & Cooling
Why is my totaline thermostat flashing fd and not working
Factory Default. Your thermostat is halfway through the factory reset procedure for some reason. Check out the cheat sheet here:
http://www.totaline.com/dl/stat_setup_cheat_sheet.pdf
DON'T FORGET TO REPROGRAM YOUR THERMOSTAT SO IT WILL ACT THE WAY YOU WANT IT TO AFTER IT IS RESET!
If you don't know how to, just look at the cheat sheet cited above or find the model number (inside the case) and search google for an operation guide.
Jan 05, 2015 | Heating & Cooling
I have no idea how to use my totaline digital thermostat,
Totaline is a brand name of the Carrier Corporation. Go on www.totaline.com and research the model of your thermostat. User manuals are available.
Nov 11, 2013 | Heating & Cooling
Bakers pride deep fryer will only stay lit for couple of minutes and then shut off
Hi there!
Normally hi limit sensing bulb is thicker and shorter than that of thermostat.
Try tightening all wire terminal crimps and connection.
Regards.
Feb 05, 2013 | Imperial IFS40 Deep Fryer
Have a gmp125-4 furance blower runs all the time checked themostat wires error code 1 blink then 2 then 3 then 5 furance works if you turn power off turn back on when heat kickes off blower comes on gives...
Sounds like limit switch issue. Furnace heats up, high temp limit switch opens, fan will stay on. GMP model is older and do not have the codes.
May be over fired, have airflow problem, to cause the limit to open.
Next time before shutting off power, try to find the limit, it has two wires that connect to a 1.5 x 2 inch card mount to the furnace fire wall. tap on it and see if the blower stops. If so replace the limit.
Sep 06, 2011 | Goodman Heating & Cooling
AC IS TURNING ON BY IT SELF AFTER I SWITICH IT OFF, HOW TO SOLVE THIS PROBLEM
Sounds like a problem with the furances circuit board. With the furance powered off, disconnect the two wires at the circuit boards thermostat terminal strip. These are probably red and white wires connected to the "Y" and "C" thermostat terminal strip on the circuit board. These two wires send 24 volts to the outside A.C. condenser unit when the thermstat is se tinto the cooling mode. With the thermostst in the "off: postion measure across the "Y" & "C" terminals at the furances thermostat terminal strip. If you have voltaged than either the board or thermostst has failed. The next step to determine which has failed is this. Disconnect all the thermostat wires at the furance. To check the heating circuit jumper across the "R" & "W" terminals, the furance should fire off for the heating circuit and run non stop beacause the thermostat is no longer controlling it and is isolated from the furance. Now remove the jumper and jumper across the "R" &"Y" terminals, the blower should run at your furance for the cooling mode and you should have 24 volts across the "Y" & "C" terminals for the outside A.C. condenser compresor contactor.Next check for blower operation by jumpering across the "R" & "G" terminals. If everything checks outs than the thermostst is the problem. Tou may also want to check the control wiring at the thermostts , furance & out side condenser unit. If the wiring has connnected somewhwre between these points or at the terminal connection this may also be bring on the A.C. when the thermostat is in the "off position.
Feb 13, 2011 | Hitachi Heating & Cooling
Furance won't lite
The first thing i would do is turn thermostat down and turn power off wait for a few minutes then turn power back on and then thermostat back up. If it has a ignition module then there should be a blower motor. It should come on then a pressure switch that should click then the ignitor should glow or spark. there should be a round glass circle that you can look through to see the ignitor
Apr 04, 2008 | Goodman GMS90703BXA Heater
Totaline Thermostat
Hi, My totaline thermostat says EH on it and will only heat. No AC. any suggestions. Previously my AC repairman came out and added Freon into the unit. But did not fix it totally either.
Hot In Atlanta
Oct 26, 2007 | Computers & Internet
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
