Question about Gateway One ZX6971-UR30P All-in-One Desktop PC with Intel Core i3-
When you upgrade to windows 8 do you install the windows 8 UEFI bios or should i should not upgrade.
The bios if this site http://us.gateway.com/gw/en/US/content/drivers-downloads says its not upgrade so i don't understand that also its a different bios from the one i have.
  • Gateway Master
  • 9,639 Answers
Wait for windows 10. Coming soon.
Posted on Nov 19, 2014
How do I go to BIOS?
You can enter BIOS setup or UEFI firmware via traditional method: Boot the PC, while the firmware starts to run, press F2/F1(Fn+F1 or Fn+F2). However, computer boots fast, maybe you often miss the trick to press F2/F1(Fn+F1 or Fn+F2). You can enter UEFI firmware from windows 8 or 8.1.
Nov 02, 2016 | Computers & Internet
Can legacy bios ever boot gpt efi, say with a linux efi emulation.
Ok so when it's trying to boot in legacy mode it will see the hard disk as unformatted. Therefore it won't boot Windows 8 or 10. You need to get the bios back into booting uefi.
Resetting the bios should do that anyway, but there is no reason why you shouldn't be able to get into the bios to make that change. Try doing this with the hard disk unplugged so you don't risk trashing it.
Jul 27, 2016 | Legacy Computers & Internet
Windows 8.1 Setup: failed to launch the setup application.
windows 8 uses a different bios to windows 7
https://en.wikipedia.org/wiki/Unified_Extensible_Firmware_Interface
you may have to change the bios settings to use UEFI to get windows 8.1 to work if the p.c has the capability to run in uefi mode
http://social.technet.microsoft.com/wiki/contents/articles/14286.converting-windows-bios-installation-to-uefi.aspx
Jul 24, 2015 | Microsoft Windows 8.1 - Windows
I have a hp altec 255 laptop .when I put in reinstall disk .windows 7 .computer will not set it up to take program .enyway to get a new hp recovery and applications/drivers reboot disk
please check bios boot type I sujspect it may be booting for UEFI rather than for legacy boot. Windows 8 will boot on UEFI boot type but windows 7 will need legacy bios type of boot up settings in bios
see
http://blogs.technet.com/b/askcore/archive/2011/05/31/installing-windows-7-on-uefi-based-computer.aspx
Dec 21, 2014 | HP Computers & Internet
My new Hp p2-1394 desktop came with Windows 8. I do not like 8, and wish to install Windows 7. I can boot from CD but can not access my hard drive to install Windows 7.
all original windows reserve a recovery drive. you should repartition your hard disk first and delete the recovery drive to be able to install another OS.
Feb 08, 2014 | HP/Compaq P4 System - WinXP Pro/Office...
Computer wont load shows emachine sign then goes to reboot screen
right go into the bios and look through the options until you find one that says either UEFI or Legacy, make sure they are legacy. If you don't have this option, find out your bios version and then update it try again in the bios and see if this works if not switch to UEFI and then try again
Jan 12, 2014 | E-Machines Computers & Internet
How to enter bios asus on my asus v550c
On systems with Windows 8 pre-installed, you can access the UEFI (BIOS) setup screens from the Windows 8 boot menu:
  1. Press the Windows key + C, or swipe in from the right edge of the screen to open your Charms.
  2. Click Settings.
  3. Click Change PC Settings.
  4. In PC Settings, select General.
  5. Under Advanced startup, click Restart now. The system will restart and show the Windows 8 boot menu.
  6. In the boot menu, select Troubleshoot.
  7. In the Troubleshoot menu, select Advanced options.
  8. In the Advanced options menu, select UEFI Firmware Settings.
  9. Click Restart to restart the system and enter UEFI (BIOS).
How to access BIOS on an ASUS laptop
Dec 06, 2013 | Computers & Internet
I'm having problems installing Ubuntu on Windows 8.
restart the computer HOLD the keys CTRL+F11 OR F12 depend of your model, and restore to the factory defaulty, and try it again.
God bless you
Jul 09, 2013 | Dell Latitude D531 Laptop Computer PC...
Windows 7 with Gigabyte motherboard says "ntldr is missing"
Check if UEFI is disabled after flash with newer BIOS version. If you flash BIOS the default settings gets loaded again. Check hard disk settings and boot settings.
Mar 03, 2013 | Gigabyte Computers & Internet
Tecra A11 can't see all of 3TB drive
Support for Disk Drives Beyond 2.2 TeraBytes (TB) and 4K Advanced Format Sectors
Most legacy systems built before 2011 have a traditional PC BIOS. This type of BIOS uses a Master Boot Record (MBR). The MBR Partitions can define a disk drive capacity up to 2.2TB. Windows operating systems that boot from an MBR are therefore limited to 2.2TB per MBR. A 3TB disk drive in a legacy BIOS and Window system will need a DiscWizard device driver to access the full capacity of a 3TB disk drive. Two partitions will be necessary because of the MBR limitation. The device driver mounts the capacity above 2.2TB with another MBR which looks to the system as a second virtual "physical" device.
GUID Partition Tables (GPT) can define drives larger than 2.2TB. You can use GPT today on any Windows 10/ 8.1/8/7 and Vista system as a non-booting data drive. Windows can only boot a GPT partition on a new type of BIOS called UEFI.
UEFI BIOS desktop systems are new since 2011. Windows 10/8/8.1/7 64-bit and Vista 64-bit operating systems support booting from UEFI and GPT without the need of a non-Microsoft device driver. This is the Windows native solution for booting a 3TB drive to a single partition.
Quick facts about Windows and 3TB drives:
  • Windows 10/8/8.1/7 and Vista support GPT 3TB single partitions
  • Windows 10/8/8.1/7 and Vista can only boot GPT on systems with UEFI BIOS
  • Windows 10/8/8.1/7 and Vista can mount a GPT non-booting data drive
  • Intel RST device drivers before v10.1 do not support 3TB disk drives
  • Windows systems with Legacy BIOS and MBR boot drives are limited to 2.2TB partitions
  • Windows XP does not support GPT
  • Windows XP sees a 3TB drive as 800GB on boot or data drives
  • DiscWizard software can install a device driver which opens the full capacity of a 3TB. You can use it to create a second partition for the capacity above 2.2TB
Sep 27, 2017 | Toshiba Computers & Internet
Gateway One ZX6971-UR30P All-in-One Desktop PC with Intel Core i3- Logo
95 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
