Question about Behringer Dsp1124p Feedback Destroyer Pro with Parametric Eq
I just bought a Behringer Feedback Destroyer pro dsp1124p and I am having difficulty figuring how to set it up so that it will cut the feedback not only in my monitor speakers but also in the main spe
Right now I have for FOH the mixer to the eq and then eq to the feedback destroyer and then to the crossover to the amp. The monitor is aux 1 to eq then eq to feedback destroyer and then fbd to the monitor amp.
  • 35 Answers
Hi, sounds like you have it connected up ok so you can use one channel for FOH & the 2nd channel for the monitors. However if the unit is in "couple" mode both channels will react the same as each other so you need to set the unit to act as 2 separate channels. See the manual Page 11 for how to set "L" & "R" buttons to do this... Good Luck!
Posted on Nov 26, 2014
  • Al Staggs
    Al Staggs Nov 26, 2014
    Thanks so much Barry I did notice that both channels where in couple mode so I diconnected the FOH and ran that into eq and took eq out of the destroyer. This worked but I want to have it available for both foh and monitor so your advice will fix the issue. Thanks so much.
4 Suggested Answers
  • 5603 Answers
SOURCE: How to connect feedback destroyer pro dsp1124p ?
It all depends what you are connecting it to... Essentially wire it someplace between the preamps of microphones and the power amps that drive speakers. The only stipulation is that you want the levels to be "line level" signals.
If you are using a powered mixer, you will do this as an "insert" using the insert effect jacks. The preamp signal goes to the "in" of the destroyer, and the "out" goes to the following amp.
Posted on Dec 13, 2010
  • 4234 Answers
SOURCE: how o u hook up
In order for this to work properly it must be inserted between the last pre-amp stage and the power amp. Can you please update this with the mixer that you are using? With the make and model of the mixer, I can provide you with a connection description. Since each mixer will have different labeling and options, it is not possible for me to accurately describe the connections without hte make and model.
Thanks,
Dan
Posted on Feb 02, 2011
  • 5603 Answers
SOURCE: what is the best way to connect an external EQ or Feedback Destroyer unit to a Behringer PMP3000
Get an "insert snake" which splits each of two TRS plugs into TWO TS plugs.
Plug the TRS ends into the MAIN INSERT jacks and each of the "TIP" plugs at the other end into inpout jacks of the destroyer. Plug the "RING" plugs into the output jacks of the destroyer. You will need a snake with at least two sets of splits. I use a Behringer PROCOM compressor. For those the TRS plugs go into the channel insert jacks and the tips and ring plugs go to the in and out of each channel of the compressor respectively.
Posted on Jan 11, 2012
Excessive feedback
On mic? On guitar? Take top frequencies off EQ, point mic away from speakers. Use decent dynamic mic or feedback resistant condenser such as Sennheiser e865. Try Behringer feedback shark
Feb 06, 2014 | Music
How do i hook up a feedback destroyer to my EQ,COMPRESSOR,COSSOVER
Put at end of the chain. In this order: (1) EQ (2) Compressor (3) Crossover, (4) Feedback Destroyer.
Dec 12, 2012 | Behringer Dsp1124p Feedback Destroyer Pro...
What is the best way to connect an external EQ or Feedback Destroyer unit to a Behringer PMP3000
Jan 11, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
How o u hook up behringer feedback destroyer to a powered mixer
Thanks,
Dan
Feb 02, 2011 | Behringer Dsp1124p Feedback Destroyer Pro...
Dec 13, 2010 | Behringer Dsp1124p Feedback Destroyer Pro...
Show me how to hook up the Behringer destroyer pro?
What are you going to hook up to?
Essentially you connect the power cord to power and connect outputs from say a mixer to the inputs using TRS balanced cables... and connect the outputs of the unit to your power amplifier.
Note taht there are MANY other possibilities using "inserts:on some devices.
Dec 02, 2010 | Behringer Dsp1124p Feedback Destroyer Pro...
Feedback
Supposedly one pushes down the FBQ button and the LED's in the EQ handles light for those with feedback and you adjust those till the lights go out.
More importantly I want to caution you to NEVER run this unit without a speaker load. There is an arc over condition in the rear-most power amp that kills the unit. This can happen even with everything connected. It causes major damage. At the slightest indication of flakey behavior, power down and take in for service.
Apr 02, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
My behringer djx700 5 channel pro dj seems to have a feedback problem even when nothing's plugged in to it cant figure it out.
It doesn't seem like a typical "feedback" problem, as feeback is produced by over modulation between the amplifier and the source - usually a pickup or microphone. It may be your cables to your amplifier are bad, or the actual line out jack(s) may have gone bad. If it is more of a humming sound rather than feedback, that is most likely your issue. If you have additional patch cables, switch out the existing ones, and see if that ends it. If not, it is possibly the jack(s).
You have a headphone jack on the Behringer, though you did not say if the problem arises through the headphones or an external amplifier. If you get the noise in the headphones, when no patch cords or a mic is attached, then the problem you should look at is your headphones or the headphone jack. You can narrow the problem down by using an external ampifier and see if you still have the "feedback" sound. if not, it's in the headphones or headphone jack.
Please try and provide more information for this question if we are unable to track the problem with these suggestions. As we do try very hard to center in on customer's problems, we do ask to provide as much information as possible, so that we can facilitate your resonse more effeciently.
Thank you for using FixYa.
Dec 31, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer Dsp1124p Feedback Destroyer Pro with Parametric Eq Logo
29 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
