Question about Sharp Microwave Ovens
How do I set my Sharp SPC570 clock to proper time
Held down T.set button and punched + and - buttons
SOURCE: Sharp R-9H56 Microwave convection oven
I have this model. Press clear then press Auto/Clock. Enter in the time eg 700 then press Auto/Clock again. The time should now be set
Posted on Dec 11, 2007
  • 619 Answers
SOURCE: Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Posted on Jan 03, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Setting the time on Sharp microovens.
Normally it's
Clock > time numbers > Clock
or
Clock > time numbers > Start
Sometimes it's
Clock > (1 or 2) > time numbers > Clock
or
Clock > (1 or 2) > time numbers > Start
If this doesn't work, please reply back with your model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 19, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp 510 HKF "clicks" only when start button
See these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Posted on Jan 28, 2011
Setting the setting the clock
Colin,
Most of the time, you hit clock, then on the keypad, punch in the time of day and then either hit clock again or hit the start button. Some models may ask you for AM or PM but it will scroll a message if it is going to ask that & will tell you what button to push. Hope this helps!
Jul 09, 2015 | Microwave Ovens
I need the manual to set the clock on a microwave rhm 1712
Most of the time you just hit the clock button then punch in the time then hit clock again
Mar 09, 2012 | Microwave Ovens
I can't set the clock. It's a Sharp Carousel II w/ ESP - R-4K82C
Press the clear button twice and then the clock button. You can now enter the time. Press the clock button when set.
Jan 03, 2011 | Sharp Microwave Ovens
I have a Shapr Microwave Convection model R-8880(W) T which is flashing after being stored for 3 months. It won't work, the timing light just keeps flashing on andoff 88-888. Does it have a reset...
Try pushing / stop reset first. The setting the time by pushing clock button .... punch in the time and push the clock button again. Just respond here if that does not work. 88-8888 is what you get after your first plug it in. Sometimes you will get PF if you unplug it and plug it back in. If that appears push stop / reset / clear. (Same button)
Kelly
Dec 26, 2010 | Sharp Microwave Ovens
How to set clock on sharp microwave
normally you look for the clock ot watch icon. Pressing it once will give you the option for 24 hours setting. Press it twice and it will give you the opportunity to set to 12 hours setting. Using the no. keypad, punch in the time and then repress the clock icon again.
Sep 21, 2009 | Sharp R-1480 Microwave Oven
R-209BK Sharp Microwave buttons inoperable
I had this problem too:
it turns out that it (apparently) just needed some 'warm-up' time!
After being plugged in for about 15 to 30 minutes,
the buttons suddenly "came to life"...
Note that when it's flashing 88:88 you are supposed to _start_ with the 'Stop/Clear' button. After that, set the clock (press "Clock", enter the time with the number pad, then press Clock again).
Hope that helps.
Sep 01, 2009 | Sharp R-1502 Microwave Oven
Clock setting
Mine is a Samsung, I don't know about your brand, but mine has a "CLOCK, AUTO/START"
button. Press & hold this & punch in the numbers until have the correct time
Aug 09, 2009 | Microwave Ovens
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
Jun 08, 2007 | Sharp R-1872 Convection/Microwave Oven
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
