Question about Kitchen Ranges
I have a GE electric range and the oven no longer turns on. I knowthe oven element is fine. The clock display on the front of range is also dead. Ive taken the back panel off and found that the wiring going to the lower area in back looks burned out. Can I repkace just the wiring there? Could this also be causing the clock display to be dead? There is a circuit board behind the clock display but that appears to be in good shape.
  • 833 Answers
SOURCE: Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Posted on Dec 13, 2007
  • 7 Answers
SOURCE: Frigidaire electric range
is there voltage going to the erc (electronic range control)?
Posted on Feb 09, 2008
aborcass
  • 2651 Answers
SOURCE: whirlpool gold electric range control panel blinks w/all lights powers oven off
you say after 5 min of plugging in , is this brand new and still covered under your 1st year warr???if so get an authorized servicer out there to take a look at why should you be responsible for their problem
Posted on Mar 17, 2008
micromaster
  • 3614 Answers
SOURCE: GE Stove tope range not working
did the timer was still functioning, and the only problem was it was not getting any heat, right>
Posted on Sep 04, 2008
SOURCE: Inglis electric freestanding range model #IRE3230- Oven no longer working
If the oven and the electric panel no longer work, this is an electronic problem. The burners and the oven light will not be effected, nor will the fuses. The electronics card will need to be replaced by an appliance technician.
Posted on Nov 25, 2008
GE JS900 electric range stovetop works fine but no lights or clock on control panel so the oven cannot be turned on.
You will probably have to replace the main control board- the cooktop operates independently of the ovens, so your symptom is not uncommon... GE Range Stove Oven Oven Control Board WB27T10416
Jan 09, 2016 | GE Kitchen Ranges
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
Oven, oven light and oven led display will not work
that sounds like an erc[electronic range control] or clock timer etc. You can check power supply to it but chances are thats what you need.
May 20, 2009 | GE Spectra JBP78 Electric Kitchen Range
Oven problem
if you had a power surge then the resistors on the board cannot handle it. i am no electronics expert however i am a range expert and usually it happens when 1 you live in a very rural area and have frequent power surges.. 2 get struck by lightning.. 3 may have a miswired outlet.
Jan 20, 2009 | GE Profile 30" Free-Standing 5 Burner Self...
JBP26 Oven broil and bake do not work and the oven light is flash
If you have 240Volts to the range and BOTH elements don't work, it sounds like the L2 OUT relay on the oven control is bad. Bake and Broil share this line and this problem is not un-common. Make sure you have proper incoming voltage first. Turn breaker off and back on to make sure both poles are set.
Dec 15, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Aug 29, 2008 | GE JBP90 Electric Kitchen Range
Oven not working
check its fuses, might be one of them has blown/ open.
Jul 30, 2008 | GE JBP71 Electric Kitchen Range
Electric Oven not getting hot enough
there are relays on the oven control that turn the elements on and off, sounds like you need a new control
Feb 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
Dec 13, 2007 | Frigidaire FES367 Electric Kitchen Range
Kitchen Ranges Logo
52 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
