Question about Whirlpool RBS305PD Electric Single Oven
Fan won't quit running, even after shutting breaker off to entire unit and powering back up.
Power cycling, cleaning cycling, turning oven on and off, nothing works. As long as there is power to the unit, the fan is running. Does thermostat need to be replaced?
    Prodigy:
    An expert who has answered 500 questions.
  • Whirlpool Expert
  • 650 Answers
There is a thermal sensor usually under the top panel that controls the cooling fan. You can check it for continuity or just pull a wire off and power it up. If the fan stops running then this could be the problem. There also could be a stuck relay on the control board. lets hope it is the thermal sensor.
Posted on Nov 22, 2014
catriver
  • 878 Answers
SOURCE: Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the fuse....Catriver..post back.
Posted on Oct 25, 2006
SOURCE: cleaned oven now won't heat
Probably what happened is during cleaning cycle the oven overheated the tco (thermo cut off). This is a thermo-fuse that is located behind the control board. It will need to be replaced.
Posted on Aug 25, 2007
SOURCE: whirpool rbd275yPDT11 no power after auto clean
I printed down the installation sheets. I could not locate the thermal fuse on the control panel (which was the easiest to get to without removing the oven) so I went ahead and removed the oven. The upper and lower thermal fuses were fine. I put in back into the wall and my husband found the control panel thermal fuse--it was in-line--so we tested it and it was bad. I could not find anyone online that carried this fuse-or even knew the name of it. After much hard work we finally got the info off it--Microtemp KLBALY G4A00 TE 110C. Nowhere could I find a replacement except for something I am hoping is comparable online at Goodman (?). So while I am waiting for the fuse, I went to Radio Shack who had a thermal inline fuse rated at 128C for coffee pots and hair dryers. Also got some fully insulated crimp on connectors. Hooked it up and it works--havent cooked yet--to do cookies soon to test it. So far it seems like everything is running ok. I WILL NOT EVER USE THE AUTO CLEAN again. I dont get why the company has let it lie without helping unknowing consumers
Posted on Jul 06, 2008
SOURCE: Whirlpool Wall Oven not working
It is likely the Thermal Cut-Off (TCO) fuse, which for many Whirlpool ovens is located on the back of the unit. Turn the circuit breaker for the oven OFF first. You'll need to remove the trim on the left and right side of the oven (2 screws) and then remove the screws holding the oven in the wall. You can locate it easy enough by looking for the thermal fuse on any of the major appliance part websites. The test is simple enough if you have an Ohm meter, as it will be an open circuit if it is blown. There is only one fuse (normally) so if it is blown neither the bake or broil element will work. There should be a Tech Sheet located behind the control panel which will help, but if you don't feel comfortable doing this call a service tech.
Posted on Oct 28, 2008
ginko
  • 19396 Answers
SOURCE: oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Posted on Dec 03, 2008
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
Viking deso175ss ran self clean cycle, tried to stop the cycle early. oven door locked wont reset. tried turning power on/off. was able to get door open by pushing latch to left, however it still will not...
Hello, welcome to FixYa.
I understand you have a Vking oven that is not unlocking after stopping (interupting) a self clean cycle, correct ? (I think the letters in the model should be "DSOE" as opposed to deso, aren't they ?)
Though this can cause issue's with the lock mechanism, it is unlikely anything was damaged...in my opinion of course, thus I don't think you need to start swapping parts.
If this hasn't already been done, I would suggest prepairing your oven as if everything was status quo for a self clean cycle.
Close the door, select self clean and let it go through it's start-up and lock sequence. Your going to stop it again, just as Viking instructs pressing "off" which should allow the lock mechanism to properly lock and then unlock.
During the clean cycle the unit usually has to cool before allowing for the door to open which can take up to 30 minutes, (this is why it counts down from 4 hrs even though the cycle is 3.5 hours) but since it should already be cool I'm hoping the lock will go a full revolution to it's normal position.
Normally these ovens will go through a self check sequence upon a power up (if power was lost and then restored...aka "onboard watchdog") which should include the lock assembly rotating to it's unlock position, but they can get out of sequence at times in my experience.
The other method I've tried and had success with is having a secone person hold the door switch closed while power is turned off and then restored a few minutes later.
Let me know if you have tried that and if not try it and get back to me. Hopefully that will restore it's proper function. Good luck.
Regards,
Macmarkus :)
Sep 07, 2011 | Ovens
After oven turned on for normal baking it starts to hum rather than typical noise from exhaust fan.
If you're not hearing the fan turn at its normal speed, it is possible that your fan motor has become stalled. AC motors will often hum or buzz when they can no longer turn but still have power applied to them. This could be due to bad bearings, or a blockage of some sort. It's probably not easy to get to, but if you can hand check the fan it should spin quite freely. Be sure to unplug the unit before messing with the insides, or shut of its circuit breaker if it's a built-in unit.
Dec 24, 2010 | Dacor ECS130 Epicure Electric Single Oven
F2E1 on stove after cooking on temps of 425-450 for 20mins stove shuts off and can not restart even if power is turned off and then started. must wait for stove to cool down and then press cancel and stove...
Is the background cooling fan running? Also, look under the oven and if possible take off the kick panel and clean all the rubbish out to ensure the cooling fan can circulate air round. As a check, when you turn any part of the oven on ( Main/top/grill) the cooling fan will run and you will feel a cool draft of air coming out of the gap just above the top of the main oven door. If the fan is not running, this will cause the unit to overheat and the overheat thermostats to kick in, turning the oven off.
If the fan is not running, you will have to take the whole unit out to gain access to the back panel.
Nov 28, 2009 | Stoves 720EF Electric Double Oven
Put in new wall oven , turned on power and set
my kenmore double oven model 41165 has no power....its hardwired 40 amp....it stopped working when it was cooling down after the slf cleaning cycle..we had a storm and had a minute power outage. Finakky got the door open but it wont turn on at all. Tried the breakers but i stll get no power....no even the bulb.......thanks....
Jun 07, 2009 | Ovens
Error code E3 - F3 on Whirlpool oven, RBS275PDB12
Error E3-F3 says that the Oven temperature is too high(Clean mode).You might have to replace the Oven Temperature Sensor(RTD).
Apr 19, 2009 | Ovens
Won't turn off
Sounds like maybe a wire burned off of an element terminal and shorted to ground. This would bypass the thermostat, so to speak, and continue to heat at 1/4 wattage. The only way to control this failure would be to turn off the power to the oven, but it won't reset until the burned wire is repaired.
May 27, 2008 | Maytag CWE4800A Electric Single Oven
Oven door locked
First check to see if you activated the "child lock-out". See your manual to deactivate.
You could also try unplugging the unit, or trip the circuit breaker in your home which supplies power to the oven. Wait 5 minutes and turn power back on. This will reset the controls.
Jan 26, 2008 | Whirlpool RBS305PDS Electric Single Oven
Oven will not heat at all after an interrumpted cleaning cycle (power went off)
There is a thermo fuse located behind the back panel of the oven. If the oven appears to be working but is not actually heating then this is the cause. The oven will have to be removed from the wall, power to the oven shut off at the main breaker and the back panel removed. the thermo fuse is just to the left and up from the center of the convection fan. It has 2 wires connected to it.
Jan 02, 2007 | KitchenAid KEBC107 Electric Single Oven
Whirlpool RBS305PD Electric Single Oven Logo
108 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
