Question about Kitchen Ranges
Burner will not stay on too warm house - Kitchen Ranges
  • 9,587 Answers
Using a stove burner to heat the house is the wrong thing to do. You can kill everyone in the house from carbon monoxide poisoning.
Posted on Nov 19, 2014
Why burner on light on stove wont come off
After stove is turned off, the light stays on if burner still warm. If the burner never came on, then it needs to be replaced with new one.
Apr 26, 2014 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Junkers manual gas hot water
What are you expecting to happen?
I assume the water heater and water inside it is cold (otherwise you would not be lighting it). You light the pilot. The main burner comes on and the pilot lights it. The main burner should stay on until the tank is hot, When the tank gets hot the main burner should shut off but the pilot stay on. If you draw hot water, cold water will run in and cool the tank. If yu do nothing the tank will eventually just cools off. then the main burner should come back on to reheat the tank.
Nov 05, 2013 | Water Heaters
The left front burner will not turn off. The light stays on and the burner is warm.
Switch to that burner needs replacing.
Go here for instructions.:
http://www.applianceaid.com/procedures.html
Vote for me if this was helpful
Thanks
Leo Ponder
imufo2
Aug 13, 2011 | Kitchen Ranges
Burner pilot does not stay lid.
You need to have the THERMOCOUPLE replaced immediately.
Apr 05, 2010 | Vanguard International Vanguard 82V66-2T...
Gas oven wont stay on
If this is electronic ignition, then chances are the burner or ignitor nub has residue on them, preventing the flame detection system from keeping the gas on.
Use warm soapy water and a plastic scrub brush to thoroughly clean the burner cap, burner base, and ignitor nub.
Jan 25, 2009 | Whirlpool GS475LEKS Gas Kitchen Range
Fan cycles on and off to often the burner stays on and the fan cy
what is happening is that the heat exchanger has to get to a certain temperature before the fan comes on that way you have warm air blowing out of the grilles and when the heat excahnger gets cool it shuts off until it warms back up again.
Jan 15, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Parkray Cumbria efficiency problem
Some circulation pumps have a 3 phase mixing valve (cold,warm,hot) to regulate the water pressure in the building; no way to know unless you trace the plumbing. Basically, the hot water temperature could be lost because the circ-pump is cooling it with the cold water supplied to it. This is used to balance the pressure (aka Pressure Balancing Circ-Pump), so heater is really working overtime to heat the water. If the pump has two in and one out that's more than likely your problem; but you should consult a "old-school" plumber in your area.
Nov 25, 2008 | Water Heaters
Kitchen Ranges Logo
65 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
