Question about Refrigerators
I bought a fridge from liquidation a Kenmore model #59649539018 freezer works finebut the fridge is not cooling they changed the control panel but still not working
  • Refrigerators Master
  • 15,557 Answers
There should be a fan in the freezer that moves cold air into the fridge. The fan might not be working. The temp setting for the fridge is a door that opens and closes depending on the setting. Check to make sure it works.
Posted on Nov 19, 2014
2 Suggested Answers
  • 93 Answers
SOURCE: Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Posted on Sep 13, 2009
Kenmore top fridge not cooling bottom freezer working fine
Do you see ice on the back of the freezer wall?
Oct 18, 2012 | Kenmore Refrigerators
Kenmore 795 freezer on top. Freezer working, temp lights on in fridge, but fridge not cooling and lamp out as well.
If the freezer is located above the fridge, the air from the freezer drops into the fridge to create the cooling in the fridge. So what I would look for is a blocked vent from the freezer to the fridge, which is usually located on the top and or back of the fridge inside of cores. You can get a frost or ice build up in there and block the air flow to the fridge, that is usuall the problem. I would also heck the dial for temp control in the fridge, I know my kids have changed it before on me.
Sep 07, 2012 | Kenmore Refrigerators
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Freezer works great, but the refridgerator is not getting cold.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Kenmore Refrigerators
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
first off unplug ref and melt the ice with a blow dryer.then check your defrost circuit,it is easier to check with the ice gone.
Dec 22, 2008 | Kenmore 71812 / 71814 / 71819 Bottom...
Refrigerator is not cooling
Hello hazraan
Welcome.
You said your Kenmore model 60852990 freezer is working but refrigerator is not cooling.
Lets try a couple of ideas.
Is your freezer filled up where the packages are covering the air vents in the rear of the freezer?
Refrigerators and freezers must share the cold air and circulate between them. If the freezer is packed full with not enough space at the air vents in side it, the fridge will get warmer!
Next,Turn off the fridge and freezer controls, and then go to the breaker box and turn off the breaker to the fridge for 5 minutes!!!!!
Then restart it and the fridge and freezer controls.
This should reset the system and solve the problem. let me know if either were the case.
If either was the reason,it now will take some 8 to 12 hours to gets back to temperature.
Waiting your response.
Huuum, Please remember to leave a rating.
Oct 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Warm refrigerator/freezer
very good chance it is the same problem or possibly a leak of refrigerant due to joint failing where compressor is joined to pipework
Jun 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore Model # 596.735032.. Fridge is cool, Freezer is not freezing
After pulling the fridge away from the wall and removing the lower right hand panel I noticed that the compressor (big round black ball with copper tubing) was not turning on. I also noticed that there was a ticking or popping sound comming from it every couple of minutes or so. After doing some research online in numerouse forums I decided to try and replace the overheat relay that is attached to the compressor. It only took maybie five minutes at most to change it and the compressor is now working with nice cold air comming into the fridge and freezer. Hope this helps someone else with the same problem.
May 06, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
