Question about All-Pro Heating & Cooling
Change thermocoupler on all pro 50000-85000 btu heater
All pro 35000- 85000 propane forced air heater. have cleaned thermocoupler. unit goes off after releasing start button
    Novelist:
    Champion:
  • 373 Answers
If you have replaced the thermocoupler and it still wont stay lit then replace the gas valve.
Posted on Nov 19, 2014
Buffalo12980
  • 625 Answers
SOURCE: forced air propane heater won't stay lit
two items come into play here - 1) the hot surface cutout and 2) the flame detect Cd cell. Check alignment of the Cd cell or just replace it. The hot surface cutout has two terminals that plug into the two tabs on the millivolt generator.
Posted on Aug 22, 2007
SOURCE: All-Pro Kerosene Heater
I have a 100,000 allpro Kerosene heater I get sprake but won't lite I need help Thanks
Posted on Dec 03, 2008
SOURCE: propane shuts off after releasing start button.
I have the same problem with my Reddy heater 55-f. Is it thermal coupling or relay?
Posted on Dec 08, 2009
  • 188 Answers
SOURCE: 150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Posted on Jan 28, 2010
hardrocko
  • 1476 Answers
SOURCE: I 50,000-85,000 All Pro Propane heater release red button fireout
If the red button has to be held down for a period of time to get the heater going it overrides the shutoff mechanism. If you are holding it the prescibed amount of time then either the hydraulic system which keeps your unit running is bad or out of place or the metering valve is bad. Check for a copper line with a bulb on the end. It should probably be in the fire created by the heater, if not bend it to be in the heat or very close. If this is ok then you may need to get a new burner for the unit which would probably mean buying an entire new unit as the cost would probably exceed the cost of a new unit. Let me know how you make out.
hardrocko
Posted on Feb 07, 2010
I have a 225,000 to 375,000 btu propane heater that the gas valve will not open on. The igniter sparks I can see that .There does not appear to be a thermocouple unless it is built into the igniter. T
YOU MAY NEED TO CLEAN THE NOZZLE, THE FUEL FILTER, & POSSIBLY ADJUST THE PRESSURE AT REAR OF UNIT. MAKE SURE THAT THE FILTERS ARE CLEAR & UNIT HAS PROPER AIR FLOW OTHERWISE IT WILL OVERHEAT & TRIP THE HIGH LIMIT
Dec 25, 2012 | Reddy Portable Forced Air Propane Heater...
My all-pro propane heater will not stay lit for over thirty seconds after I release the red fuel start button,before the flame goes out it makes an air hissing noise right before it shuts off.Heater will...
This sounds like a problem with your thermocouple.
Just remove the end of the thermocouple from where is goes into the gas valve and leave the end that goes into the flame in place.
Clean the end of the thermocouple connect by scraping off just a little metal from the end just about there the nut tightens the thermocouple into the gas valve. After you have exposed some new metal do the same inside the valve where the thermocouple seats into the gas valve.
Use a small pic or similar item to scrape inside the gas valve to expose some new metal there also.
Now reassemble the thermocouple into the gas valve and see if the heater works.
Here is a link with some more instructions.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
If this does not solve the problem you may need a new thermocouple and you can find that at www.desaparts.com
Thanks
Jan 04, 2011 | All-Pro Propane Garage Shop Heaters - All...
My 35000 btu will not stay lit. after i take my finger off the propane gas butten the flame goes off. what is wrong. this is a ready heater
I would venture to say that it is the thermocouple not picking up signal to keep the gas valve open. You can try cleaning the bulb end with steel wool and positioning it in the flame remember the hottest part of the flame is out on the end.
Dec 20, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
The heater wont start got power,got propane ,when i release the push in switch it wont start
YOU WILL NEED TO HOLD THE START BUTTON FOR ABOUT 2 MINUTES, ON YOUR FIRST START UP , TO GET THE FRESH GAS UP INTO THE UNIT
Dec 01, 2010 | All-Pro Propane Garage Shop Heaters - All...
The unit will light however after a few minutes of running the heater shuts off and does not continue to heat
Does this unit have an OXYGEN DEPLETION SENSOR ? if so, then are you using the heater in an area that is too confined or too closed-up? You say it is forced air, therefore the air must move continuously or the over-heat sensor will stop the gas since there is no air to remove the heat being produced. If this unit has a thermocouple flame sensor, the flame my not be touching thethermocouple sufficiently and the thermocouple thinks something is wrong and stops the gas. Or the thermocouple can be weak and not give a strong signal to allow the gas valve to stay open. This is common on heater and hot water heaters, and you simply change the thermocouple.
Good Luck, Macgivor
Nov 27, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Everything works fine except the heater will not remain lit when the push to start is released after the required 30 seconds to light.
Now reassemble the thermocouple into the gas valve and see if the unit works when you release the button.
If this does not work you may need to purchase a new thermocouple.
You can purchase the new part at www.allpartsinc.com
Nov 02, 2010 | Reddy Heater RLP100 Portable Forced Air...
Propane heater wont stay running
is the sensor for the thermocouple located in the right spot in the flame,remove it and if you have access to a propane torch,heat the end till its red hot and leave it connected to the gas valve,then start the unit and this will tell you if the sensor is properly positioned in the pilot flame on the unit itself,if not you could have a defective new thermocouple or another safety device keeping it from staying lit or the gas valve is faulty
Jul 28, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
hardrocko
Feb 07, 2010 | All-Pro Propane Garage Shop Heaters - All...
Heating & Cooling Logo
323 people viewed this question
Top All-Pro Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
