Question about Kitchen Ranges
Kitchenaid superba gas stove left front burner will not operate unless back left burner is turned on at same time
    Prodigy:
    An expert who has answered 500 questions.
  • Kitchen Ranges Expert
  • 644 Answers
The switch for that particular burner is bad. It turns out that whenever you switch on 1 burner, they all spark - that's a safety feature. Depending on the model, you may just need to replace the 1 switch, but usually, they are part of a switch string, and you have to replaced the whole string of switches..
Posted on Nov 27, 2014
SOURCE: Kitchenaid Superba Gas Range
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
Posted on Aug 31, 2008
rickzilla
  • 706 Answers
SOURCE: ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
  • 409 Answers
SOURCE: Kitchenaid Superba gas stove. Oven
so you get an error message on the display?
do the burners work?
Posted on Sep 13, 2008
  • 126 Answers
SOURCE: Burner will not turn off
I would first check the infinite control switch (#WB24T10029) the part the knob slips onto. The next thing I'd check is the erc (#WB27T10231) control board. Hope that is helpful!
Posted on Jan 15, 2009
SOURCE: Kitchenaid superba Stove Door
Slid the bottom storage compartment completely out. On the bottom of oven door are four (4) screws that hold trim piece that support outer glass panel. Remove screws and carefully remove complete glass and trim assembly. There are two (2) corner trim panels that are also secured by two (2) of the screws being removed. At this point you can clean all glass (both the outer panel that was removed and the inner insulated glass) and all other built up goop. Simply reverse process to reinstall.
Posted on May 03, 2009
Kitchenaid superba oven
It is very possible that moisture from the cleaning has caused the ignition switches to make enough resistance to cause the burners to spark. It usually goes away after the stove has dried out. If it continues after a day or so one or more of the ignitor switches may need replacing.
Nov 20, 2013 | Ovens
Problem with Kitchenaid Electric Range Stove Top Burner
there may be a loose connection in either the pipe or on the burner rings on the surface. Some stoves have a safety cutoff if gas supply is interrupted to avoid prolonged gas supply.
May 12, 2012 | KitchenAid KERA807P Electric Kitchen Range
Ignotor problem on kitchen aid superba
if it takes that long its either the spark moduel or the sw / if all the burners do the same replace the spark moduel and if only one does this replace the sw . some sw kit require all sw tho be repl as they come in a harnes. pre wired. mm hope this helped / feed back pls ..
Feb 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
I have a Kitchenaid superba gas range slide in, model #KGST307HBS9. The nob of one burner, only, the left rear, will initiate the electronic spark that will light burners. When that nob is turned to...
Pull out the bottom drawer and you will find the spark module. I strongly suspect it is weak. Here is a video that shows operation:
This one shows the module on the backside but I looke dup yours and it is below in the backside of the bottom drawer. Ok here is what i think The igniters could be dirty and I have a video showing how to check that plus another video to show how to remove those pesky switches on the top burners and spark module operation.
TOP BURNER SPARK IGNITION
SEALED BURNER SCREWUP
Jan 02, 2010 | Kitchen Ranges
Stove burners won't ignoite
remove a burner cover and while observing the burner turn on the ignitor listen to it click for that burner ; you should see a tiny lightning bolt like flash if you do not tun off the burner clean the area and, try again oil and grease coat the burner gas plate and isolates the ground that the spark needs to be able to "jump" to
Apr 26, 2009 | KitchenAid KGRT607 Gas Kitchen Range
Kitchenaid gas stove left back burner won't light. hear clicking
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Mar 05, 2009 | KitchenAid Kitchen Ranges
KitchenAid Superba
http://www.kitchenaid.com/custserv/service.jsp
Enter your model number and it will give a listing of the manuals available to you.
Feb 11, 2008 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
148 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
