Question about Vitapur Water Dispenser. Hot, Room and Cold Water Dispenser Stainless Steel VWD5446BLS
<!-- from fixya rte -->My vitapur water is not hot - Vitapur Water Dispenser. Hot, Room and Cold Water Dispenser Stainless Steel VWD5446BLS
I cleaned my water cooler with vinegar but the water still taste bad. What can i do ?
it it is a plumbed in unit running off utility water supply, there is a small ceramic water filter assembly that can be fitted into the water inlet side of the unit
because it is extremely fine it removes the contaminates that make the taste if that doesn't work you can fit in tandem a charcoal filter after that ceramic to guarantee perfectly clean tasteless water
add to the fact that every 12 months ( depending on volume usage) the ceramic filter can be removed and the contaminates scraped off the surface using a knife which regenerates the filter
if it is bottle feed then clean out the holding tank using bleach, wash thoroughly and allow water to run from both taps for a few minutes to remove all residue bleach , the fit new water bottle
spare bottles are subject to algae growth ( taste ) if stored in a well lit area so store spare bottles in a dark room ( closet , under bench etc )
Jul 12, 2016 | Greenway Vitapur Point-of-Use Water...
Vitapur manually cool lite is not on
You have a model number ? is it VWD9506W-POU
VWD9506BLS-POU
if it is the cool light is off because the water is cooling to coldest temperature . See the manual here.
http://www.homedepot.com/catalog/pdfimages/2d/2d629539-f891-45c8-8493-fdc50aff5a84.pdf
Aug 16, 2014 | Refrigerators
Water cooler runs for 20 sec and then stops says that bottler is empty. not pumping water?
either you faild to unpack it properly and left some thing in the dispenser area where the bottle drops in. It doesn`t pump water, it gavitys out of the bottle.
Apr 23, 2014 | Vitapur Energy Star Bottom Load Water...
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
My Vitapur water cooler hot water doesn't produce hot water anymore and the light just blinks how can I fix this
It may have a thermal fuse inside. They are usually either a inline cylinder or a press-fit cylinder in shape. They will have a maximum temperature in either Celsius or Fahrenheit. We carry the inline cylinder shaped ones at my store (www.we-supply.com) from NTE, but you would need the part number to find them on my website:
Thermal Cut-Off (TCO):
NTE8070 TCO - 72c/162f
NTE8081 TCO - 84c/184f
NTE8090 TCO - 93c/200f
NTE8096 TCO - 98c/209f
NTE8098 TCO - 100c/212f
NTE8103 TCO - 104c/220f
NTE8115 TCO - 117c/243f
NTE8118 TCO - 121c/250f
NTE8125 TCO - 128c/263f
NTE8139 TCO - 141c/286f
NTE8149 TCO - 152c/306f
NTE8167 TCO - 170c/338f
NTE8181 TCO - 184c/364f
NTE8182 TCO - 192c/378f
NTE8213 TCO - 216c/421f
http://www.we-supply.com/browse.cfm/nte-replacement/2,408.html
Austin
Aug 08, 2013 | Kitchen Appliances - Others
Vitapur water cooler troubleshooting
Mine was beeping after it overflowed. I could not figure out why, but my husband did. The beeping noise is a warning that your holding tank is too full. Just dispense some of the water and it will shut off.
Jun 15, 2012 | Refrigerators
Vitapur Water Dispenser. Hot, Room and Cold Water Dispenser Stainless Steel VWD5446BLS Logo
121 people viewed this question
Top Vitapur Water Filters & Coolers Experts
Tom Chichester
Are you a Vitapur Water Filter and Cooler Expert? Answer questions, earn points and help others
