I have a becket oil furnace that will not start. We have tried the reset button and still nothing
    Sergeant:
  • 266 Answers
Also found this - (Please be careful of live wires as there is high voltage in there) -
http://inspectapedia.com/heat/No_Heat.php
Posted on Nov 19, 2014
How to install a return line for a oil furnance
Hey Clinton ,if you have a home style becket no return line is required if you have a carlin the return line will be on the right side of burner pump in coming oil will enter left side next to air bleeder on pump, im worried are you modifying something ? i'll be glad to help if I know what your doing or trying to do.
Woody
Dec 10, 2014 | Cars & Trucks
Peerless Boiler - Turned off boiler to replace Circulator for the hot water. Turned furnace back on. Did not ignite. Tried to hit the reset button for 30 seconds and nothing happened. Furnace will
Did you bleed the air out of the pump. The boiler has a flow switch that has to make before it will let the boiler lite. Make sure you have all of the air out of the system and are pumping or flowing water and not air...Also check to see if you didn't happen to of tripped the limit it has a manual reset. Red Button on the front of limit.
Nov 13, 2013 | Heating & Cooling
How to hook up becket oil furnace
On the top right hand side of the burner is the controller, on the right side ther are 4 contact screws, closest to the fire are the thermostate wires dosn,t matter which one goes where, two from thermostate go on these two contact screws. The two contact screws far away from the flame are for the two wires from the cad cell dosn't matter which one where. All that is left is 120 volt ac power which shouldn't be hard to see where they go.
Dennis
Nov 05, 2012 | Heating & Cooling
Webster/becket oil furnace there is no bleeder valve on it does anyone no have to bleed it
Actually, there is a bleeder valve on the pump you are referencing. It's located directly on top of the pump and the air (with some oil) comes out the nipple looking part just below and to the left of the bleed off valve 1/2" nut.
Apr 10, 2012 | Heating & Cooling
What is the best oil furnace on the market today 2011?
Your question is quite wide open to interpretation,Size, venting option, space availability,,,,But, if i think you wish to install this in a ,,lets say 1500 sqare feet home,, i would say a oil furnace made by olsen. Burns clean, effeciency depends on model, but sometime i would sacrifice a half % of efficiency for reliability, ease of maintnance,(not enough good ,reliable technicians in this field) quietness, odor free,parts availability, life span, ect ect.Stick with a canadian or north american made oil burner. I aint too fancy on the riello burners or even worse, a burner made for 50 different furnace model. I like the becket or aero burners. Choose a dc fan motor, direct dive if available. Stick with a chimney versus a direct or power vent.
Nov 11, 2011 | Heating & Cooling
Furnace wont start when thermostat sends signal
by restart button you mean reset i believe,its located on top of oil burner and says only push one time .if thats the button your pushing it is the reset button or retry for oil burner if you are pushing this there is a problem with burner
Jan 04, 2009 | Honeywell Electronic Programmable...
My becket honeywell r7184p oil burner monitor is not resetting it keeps blinking a fast green. What should i be looking for?
my Beckett oil burner with a honeywell R7184P just did the same thing. Quit burning, blinks for half a second. The burner says press reset once, if it does not reset then call a local serviceman. It is cold here in Alaska, you betcha', and my oil must have jelled up. It happened once, but pressing reset solved my problem, two days later it stopped again. I applied heat (hair dryer) to my supply line, added an anti-jelling solution to my tank. Here is what I found.
"The Honeywell R7184P-1080 (interrupted control—transformer shuts down 10 seconds after flame is established) is now the standard control used on all Beckett oil burners along with the new “Cleancut” pump. The Honeywell control has both a 15 second pre-purge and a 15 second post purge feature, as well as internal self-checking of the control itself. The control has 15 second lockout timing plus a 10 second ignition carry over period. After 3 lockouts during the same call for heat, the control goes into restricted lockout., A restricted lockout condition may be reset by holding the reset button down for 30 seconds until the LED flashes twice. At any time the control is powered, the reset button may be held for 30 seconds to reset the lockout counter. There are several new “Service Features” with the R7184P control that make for easier servicing."
You have to press the reset button for thirty seconds. I don't know how cold it it there, or what number oil you guys are burning, but what I do know is that you guys have been pressing your reset button more than once.
This worked for me. Good luck.
Jun 12, 2008 | Heating & Cooling
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
