Question about Unisar Extra Headset For the Tv Listener Tv777
When I connect Unisar TV920 to the digital (S/PDIF)audio output jack on my Philips 26PFL4507 no sound comes through. I've searched for a "simple" resolution. Is it something to do with the S/PDIF?
Television to connect with is Philips 26PFL4507.
    New Friend:
    Problem Solver:
  • 16 Answers
If the cable you use to send the S/PDIF signal is a fiberoptic toslink cable, inspect the ends very closely. The clear plastic nubs that protect the laser output can look an awful lot like part of the connection itself. If you haven't done so, remove them and try again.
Posted on Nov 26, 2014
What kind or type of spdif cable do i need ?
The Unisar DH900 input uses a 3.5mm stereo audio jack for input, whatever you need on the other end depends on to what you are connecting it to, here are the I/O specs for the Unisar DH900, it should come with various adapters to suit most eventualities, http://www.yourhearing.net/pdf/HC-DH900.pdf
Jan 20, 2016 | Apex Digital LD3249 LCD TV
What is the s pdf out port used for?
It is S/PDIF. It is a digital audio output for connection to a sound system.
May 22, 2015 | Philips Magnavox 42MF521D/37 Television
How to output sound to a 2nd device
If you need an analogue output, you can tap stereo analogue audio by using one of the two sets of "pre-out" RCA jacks on the back of your receiver. These provide "headphone like" output power, and will not overload any analogue input connected to it EXCEPT MIC and PHONO inputs on the 2nd device. If it's digital audio output you need, there's an HDMI monitor out, that will provide digital audio to another HDMI input equipped device. You'll have to get a relatively cheap adaptor if you need this digital audio output in another digital format/connection (like the popular S/PDIF optical or coaxial).
Jun 11, 2014 | Marantz NR-1604 7.1 channel HT receiver...
I would like to connect my computer to my panasonic sa-ht800v unit and hear the sound thru the surround sound speakers
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for analog audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The SA-HT800's single LINE Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select VCR.
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Mar 26, 2011 | Panasonic sa-ht800V Home Theater Audio...
How to connect the gemini to the computer
Easy.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for REAL audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The Gemini's Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select Line In.
http://i.ehow.co.uk/images/a04/fa/r2/subwoofers-as-home-entertainment-set-1.1-800X800.jpg
The Gemini's Output (Record Master) would perform similarly if adapted to your PC's audio input, whatever that may turn out to be (usually Mic, maybe Line In).
Mar 12, 2011 | Philips Gemini CDM-500
Can u hook it to a computer for sound
More-advanced sound cards would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
A digital-capable receiver would accept 44.1 kHz for normal CD or DTS sources. Some diddling with the output sampling frequency might allow digital multichannel audio to be decoded by the receiver.
Feb 11, 2011 | Harman Kardon AVR 430 7.1 Channels...
How do I connect my computer to my Sony STR-D915.What if any special cable,adapters,equipment do I need to have all computer sound relayed through the speakers I have ?thanks
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts (*) to RCA pair for REAL audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
* http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
YOUR receiver has only analog stereo RCA inputs so you
Feb 11, 2011 | Audio Players & Recorders
Connecting BA735 digital 3.5mm plug with S/PDIF coax jack
The male mono plug (from the left small speaker) should be connected into the right speaker (small speaker with controls) . After plugging the multi pin cable from the control speaker to the sub-woofer you need to plug in a signal source from your computer (or any other digital signal) into the sub-woofer. This digital input looks like an ordinary RCA plug but carries many channels of audio. That connects to the enabled digital output of your computer. Some computers output digital through a 3.5mm jack others look just like an RCA phono jack. If you are lucky some BA735 sub-woofers have a second input that is a standard 3.5mm stereo jack and it will take analog audio from computer, DVD, MP3 player or the like. I have three sets of these speakers that I love because of their big volume considering such a small size.
Mar 29, 2009 | Boston Acoustics BA735 Computer Speakers
Setting up tv sound to come thru stereo speakers
Offhand, your Philips 32PFL7422/98 do not have regular Audio Output RCA jacks (white and red), sorry. However, right before the antenna connector is an S/PDIF output connector. This should allow transfer of digital audio signals from the Philips 32PFL7422/98 to a S/PDIF capable receiver or amplifier. If you would look at the rear of your stereo and determine if it has such an input, then it would be a matter of getting the right cable/connector.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Philips Televison & Video
LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
Sep 12, 2007 | Digital Audio 5-OUTPUT COMPONENT VIDEO...
Unisar Extra Headset For the  Tv Listener Tv777 Logo
125 people viewed this question
Top Unisar Baby Care Experts
masud
masud
Tom Chichester
Bill Boyd
Are you an Unisar Baby Care Expert? Answer questions, earn points and help others
