How do i update the software in my Conia tv CLCD2612HD I tried connecting my Computer with VGA, it only connects on 600x400, tried to connect using HDMI Port via a VGA/HDMI connector with inbuilt 1
Tried all forums, no information found, contacted Conia, no response. Required the Unit as a monitor only, Digital TV works OK.
    Top Expert:
  • Televison & ... Master
  • 75,157 Answers
Contact any service technician. Firmware update procedure is a skilled one. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 19, 2014
Benimur
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
pazman
  • 81 Answers
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Posted on Apr 08, 2008
  • 90 Answers
SOURCE: philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Posted on May 25, 2009
  • 668 Answers
SOURCE: TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Posted on Jun 18, 2009
  • 1606 Answers
SOURCE: I am trying to connect my macbook pro computer to
On the MacBook, check the Displays pane in System Preferences to make sure the settings for the external monitor are correct. It's possible that the system is not recognizing the adapter or it has the wrong resolution setting, so it's not sending out any signal that the adapter can use.
Many of the better DVD players and high-end video game consoles use HDMI. You can use one of those as a test signal generator to check the TV.
You may get better results if you use a DVI-HDMI converter, although you would need to get the DisplayPort to DVI cable. This will avoid converting to analog VGA signals and back to digital again.
Posted on Oct 13, 2010
Testimonial: "Thank you for giving me another avenue to explore."
How do I change source resolution on my TV?
connecting PC to Tv through VGA - Tom's Guide
www.tomsguide.com/answers/id-1891563/connecting-vga.html
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Connecting my Plasma to my PC via the VGA port. - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Ensure that the VGA cable is working properly using other methods. Perhaps .... I am trying to connect my pc with my samsung tv. .... I'm very sorry to hear that has happened, and I apologize for any inconvenience this may have caused you. Connection between Dell laptop and Samsung TV
Jun 11, 2015
How to connect computer to tv with sound and picture?
Jun 5, 2015
PC Audio won't play through connected Samsung LCD TV
Jun 4, 2015
Connecting computer to TV
Jan 18, 2008
More results from www.cnet.com
My custom built PC will not connect to my TV via VGA cable ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Jun 28, 2013 - 5 posts - ‎2 authors
Jan 31, 2016 | VIA Computers & Internet
Windows xp connected to Funai tv vga
You need to identify which audio input is active when you select the VGA input from the TV. Some TVs use RCA input jacks, and others use the standard headphone jack, so you may have to try an adapter.
May 07, 2014 | Televison & Video
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
How to connect Acer Aspire 5530 to TV
If your TV is liquid crystal, or with VGA interface of the TV, the computer also WITH VGA interface don't need to buy TV card.Otherwise not only buy TV card, still need to buy a VGA connections, five meters. But VGA connections only transfer video, not transmit audio. So, you need purchase another audio signal lines, according to TV and computer their audio interface situation choose, both prominent circle mouth speakers audio signal lines. , 5 m.Also you can buy take S terminals output graphics CARDS, but it also requires TV also have S terminal input interface.
just have a try,I do not know if useful!,source from autodvdgps
Jan 09, 2012 | Computers & Internet
Conecting computer to view screen
Hello
Your JVC Tv has AV & Component video inputs only. No direct connection facillty with computer is there. Computers outputs VGA stream video. VGA stands for Vodeo Graphics Arrey. This video stream cannot be connected directly to your JVC set. There are sets, which have this facility, but your set have not.
If you want to connect this set to computer, you have to buy one converter [VGA to RCA out], from open electronic sparepart selleing shops at your town. It will not cost more.
If you have this converter, you can connect your computer directly to the VGA converter, using a VGA to VGA cable, and the output from the converter by RCA connecting wire to TV. In short, the converter will be in between TV and Computer.
VGA to Video converter will look somewhat like this. OK.
Dec 14, 2011 | JVC AV-32D305 32" TV
I need to connect a Dell Optiplex GX520 PC Desktop to a TV that is non-HDMI Can you assist?
As I see you have two choices to connect your PC to TV.
1. Use VGA to RCA Component Cable
2. Use VGA to Scart Cable - It is hard to find that one.
So if you choose the first option, you have to connect VGA to your computer (it is marked with 9 in the picture below) and RCA end to the TV.
Before that, lower the resolution of the computer and set the frequency of the Video adapter to 50Hz.
Make sure your Video card software initializes the TV.
That's all. Simple as that.
Sep 19, 2011 | Dell OptiPlex GX520 PC Desktop
I am unable to open the report center in quickbooks 2010
easiest is to check quickbooks.com for support and you may have free tech support form intuit. I have found its hard to troubleshoot problems with quickbooks and very little info online unless its on their website
Mar 03, 2011 | Intuit QuickBooks Pro 2010 Full Version...
Trouble connecting dell vostro 1500 with lcd tv
Depending on the operating system on your Dell. Try right click on the desktop and go to graphics properties or display settings. If the computer can 'see' the TV try to enable it by clicking 'extend desktop to this display'. If you cannot "see" the TV try the detect button and enable it as per above.
Jan 31, 2018 | Samsung LN32B360 32 in. LCD HDTV
Jvc 56dlp connect computer
If you are getting an invalid input its because the resolution setting on your computer is probably set too high. The JVC only accepts 2 resolutions one is like 600x400 and the other is 1280x768. I had this problem all the time with vista. It can't seem to remember what resolution to use. The exact setting are also listed in owners manual.
Apr 08, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Conia plasma 42inch connecting to macbook pro - ??
Hi, i also have a conia plasma (and sony 510 amp). Which video connection are you using? DVI-VGA? DVI-component? Note that the tv probably defaults to using YPBR rather than VGA so you may need to play with settings in the menu ...
Aug 12, 2008 | Sony STR-DG510 Receiver
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
