Question about Necchi Sewing Machines
Bobbin thread not being picked up Necchi 7010
Machine fails to pick up bobbin thread
    New Friend:
  • 36 Answers
This is a tough fix. There is a metal ring with a hook on it that goes around the bobbin. Check that there are no threads jamming the bobbin parts. Short of that, sry its a trip to the repair shop.
Posted on Nov 19, 2014
landsend
  • 1066 Answers
SOURCE: Brother sewing machine vx1120 Ithink won't pick up bobbin thread
have you tried other thread and a different bobbin?  The tension screw on the bobin case could be too tight.
Posted on Mar 11, 2009
SewExpress
  • 41 Answers
SOURCE: Picking up the bobbin thread
A few suggestions:
  1. Rethread top of machine from scratch with the presser foot raised, i.e. remove thread completely from all thread guides & paths and start from scratch, making sure thread is securely seated between tension disks. Once the needle is re-threaded, lower the presser foot and give the tail end of the thread a tug to make sure there's tension on it.
  2. Make sure the bobbin is turning the correct direction for your machine - and that the thread tail is under the tension plate or bobbin tension guide (depending on machine).
  3. Blow out any fuzz.
  4. Insert a new needle, making sure needle is pushed all the way up.
  5. Oil machine (in locations recommended in your owner's manual).
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Hope this helps narrow down your stitching problems.
Happy sewing,
Kim & Linnette
Posted on Jun 27, 2008
  • 323 Answers
SOURCE: Threading & bobbin won't pick up
Make sure the needle is inserted all the way in with the long groove to the left.
Threading is through 1)the thread guide 2)The tension 3)The take up lever 4) The needle eye (left to right).
Remove the needle plate, thread the machine. Turn the hand wheel and watch the thread in the needle to see if it is above the eye of the needle. If it is, the machine needs to be retimed.
Sewman7
Posted on May 14, 2008
Mimito7
  • 128 Answers
SOURCE: Necchi Heavy Duty Sewing machine model 3205FA,
Generally when the needle does not pick up the bobbin thread, it means the needle is either too far in or just plain the wrong length. YOu might want to try lowering the needle just a hair and see if that helps.
Posted on Apr 22, 2009
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
Necchi 00348 bobbin threaded but bobbin thread not being picked up in a stitch??
This is a normal problem for all sewing machines. It is called timing. While the needle is on it's way to the needle plate the thread is picked up by the hook(sharp, under bobbin). If the hook and needle aren't in the right position the thread won't be picked up. Open up your needle plate and use your hand wheel while you watch what happens with the upper thread as it rises. You should notice where the hook is while the needle is rising. There are are other times that the needle thread isn't picked up and that is when the hook isn't close enough to the tip of the hook. Now, you must go to you tube and learn how to time your machine. If this isn't something you wish to take on you can take to your local repairman.
Nov 18, 2014 | Necchi Sewing Machines
Necchi model 3537 won't pick up bobbin thread
sewvacdoctor.com has a list on their site with helpful free tips. I found this site for you I think will get you on your way. Hope this helps.
Apr 03, 2012 | Necchi 3537 Mechanical Sewing Machine
Please tell me exactly how to thread the bobbin on a 3620. I have followed the instructions, but I don't have a picture showing the bobbin when finished. I start with the bobbin thread coming from left...
I also own 2 necchi sewing machines, I used to have a 3620 myself,,
in my operation manual it has a picture of threading the bobbin case,, if you would like a picture send me a comment with your email address
Nov 17, 2010 | Necchi 3620 Quilter Mechanical Sewing...
Necchi 215A Sewing machine Could anyone help I have a Necchi 215A which will not catch teh bobbin thread, I have tried a new needle and checked the bobbin is loaded and fitted correctly. The needle passes...
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Sep 26, 2010 | Necchi Sewing Machines
Bobbin thread will not pick up
Ensure the bobbin thread is mounted on correctly and using your right hand turn the gear that makes the needle go up and down until it catches the thread.
Apr 08, 2010 | Necchi 3102 Mechanical Sewing Machine
Where can i get my sewing machine fixed? i have a Necchi sewing machine, and it does not work. i bought it two years ago and it was working perfectly. i've tried everything it said in the manual, but it...
make sure you have it threaded right and picking up thread at bobbin
brfore sewing i have seen a lot of people put the thread the wrong way through the needle and it will have this problem
Dec 31, 2009 | Necchi Sewing Machines
Top thread will not pick up the bobbin thread
Timing is off, is is possible that you broke a needle or sewed over a pin. timing needs to be re set by a professional.
Aug 22, 2009 | Necchi Sewing Machines
Model 3205 FA not picking up bobbin thread, needle goes down but doesn't pick up bobbin thread, needle not bent, macine was working fine then all of a sudden bobbin thread stopped. Can't even pick it up to...
- check ifu are using same needle model.
- check hight of needle bar is ok
- check timming between needle bar and hook.
- check if your material is very stritch or no
- check blad point of hook is ok or no
best regards
Aug 15, 2009 | Necchi Sewing Machines
I have a Necchi heavy duty sewing machine, I was hemming a denim skirt, the machine got bound up and now the threaded needle will not pick up the bobbin thread and bring it up. What could be the cause of...
I have the same machine. Try replacing the needle, it could be slightly bent and not be in position to pick up the loop from underneath. A good de-fluff may help too.
Apr 19, 2009 | Necchi Sewing Machines
Sewing Machines Logo
57 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
